The person holding the light has small hands, so the light appears bigger than it really is.
M4D M4X doesn’t have a prototype… or tiny hands. Neal got excited and sent pics to several people.
The photos seem to be taken from up close where there is a lot of perspective distortion, which makes it look weird.
The finish looks pretty odd in the photos, so we’re waiting to see it in person. Maybe the final product won’t be anodized, or maybe it’ll have more traditional anodizing, but … hopefully it won’t look like today’s unflattering photos.
With any luck, proto2 should show up soon for testing, hopefully with the internal changes completed as requested.
I’m not bothered by the taper; I just don’t like this sort of finish. In an ideal world, it’d be the same sort of finish as the blf 348; of course this is a different thing.
I find bare aluminum transmits heat to my hand much faster than anodized aluminum. The result is hot-rodded high-lumen lights are much less practical. I have to ramp down earlier to avoid burning my hand.
Like I said earlier, I am good with whatever it turns out to be.
A preference is clear anodized…. but certainly not a deal breaker in any way if it is not. It would not even bother me if it had a lightly blasted finish.
Well in that case, why not reduce the threshold temperature and let it do that for you? Generally conductivity is thought to be a good thing; isn’t it?
I saw some bare aluminum recently that looked pretty nice.
They call it raw, tumbled aluminum.
Dont want to link to picture so I’ll just put a link if anyone wants to see it.
They all look great to me. Just ordered a D4, can’t wait any longer to burn a flashlight profile into my hands, but I am keen to have both now to compare, and it looks like a holster made for one will fit the other so edc rotation works
Once heat gets to the outside of the light emissivity is a good thing. Conductivity, not so much. The interior of the light and the battery can all take much more heat than my hand can. All removing the anodizing on a light like this does is make it so I can’t run it in turbo as long. There’s really no upside.
This light doesn’t have a lot of thermal mass or a lot of surface area. If you want something which runs at 3000+ lumens for more than a few seconds without getting hot, this isn’t the light you’re looking for. It’s simply not big enough… so its turbo level is really a “burst only” mode, much like the D4-219c.
The default settings place the ceiling at the 8x7135 level though, which it can sustain quite a bit longer than full turbo. Last time I tested that, it looked like this:
“Surface Treatment of Aluminum, Wernick and Pinner, 4th Edition, P.608, Ch. 9. Hard Anodizing:
The thermal conductivity of the anodic coating is between one tenth and one thirtieth of that of aluminum:
The emissivity of aluminium increases rapidly as the thickness of the layer is built up, increasing to 80% for a 10 um coating. A thick hard anodic coating is therefore well on the way to being a ‘black-body’ for heat dissipation, and there is very little advantage in dyeing it black as is sometimes done.”
