So… I see I managed to miss the 351D in 4000k… Looks like they may come back into stock? I am interested since the Vf is higher and I have a couple of triples that I would like to rebuild.
Great thanks! Now I need to figure out what host to use. I have way too many S2+
I prefer E2L. Lighter weight and you can access bezel easier to switch optics but overall not much different from S2+
@AEDe again, do you have 3000k 90CRI 351D emitters?
Thanks again for the response.
There are only 3 Hicri led in the shop I used.
1)351D 4000K 90cri
2)351B 3000k 90cri
3)XPG3 5700 90cri
All other variants available on order whith minimum 800-1000pcs with lead time obout 6 weeks.
If you need at least 500pcs. 351D 3000K 90cri(300pcs I can take for myself) we can arange order, but with a prepayment condition. I not have vacant >1000$
Mmmkay, for the time being sign me up for another bunch of 10x LH351D 4000K CRI90+ AEDe.
Already set and tested 6x for a room lamp under construction, and 2x in S2+ hosts with 30º TIRs. Had to reflow one for an S2+ twice, and I'm measuring at least 8% less light flux from its torch vs the other all else being equal. Wow…
Cheers ^:)
list updated
Put me down for:
(10) 351D 4000K 90CRI
(4) 351B 3000K 90CRI
Ship all at same time. No rush.
I’m interested in:
FB
… Had to reflow one for an S2+ twice, and I’m measuring at least 8% less light flux from its torch vs the other all else being equal. Wow…
Sorry if this is off-topic, but for the sake of completeness I have to add the explanation. The variation I measured in light flux between my recent S2+ builds isn't caused by faults in my reflow process, which I already have well mastered and allows me to do away with potential temperature related emitter damage. It is due to lens quality variation: Cree 30 Degree Angle Optical Lens (5-Pack) @ FastTech. Out of my 5-pack of lenses one is clearly brighter, the next two are good and about the same, the 4th one is a tad less bright but close, and the 5th one another bit less bright. Brightness delta between best and worst is ≈15%. Nuts…
Cheers :-)
In for another 2 of CRI70 5000k LH351D.
I am interested in 4x 351D 4000K 90CRI 5x 351B 3000K 90CRI
6x351D 4kK 90cri for me please.
I would be in for 4000K 90CRI LH351D (20 pieces)
Could you please notify me, when it will be available again?
Measurements and other data made me consider additional 30 pieces - probably will make several direct driven triplets and/or quads, thank you for your published measurement, djozz =)
Now interested in total of 50 pieces.
would like 8 4k 90 CRI 351D please
Hello again AEDe.
I am interested in 8xLH351Ds.
List updated.
I found another “gem” in the store, which you have linked.
It is 6000K+ CCT and CRI90+.
This is the store link with translation:
https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=\_t&hl=hu&ie=UTF-8&u=https%3A%2F%2Fe-neon.ru%2Fmoschnyie-svetodiodyi%2Fmoschnyie-svetodiodyi-1%2Fsphwhtl3da0gf4pqr6&edit-text=
The store probably falsely associates the led to the LH351B family, as in that document, there could not be found any order code like on the page.
However, there is a match for SPHWHTL3DA0GF4PQR6 in the manufacturer documentation at the LH351D section - and the LED price is also seems to be one of a price of LH351D LED:
http://www.samsung.com/global/business/business-images/led/file/product/products/201703/Catalog_LED_Lighting_Mar_2017.pdf
Is there a slight chance, that you could also collect interest, and manage the group buy for this LED, too?
It would be so cool (literally as well, lol) to have a 6000K CCT CRI90+ emitter, after we saw all the promising data for the 4000K CCT variant.
I will ask manager of e-neon about 351D hicri in other CCT and will try to make GB. but it needs a lot of people, at least 400-500led shold be “preordered”
Bad news they change order conditions, now min order 6400pcs.
