20,000 mAh Power Bank recommendations?
Hi Green,
If Pete doesn’t mind me posting a link to a much higher capacity power bank in his thread, I’ll do that. I really need to take some photos and start a new thread on these. I’ve been most impressed with them
and for $200.00 or less, I think it’s a bargain considering what the Goal Zero brands and such cost.
@Pete, there are two products that I can vouch for their quality since they have been reviewed by trustworthy people and are not expensive.
There is EasyAcc 20Ah 4 USB ports power bank. It has been tested to actually be 22 400mAh, so good thing there:
https://www.amazon.com/EasyAcc-20000mAh-Portable-Recharge-Capacity/dp/B01422TC14?keywords=20000mah+powerbank&qid=1527979650&sr=8-11&ref=mp_s_a_1_11
There is also Romoss. It is the OEM of many powerbanks such as Ravpower.
Their flagship monster has an 8A output limit over 4 ports:
https://www.amazon.com/ROMOSS-20000mAh-Portable-Capacity-Micro-USB/dp/B078JSJHPK?keywords=20000mah+powerbank&qid=1527979748&sr=8-29&ref=mp_s_a_1_29
Then there is iMuto. They specify in 26650 power banks:
https://www.amazon.com/20000mAh-Portable-Charger-External-Black/dp/B01191S0VY?keywords=20000mah+powerbank&qid=1527979849&sr=8-49&ref=mp_s_a_1_49
I can trust that last one too since I have tested it to be 91% efficient at 5V 1A, and 89% at 5V2A. Which is quite good.
BTW, guys, the reason I only buy power banks with cylindrical cells is because if the power bank dies before warranty ends, I can just ask for another power bank from the brand. It happened once with my RavPower QC 3.0 20000mAh one, in which one of the USB-A ports broke, and caused a soft short, emptying the bank in about 2 days.
After I received the new powerbank, I opened up the pack, and found 6x3400mAh cells, and I now use them in many of my flashlights.
TLDR: Only buy 18650/26650 power banks so you cab salvage the cells later if something goes wrong.
Finally, Pete, don’t sorry about some of their prices. With the 10000s of cells they are ordering, they must be getting them at 1.35-2$ a piece, then picking the cheapest case and electronics for the ones <20$, and much more efficient and powerful >30$.
Look at Xiaomi power banks - they make the best bang for buck banks on the market. The 20,000 mAh go for around $35, contain Panasonic/LG cells and have a conversion rate of ~93% (12,700 mAh actual)
BlueSwordM, thanks for the suggestions, but none of the chargers you linked have QC3.0 output, unless I missed it.
@Pete
1. The Romoss supports 5V 3A charging and discharging over USB-C.
Samsung and LG phones can fast charge from them if you are using a USB-C to C cable.
The EasyAcc support 5V 4A charging from 2 Micro-USB ports, a bit inconvenient, but the second fast charging non-USB C/DC jack powerbank. at 20W.
2. Are you willing to forgive 18650 power banks? If so, getting a lithium ion power bank with a pouch cell and Qualcomm QC 3.0 is much easier.
This Vinsic QC 3.0 has been tested by Dodge reviews to have a legit 20Ah cell:
Here is the Amazon page:
https://www.amazon.com/VINSIC-Portable-Charger-20000mAh-External/dp/B079FN92JT?keywords=20000mah+power+bank+vinsic&qid=1527985867&sr=8-6&ref=mp_s_a_1_6
It is a real legit 20Ah powerbank.
That is just for input, not output.
I am looking for 9V/2A output.
The one in the Youtube video is VSP304. The one on Amazon is VSP303. I wonder what the difference is.
Looks nice though. I don’t mind that it’s not 18650/26650 based.
Hi Pete7874
I see another member “antik” recommends the Xiaomi as well.
There is a good review for one on this forum:
I hope this link works because it’s the first time I’ve done this
Just to update this thread, I ended up ordering the Romoss one that BlueSwordM provided a link to earlier, based on a combination of price, good reviews, and high overall current output. It does not have QC 3.0 output, which was one of my original requirements, but I just couldn’t find something with QC 3.0 that was also reasonably priced, had great reviews, and was made by a reputable company. 5V/2.4A output will be good enough for me, I guess.
@pete, sorry, I had forgotten about this one:
https://www.amazon.com/Besiter-Portable-Capacity-20000mah-External/dp/B07DN742XL/ref=sr_1_19?ie=UTF8&qid=1530815772&sr=8-19&keywords=20000mah+powerbank+qc+3.0
It’s a legit 20Ah powerbank, with a max combined output of 36W using both the QC 3.0 and USB-C port.
For some reason, they all use the same powerbank circuit as the RavPower QC 3.0, but just has a less capable buck converter for charging, meaning the “clones” only charge at 18W vs the 24W the RavPower is capable of.
I did see this one earlier, but some of the critical 1 and 2 star reviews stopped me from getting it. And I’ve never heard of Besiter either. :slight_smile:
I was more comfortable buying Romoss, just based on my personal experience with their chargers in the past.
You’re not lucky either.
I got my RavPower QC 3.0 for 26$CA, do about 20$US last year.
I have that one, capacity charging speed, output are all good.
But construction is sub-par.
Two of it’s 4 port wiggled a bit when I first got it. Now after a year the ports can only be used when you push them exactly the right way.
If not they ‘disconnect’ and don’t charge at all.
Actually anker raised the price of his power bank after he win the 80% of the amazon.com market. I guess xiaomi is a better choice.
Thanks BlueSwordM,
I got this one you linked to for use with the mini TS-80 soldering iron and it needs QC 3.0 and USB-C. Hopefully it will be a nice portable solution. As a plus I can charge my phone and flashlights with it when needed.
You’re welcome.
I’m always here to help.
BTW, if you have a USB power meter and some 5Ohm resistors, you could perhaps test the powerbank’s real capacity.
I ordered the 30k Romoss from Amazon, they have a 39Percent off coupon right now. Came to like 23 bucks plus tax. It’s a beast, already arrived. Thanks for the information.
I have this one and it’s amazing but quite pricey:
I can power an HP laptop with the thing, or two IPhone 12 Pro’s. Charges in less than an hour.
I’ve got a genuine 10Ah Xiaomi as well, with soldered LG, or Samsung cells and after 3-4 years, it’s been pretty good.
I leave it at my gal’s place, but prefer banks with removable cells.
Chris
I have been using RAV Power 20,000mAh 80W, which is quite reliable but very heavy, 23.3 ounces or about 660 grammes. And it looks like a black metal block.
I haven’t tried bringing it on any air flight just yet, although it is under the 100W maximum powerbank limit for onboard carry-on. Will certainly need to explain what it is and show written evidence that it is safe to carry onboard.
When it is on sale, it costs around S$130 in Singapore, or around US$95. I think it might be cheaper in the USA.
Isn’t it strange that they have a battery capacity limit for planes? Does it go over some threshold for catching fire or exploding at 99 watt hours or whatever it is?
