I am really excited about this light. Any way you can post dimensions?
thanks
thanks
Thank you for showing us that the keyboard is mightier than the M16.
Post #1 says 94.8 Ć 25.5 mm. There are also size comparison pictures.
Iām #27 on the list, Iād like to request another light please. Thank you.
Iād like to be on the list for two lights if there is availability still? Thank you
Love the new prototype! Looks great!!! :+1:
The new prototype looks big. Hope thatās an illusion. How come thereās prototypes being sent out randomly but no actual communication?
The prototypeās pretty much the same size as the last one. Nealās just got a talent to find unflattering angles As soon as we get it in our hands weāll post some more pictures and details.
I think that is just an optical illusion. I thought the same thing when I first saw that picture above.
The below is taken from the first post & gives a very good size comparison photo.
The FW3A
Small elegant EDC triple flashlight designed by Fritz15
Runs on a single 18650 battery.
94.8 Ć 25.5 mm
First prototype:
Size reference:
Proto 1 (post 1) vs Proto 2 (M4DM4X picture above)
It looks like the main external design difference between 1 & 2 is the addition of a small taper in front of the tailcap on #2.
I totally agree!! :+1:
But, since fritz15 designed this light, Iāll be good with whatever he gives the final OK on.
But, that being saidā¦ the proto with taper is nice!!
Still like Fritzā original design best (taper schmaper )
FWIW, a few notes about the LT proto2 photos:
With any luck, proto2 should show up soon for testing, hopefully with the internal changes completed as requested.
Alright, Iām gunna bite. Put me down for 2 please!
Iām not bothered by the taper; I just donāt like this sort of finish. In an ideal world, itād be the same sort of finish as the blf 348; of course this is a different thing.
What type finish is it?? Is it bead blasted or whatā¦. I canāt tell.
The BLF-348 is bare steel. The FW3A is not steel, but it could potentially be bare aluminum depending on how things go.
I prefer natural anodize to bare aluminum.
I find bare aluminum transmits heat to my hand much faster than anodized aluminum. The result is hot-rodded high-lumen lights are much less practical. I have to ramp down earlier to avoid burning my hand.
If I had to say something about this, I would probably prefer an anodized version instead of bare aluminium! But letās see how things evolve
Itās good to have these updates :+1:
OK, thank you TK. :+1:
Like I said earlier, I am good with whatever it turns out to be.
A preference is clear anodizedā¦. but certainly not a deal breaker in any way if it is not. It would not even bother me if it had a lightly blasted finish.
Iām easy to please on this oneā¦ā¦ā¦
Well in that case, why not reduce the threshold temperature and let it do that for you? Generally conductivity is thought to be a good thing; isnāt it?
