UTorch UT01: 400 lm on NiMH; 800 lm on Li-Ion, although realistically it is probably closer to 600 lm. Often goes on sale for $9.99 with a coupon. I’ve got several of them.
Small enough to clip to your hat and use as a headlamp as well.
$16.99 with the currently available coupon code
Sorry, I think that flash sale is over.
One thing to note about UT01 is that some people had problems with the switch not working or not working correctly. Both of mine have been fine. I have a CW one an NW one. I prefer the CW. The NW version is way too warm for my liking.
The Zebralight SC5w is a great light, by far my favourite 1xAA light. Over 500 lumens, nice tint & beam, fantastic UI. All on a single Eneloop.
It’s a little pricey, but IMO, the Zebralights are well worth it. I have a drawer full of AA lights, but it’s my Zebralights that I end up using 99% of the time.
Check out Manker E11, Utorch UT01, and Lumintop EDC05. They are all a very similar design with decent output. All 3 have had some reports of driver/switch issues (read the threads on these), but lots of people haven’t had any issues. Both of my UT01 lights work fine with AA or Eneloops, but have the well documented driver/switch problem when using a 14500. Still a very nice light though. FWIW, Lumintop supposedly has been working on the problem, and “supposedly” they have now fixed the issue. Lumintop also is the only one of the 3 that has a magnetic tailcap. I have a couple of other lights that have this feature, and I find it super handy to have.
High Lumen AA lights I have include Reylight AA Pinapple, Lumintop EDC05 in NW, Olight S1A in CW, Utorch UT01 in CW, Jetbeam Jet I MK in CW, and a Enogear Stainless AA in NW.
I usually end up with the Lumintop or Reylight in my pocket. Although the others all work just fine. I really like the Enogear but is a bit on the heavy side depending on what i’m wearing. I run 14500’s in all of them but they work equally well with NiMh as well. I am also guilty of throwing a DQG Tiny AA in my pocket as a backup.
Honestly if the weight of brass doesn’t bother you for EDC I would just grab a Reylight from the group buy. It’s beautiful and functional. Not to mention built like a tank.
The AA brass pineapple is a nice light, but you’ll definitely need to use a 14500 in it if you want decent output. On a AA, it only goes to about 90 lumens on max. Okay for indoors, but not much use outside. On a 14500, you get about 4x the output on all levels except moonlight, so it’s decently bright on a lithium-ion cell.
It will eat batteries pretty quick on max, though, and get fairly hot. The Nichia 219 emitter isn’t as efficient as Cree, though it is a really nice tint.
Unless you use high discharge NIMH AA cells like eneloops or eneloop pros, you’re not going to get “high output” using AA.
Any flashlight that says more than 400 or 500 lumens is either using nimh or li-ion cells to get those numbers.
I’m still impressed any 1.2v NiMH battery can hit 500 lumens. I thought most were in the 200 range and 14500’s were needed to hit 500-600. Sounds like Zebra has some way to get more of of the eneloops.
Hey rick, I recently reviewed the Rofis R2. Heck of a light. I got around 240 on AA alkaline and about 700 lm with the included 14500. Built in charger as well. I actually run mine with a AA.
