Hello,
i need 5 LED, soldered on 1pcs 20mm Triple 20mm mosX and 2 on Single 20mm mosDTP
Thanks, Joachim
Hello,
Thanks, Joachim
To explain better, you only need to specify number of LEDs you are interested in, other details like would you like it as bare emitter,on xx mm MCPCB is not important right now, you will receive coupon code(s) for my store for exact number of LEDs you mentioned here in topic, and when/if LEDs become available, you can use those coupons on MZ related products. Of course I will offer them on all compatible MCPCBs I have/will have.
Any plans on selling Luxeon V in 5700k in the future?
Thanks!
I forgot about BLF Q8 4040/5050 DTP pcb, it also can be used for quad MZ build, added to PCB compatibility list in OP.
Put me down for 4 please.
Ill take 3
Put me down for 4, thanks.
I’m in for 6, thanks
5700K is currently only available in full reels, so it depends on interest.
3
Change mine(post 3) to 7 please.
Ok.
5 for me
Sorry, can you take me off the list? I was going to put these leds in my Q8 but decided to go with LH351D instead, so I’ll wait until you have those in stock.
I am interested in 0 MZs.
Edit: Sorry. I don’t want to buy them anymore.
I have enough LH351Ds for now.
Dang it. Put me down for 4
Added.
I definitely want three, maybe even four. Do you think it would be possible to sand down one of those new triple pcbs and the Cute.3 optic to get it to fit in a p60 host (as part of a permanent “pill”)? When you get them in I will also want one of your drivers for a single-cell with temp sensor and the FET on the LED pcb.
I want them for a high-cri “shock and awe” light for super high currents (basically an internal resistance tester that also lights up nicely :smiling_imp: ). Something really stupid that I don’t really need, but sometimes you just need a fun project.
Not sure how you are going to fit a 32mm mcpcb in a p60 host, since p60 hosts have around 26.5mm bezel diameter… However, here is a triple MZ that I made in a p60ish host using carclo optics: What did you mod today? - #4887 by vinte77 . The triple wasn’t that well received (I felt), but I like it. The mz leds built to a triple 32mm mcpcb plus cute optic would be very nice.
6 sounds like a good number…please put it beside my name. Thank you.
