look for a short to ground on the va and vs lines.
if you find one unplug ysus from the power supply.
if still there unplug zsus.
y=big board on left as you are behind set.
z=the one on the right.
if no short leave va,vs unplugged from power supply and power it up.
measure from ground to va,vs.
if nothing possibly that section is not being commanded on or blown up.
or apfc not running and that section is in uvlo.
apfc output is at the 2 big caps on their side and is around 400vdc
oh and big warning!
these power supplies are dangerous due to both high voltages and high surge current due to big filter caps on va and vs.
apfc is around 400vdc and backed up by big caps too.
Since you tried another PSU board that was likely okay even if dirty, and you got the exact same symptoms—then i’m gonna say your problem is NOT on the PSU but on one of the other boards.
You didn’t really troubleshoot this problem and determine that the PSU was bad, you just assumed it was bad, based on stuff you read on the websticle. You obviously don’t have the equipment or skills to troubleshoot it, especially without a schematic. This is too dangerous for a novice.
Yeah, I took a chance that it was the psu after what I read and since the clicking sound came from that board, but as the short could be elsewhere, it could be a problem. TV is at my brothers house, so Monday I will put the original psu back and unplug one at a time the other three boards that are plugged into the psu board to see if that isolates the problem possibly to a board and I can go from there. I'll do my best to avoid a big voltage shock as I like my life at the moment!
I plugged in the original psu board and started unplugging each board to test like you said and the psu works again as long as the large board on the left in the pic is unplugged. I could not see any faulty caps or anything though. Is it worth the risk to try and get a replacement board or can I troubleshoot further now that we know something is going on with the left board? Looks like all the plasma screen lines are plugged into that big board, but how would I test to see if the problem is the board or what is connected to it?
Pic below psu is not in, but you can see the big board on the left. PSU will work if I unplug the top wire to it, or
if I unplug the top wire of the right board where the left board plugs into.
likely one or more shorted igbt’s.
look at the y buffer chips for burns or holes.thats the 2 green boards left of ysus.
if none found its a good risk to buy a ysus.
or you can get a parts kit and rebuild yours.
I would bet it’s the YSUS, had a 50” LG plasma go out like that. It started with very intermittent pop and momentary screen dim, but eventually progressed to a black screen with sound. Bought a “new” YSUS on Ebay, but got a well used one which still worked for another couple of years of heavy use. Just gotta be very careful not to press on the ribbon cables from the buffer boards to the screen when installing the new YSUS board.
Thanks for the help again. Had a look yesterday at the y buffer chips and didn't see anything, but tomorrow I'm over there again and will use my trusty flashlight and a magnifying glass and have a another good look just in case. If I set my DMM to continuity, can I a do a test on the y-buffer chips whilst the board is still connected to the tv or would I have to pull it?
Maybe he thinks plasma is a form of LCD.
It’s really ashamed manufactures stopped producing plasmas. I love my 2014 Panasonic plasma TV. The general public wants cheap TVs though. And 300 for a 50 inch Vs 600 for a plasma killed them. I think there’s one company that still makes a few
There’s something to be said about the size and weight of LCDs vs plasmas well. My 50” plasma has been in storage ever since I moved over 2 years ago. The original box it was packed back in won’t even fit in my car and requires 2 people to move as well as unbox and setup the TV. When my “temporary” 42” LCD died, rather than haul the plasma out of storage, it was easier to buy a new 55” slim LCD that fit in the car with the box and set it up singlehandedly.
I think the point was about understanding more about the topic before offering advice. What you posted was like someone asking to troubleshoot an LED driver and getting a response like Maglights are notorious for burning out bulbs, did you check for a spare bulb in the tail cap. It was not at all related to the technology or problem, but the responses could’ve been less harsh.
Back in the 90’s I repaired a lot of VGA monitors. Most of them I did not have schematics…….(simply too many different brands). The problems were similar. If no schematic available this is what I would do:
1) Check the internet with model number to see if anyone has posted any info on a similar problem. If one person has a particular problem is means others probably are too. See if anyone is talking about it.
2) Check for bad capacitors. Have to use an ESR (effective series resistance) meter. I never worry about checking capacitance. It’s the ESR that is the issue. Most of the time you can check ESR in circuit without removing the capacitor. Only in situations where the capacitor is in parallel with a low impedance item like an inductor do you get a false reading………but that reading will make it look good. But if you get a bad reading in circuit, then the cap is definitely bad. The electrolytic solution dries out over time and generates a series resistance to the capacitance. If there is a lot of ripple current and filtering going on with that cap, then the added resistance increases the power that will be dissipated by the capacitor and that can cause the cap to get hot and bulge. The ESR problem tends to show up with the higher voltage caps and the bigger value ones. Those are the ones I check first.
3) Bad caps can also cause a power semiconductor like a mosfet, power diode, or other heat-sinked semiconductor associated with that cap’s circuitry to go bad. If after replacing a bad cap and it still doesn’t work, then need to look at the power semiconductors. Mostly look for shorts with DMM.
4) Bad solder joints occur over time………especially the bigger pins and joints. A lot of the time you can see the cracks in the solder but not always. I recently fixed a VHS / combo TV for an older gentleman in my neighborhood and it was a bad solder joint. Never knew exactly which one it was. Could not find any bad caps………so last resort was to just reflow a bunch of solder joints. Problem fixed. (Got lucky)
5) If after spending a lot of time and no schematic or no luck in repairing, I would just call it a wash, give up and move on.
Hope this helps. Some of it has already been talked about, but thought it wouldn’t hurt to mention.
