Good to hear djozz!
Now the third GT also arrived to me to play with focus. The second which done only 870 kcd was worse than mine so it need to go to 3,5mm or above with centering plate thickness. I haven’t opened the third yet. and I haven’t got a lot time but I will sum up the conclusion when finished with all three and got the best results.
That is really a useful bit if information. I appreciate you letting us know. I suspected as much bet never took the time to try and prove it. I think I will take a look at some better meters soon…
Thrunite TN42 CW vs BLF GT NW.
Measured lux reading at 10 meter distance using UT383 cheap lux meter.
vestureofblood: djozz:Thanks for the nice comparison, the XHP70.2 mod (with TA driver) is in the planning for my GT also so I’m glad to see it performing so well.
About the lux-readings: I recently (link) compared the LX1330B luxmeter (which is the one I think I see you using) to my high end Mobilux meter (which should be as accurate as you can possibly buy in a portable meter) and my LX1330B meter at least reads the cool white 70CRI XM-L2 in my Sunwayman D40A 9% too high, and a (70CRI) 4500K led 7.5% too low. That is 16.5% apart, so the spectral error of the LX1330B alone could already account for the reading difference that you find between the cool and neutral XHP35 Hi emitters in your GT’s.
Lux test between Thrunite TN42 and BLF GT - Album on Imgur
Very nice, pretty much right in line with what I would expect.
Hardusvd70: vestureofblood: djozz:Thanks for the nice comparison, the XHP70.2 mod (with TA driver) is in the planning for my GT also so I’m glad to see it performing so well.
[/quote]
The reading of the BLF GT is still around 13% under when measuring neutral white color with this type of lux meter. Adding this error will then give around 1.141 real Mcd intensity.
[quote=Hardusvd70]
Lux test between Thrunite TN42 and BLF GT - Album on ImgurVery nice, pretty much right in line with what I would expect.
Using another type of lux meter. Lux measured at 10 meter distance.
…a man with one watch knows what time it is…
Oh how this applies to lux meters and taking readings from flashlights in general.
djozz:…a man with one watch knows what time it is…
That commend is so true.
:partying_face:
Made the GT centering ring in 3D and I made different thickness models. I will 3D print them and try the 3 GT soon. Sorry but I had a lot to do around the house.
Looking good ZozzV6!! . :+1:
I made the centering things in the following thicknesses in mm:
3.0
3.1
3.2
3.3
3.4
3.5
3.6
I need a few days for testing because I start night shifts today and I only home at daylight.
I want to see a XHP-70.2 on it! It should still throw like crazy at least farther than my eyes can see anyway with lots of lumens to spare :sunglasses:
I have a BLF GT-70.2 and in my eyes the throw is not what shocks me. About 200 to 400 yards is hard for my eyes to determine throw, but not brightness.
A palm tree that I shot with my TN42 vn had a small tight circle of light on it (at the leaves) with the Thrunite TN42 vn. The same palm tree with the BLF GT-70 is in daylight the entire palm tree and houses and everything…… I mean 200 to 400 yards away in daylight…… It’s crazy……
AlexGT:I want to see a XHP-70.2 on it! It should still throw like crazy at least farther than my eyes can see anyway with lots of lumens to spare :sunglasses:
Yes, for practical ranges the XHP70.2 is a more useful light IMHO. I never would of guessed it would make these kinds of numbers.
That sounds good Manny! I would not mind a few pictures of that comparison!
/\ …. +1 . :+1:
That looks really cool!
How much do they add to the throw?
