No, they don’t. There’s always slight difference between LEDs, even those came from the same reel.
This is a makeshift solution practice which is not ideal but works OK. In real world practice many flashlight makers do the same. Some uneven brightnesses can be seen in ultra low firefly modes.
Low LED thermal resistance, high thermally conductive MCPCB, and careful soldering (thin solder joints) lessen the problem.
Clemence; Just covering my bases. Hopefully can find a good driver for this.
Pls add one more noctigon 3X in series ($3.30) plus two 219B 4500 and one 219B 4000 ($2.8 x three = $8.40) and reflow service for same (.70). I’m sending $51.75 + $12.40 = 64.15 USD
9A and you're asking if that would work. That depends in what you believe “to work” is. For emitters who start tapering at ≈4A when properly cooled, if “to work” is to witness Mr Magical Smoke that will work.
My guess is you probably meant to say “3A” or “Noctigon 3X parallel”. That fixes it.
3x 219B in series will take no more than 3,5A. 3A is the max. for highest output. If you want to use 9A then parallel is the way to go. I suggest no more than 2,5A / LED.
Soldering service for 3x E21A on 3x VR16S1 = 3x USD 1,2 = USD 3,6.
This is the most difficult one. Scraping off the masking layer, sanding them smoothly, then positioning the LED through the entire reflow process with just enough solder to make flat and thin solder joints. Since you paid already there’s no need to send me more payment to avoid unnecessary fees from Paypal. It’s just to let you know
Mt. Agung eruption has been a norm these days. We’re all getting used to it. And yes, I never thought the additional side orders would be this much. I probably would have to close the store for a week just for soldering.
