- Normal heavily sinked and cooled the output peaked at 3,1A with very marginal output rise from 2,9A to 3,1A (it’s not really worth it)
- From 3,1A and above the output dropped sharply.
- At 3,4A all the silicone in the phosphor layer started to burn
Phosphor layer scraped, watercooled, the blue light kept increasing until the whole die completely burnt at ~7A (this is single E21A)
This evidence is a sure thing that the die would not overheats at the output peak current, only the phosphor layer. The phosphors itself can withstands ~200C but the silicone binder doesn’t.
We didn’t post the R9080 measurements due to inconsistency in measurement. But it was indeed hotter than the R70. I think Jensen567 still keeps the data.
E21A has special construction unlike ceramic based CSP LED (XD16 for example). Large portion of the phosphor layer are is isolated from the base due to the use of reflective barrier. It’s the white silicone-composite-something stuff surrounding the die.
The above measurement taken by Nichia was using normal MCPCB with very high thermal resistance unlike what we use in our boards (I believe we use the same technology ). With VR16SP4 board we can push the E21A far beyond it’s rated wattage. This also means the temperature difference also lower. Me and Jensen567 did many tests and found that the limiting factor is the phosphor layer not the die. We also found the phosphor layer max temp at max output always somewhere near the 180C surface temp.
Are there any drivers that could take a quad E21A to 10 amps? Over on reddit it was pointed out that with the Vf so low it seems FET would be a bad idea.
I’m imagining a high amp quad E21A build. Like a high cri BLF A6 competitor. Or maybe even a quad quad E21A build (four clusters of four) with a regulated driver that could push 15-20 amps. Maybe in a body similar to the S41.
It looks like I might of made a mistake with the single E21A tint. I thought it was 4500k but it might of been something else. I just looked at it again and the die is cooler then the others, so it very well could be a cooler tint. I don’t remember what Clemence sent me besides the mixed tint version.
djozz posted this photo of an E21A 2000k in a Copper Klarus Mi1c, it does not have an aspheric lens, that model uses a reflector with flat lens.
I will post photos of my Aspheric lens Utorch S1 Mini with 2000k E21A, in a few weeks, when it arrives from being modded by Clemence.
fwiw, the Utorch is on sale at gearbest for just $20 atm and the aspheric Mi1c is on sale for $30 (ask fin17)
trivia, the Klarus will memorize moonlight, the Utorch will not. fwiw, the moon mode on the Utorch is much lower, which I prefer. Only the Utorch offers a NW option.
Yeah, I think E21 quad is the best LED on the market for Mi1C (as it turns out - the variant with a reflector too) or Utorch S1 Mini.
At least when ignoring the price….
Correct, it’s very expensive. First is the board itself. Hopefully the manufacturer will reduce the prototyping cost for my next 20mm boards.
Second is the LED itself. At its early mass production time, the base price I got from Nichia was ALMOST the same as 219C R9050. Nobody would not believe me this because most people will judge from the physical appearance and the bulk material as seen. I have to lower the price just to make it looks “fair” to the customer.
Now its getting cheaper as more manufacturers are using them in their “creative” products.
Here is a rough illustration of the beam progression from stock single NW, to warm quad, to frosted
all photos originally from Clemences build progress reports…
the light is still in its Tropical Paradise Incubator, pending the birth of a sibling quad E21A w 4000k complexion
I have been using one of Clemence’s custom Armytek Tiara’s with 4xNichia e21a in 4000K for over 1 month now.
Thought I’d provide some feedback on this LED.
The tint is absolutely amazing, closest thing to perfect I have ever seen. It makes Nichia 219C 4000K seem very yellow in comparison. There is absolutely no tint shift, and both tint and CCT is perfectly even across the entire beam of light (*under stock Armytek TIR).
With regards to CRI, its also the best I have used to date. Everything pops but in a very natural way. Almost like what a good light source should be, something you don’t really notice or think about. With all other LED lights I have used to date, I always feel like what I see feels less saturated, and with less contrast then real life. Not with the E21a. When I turn it on, it feels like sunlight quality light but at night, quite surreal actually.
In sum, I am very impressed and looking forward to the potential that this caliber of LED can bring. As I am a fan of both throwy, floody and everything in between, looking forward to see something with this quality in a light designed for more throw.
I caution those that are thinking of trying this LED, because it may make all your other lights feel inadequate. I was happy with the tint on my Zebralight H600fc MK4 as it was quite similar to my 219c lights, but now this Tiara blows it out of the water.
A big thank you to Clemence and all of his amazing work developing a quad mcpcb for these LED’s, and for his quality work.
E21A slowly gains ground, there are more and more lights with it coming.
But there’s one property of this LED that I haven’t seen measured.
Throw. Or more precisely - surface luminosity.
Does anyone have any data on whether this LED can get some reasonable throw or is it purely a flooder?
