“For a lot of us mere mortals, seeing the cool things machinists make on their lathe is just a dream.
Hence the finish of the FW3A will be clear anodisation, no sanding/beadblasting before anodisation.
The idea is to give all the chance to have a light looking like it came of a lathe with the protection of anodisation.”
I’m sorry but I am rather disappointed with the new photos, I don’t think the taper from the head works, it doesn’t blend with the more industrial look of the tailcap and clip etc, I prefer the original design which I think is more honest, and minimalist.
I am particularly disappointed with the beadblast finish, which ISTM is simply a cheap way to cover up surface imperfections. I’d far prefer a raw “aerospace” machined finish, ideally with a true thick un-dyed HA-3 anodisation (which is naturally a dull gray-ish finish, and immensely durable).
This would require fine machining and careful handling of the parts. Some of the best machined and anodised torches I have are MAG-LITEs so I see no reason why this one couldn’t have a similarly good finish.
I will buy this, but I’m sad that it isn’t quite what I was hoping for.
It’s looking great.
Lets not spend more time debating the exact look of the flashlight body. This project is taking too long already. Many of us are liking the new look better. I guess it is impossible to satisfy everybody. LOL
If you created the ultimate light, capable of producing an infinite amount of your preferred light quality in the perfect beam pattern for your intended use, at will, out of thin air, with the whole mechanism stored in another dimension so it has no volume or weight, we wouldn’t like it, because there would be nothing to look at or collect, only results.
What use are results?!! We want collectibles, and we want them in a rigidly defined schedule of unpredictability.
