Great idea thanks! Last Winter I had problems with my brothers DRL on his honda and after some research, I ended up resoldering some cracked solder joins in the control module and everything worked again. Thanks to all the tips in this thread I'll keep at it and see where it goes.
If it turns on then turns itself off, it sounds almost like too much of a load that the supply “folds back” shortly after.
Ever power up the supply with a dummy load (resistive), see if it holds steady?
If it does, increase the load to what the teevee should be drawing, see if it keeps holding steady. If yes, then a different board might be trying to draw too much.
Coupla new(ish) laptops they gave me from work have these weird-ass barrel connectors, not the usual 12V kind, but 18V or more, and huge (but flimsy) plugs. Squishable-between-your-fingers flimsy.
Anyhoo, tried powering up some strip-lights, evidently tried drawing more amps than the beastie was rated for, and just stopped. No voltage. Oops. Power it off (ie, unplug it), wait a few secs, then plug it back in, works again. Repeat the experiment, same thing. Shuts down, doesn’t come back up ’til unplugged and “rested” a few secs.
That’s when I look up the ratings of the strip-light. Whups…
Both fuses are good. Does your DMM measure capacitance?
I also noticed in the bottom middle of your pic there is a black box. Looks like a relay to me. I had one of those go bad on a older TV before.
Looked it up, it does measure capacitance. Ideally, caps need to be measured out-of-circuit. Without knowing what the capacitors are in parallel with, the readings may or may not mean much.
Not easily. If you look up "how to measure caps in circuit", there are some rather sophisticated ways that might give you some ballpark values in some circumstances. This is not going to be practical for you. https://www.youtube.com/watch?v=qDABYKoVO4Q
Even though your research "goes back to the PSU", it's certainly possible the issue is with the TV. If a component in the TV shorted out, pulling too much current, the PSU may shut down as a safety feature.
I don't think it would be that easy to test it with a dummy load as it has three ribbon connectors so could be complicated trying to give power to it. Would be disappointing if you were right and another board is faulty of the plasma screen itself as are drawing the extra current that is switching off the psu.
On occasion I have heard of the plasma screens themselves giving out so that is a real possibility. If there is a short elsewhere, well that could be too, that's why I ordered the psu board just to give it a go, but they cheated me and sent me a beat up used one instead of a new one.
Apples and oranges, buuut, my LED backlit TV stopped working and I wasn’t getting voltage at the power supply output, bought a used PSU and same thing happened.
Turns out it senses when one of the series LED lights goes out and shuts down. Bought some new LED strips from Shopjimmy.com and it’s better than new.
Could be something downstream.
Shame you can’t take all the tubes down to the drugstore tube tester or clean/replace the tuner knob. (sorry, joke for old people)
look for a short to ground on the va and vs lines.
if you find one unplug ysus from the power supply.
if still there unplug zsus.
y=big board on left as you are behind set.
z=the one on the right.
if no short leave va,vs unplugged from power supply and power it up.
measure from ground to va,vs.
if nothing possibly that section is not being commanded on or blown up.
or apfc not running and that section is in uvlo.
apfc output is at the 2 big caps on their side and is around 400vdc
oh and big warning!
these power supplies are dangerous due to both high voltages and high surge current due to big filter caps on va and vs.
apfc is around 400vdc and backed up by big caps too.
Since you tried another PSU board that was likely okay even if dirty, and you got the exact same symptoms—then i’m gonna say your problem is NOT on the PSU but on one of the other boards.
You didn’t really troubleshoot this problem and determine that the PSU was bad, you just assumed it was bad, based on stuff you read on the websticle. You obviously don’t have the equipment or skills to troubleshoot it, especially without a schematic. This is too dangerous for a novice.
Yeah, I took a chance that it was the psu after what I read and since the clicking sound came from that board, but as the short could be elsewhere, it could be a problem. TV is at my brothers house, so Monday I will put the original psu back and unplug one at a time the other three boards that are plugged into the psu board to see if that isolates the problem possibly to a board and I can go from there. I'll do my best to avoid a big voltage shock as I like my life at the moment!
I plugged in the original psu board and started unplugging each board to test like you said and the psu works again as long as the large board on the left in the pic is unplugged. I could not see any faulty caps or anything though. Is it worth the risk to try and get a replacement board or can I troubleshoot further now that we know something is going on with the left board? Looks like all the plasma screen lines are plugged into that big board, but how would I test to see if the problem is the board or what is connected to it?
Pic below psu is not in, but you can see the big board on the left. PSU will work if I unplug the top wire to it, or
if I unplug the top wire of the right board where the left board plugs into.
likely one or more shorted igbt’s.
look at the y buffer chips for burns or holes.thats the 2 green boards left of ysus.
if none found its a good risk to buy a ysus.
or you can get a parts kit and rebuild yours.
I would bet it’s the YSUS, had a 50” LG plasma go out like that. It started with very intermittent pop and momentary screen dim, but eventually progressed to a black screen with sound. Bought a “new” YSUS on Ebay, but got a well used one which still worked for another couple of years of heavy use. Just gotta be very careful not to press on the ribbon cables from the buffer boards to the screen when installing the new YSUS board.
Thanks for the help again. Had a look yesterday at the y buffer chips and didn't see anything, but tomorrow I'm over there again and will use my trusty flashlight and a magnifying glass and have a another good look just in case. If I set my DMM to continuity, can I a do a test on the y-buffer chips whilst the board is still connected to the tv or would I have to pull it?
