It’s D160 rated. The same LED as in the store. It has the thickest phosphor layer off all E21A. High CRI in candle CCT light comes at a price - very low efficiency.
That 157lm at 700mA still within the margin of error. D160 rated at controlled 25C Tj.
This is inline with Djozz built using the same 2000K E21A
Has anybody shaved/de-domed a 219C 5000K R9050? How is the tint (yellowish/greenish?)? I have had a few of them laying around for my Noctigon Meteor for a while now, but I’m not so sure. It currently has de-domed 219B-V1s with 5000K. They are quite nice, but very inefficient.
Clemence, I need to say a big thank you again for these E21A emitters, and your additional service… and I think, that I need to be a completionist… :partying_face:
I just finished two more Skilhunt H03 emitter board swaps - one of them had a heck amount of glue among the threads, so it was nearly impossible to get that battery tube loose, but absolutely worth it.
The sm203 gives the perfect ‘just before sleep’ tint, and it will be very useful for not losing dark adapted eyesight. Probably I will take the chance to order one of the new rechargeable (RC labeled) Skilhunt H03s to check that if I could perform the same actions, because I will definitely need this tint, when I am out in the field for watching meteor showers (or other activities, when only a powerbank is available as battery runtime extension), for taking notes.
The sm403 gives a little bit more complete color perception compared to the sm503, but bluish colored objects become somewhat less pronounced. This tint gives a very relaxing reading light.
I would like to ask if you consider adding the sm453 tint to your emitter lineup, because mixing tints would give more rosy result, and this emitter family seems not to be ‘suffering’ from being too greenish/yellowish. Based on Maukka’s measurement, the sm503 is a rather a 5300K one, so the sm453 could be a(n almost) perfect reference-worthy neutral white (not counting in the Optisolis, which has currently limited power).
- There’s a problem with E21A R9080 production for these CCTs: 2000K, 2700L, 3000K, 3500K, 5000K, 5700K, and 6500K. So they’re not available until further notice. Only < R9050 available, and I’m not going to order anything less than R9080.
- Plenty of sm403 and (normally hard to get) sm453 both in R9080.
- I ordered small quantity of 144AR sm453 R9050 and the special 144AR sm563 R9080.
Full range Optisolis (2700K, 3000K, 3500K, 4000K, 5000K, 6500K) rfg00/rfh00, rfc00, all 3 steps)
Never thought into that yet, but absolutely would make sense, and I definitely would take a few, if someone could make a compatible board for 31mm length festoon lights.
(Another field of application, I am currently in the process looking up some (preferably the more efficient, the more good) driver for single 18650 cell lights, because I want to ride bike with customized lights - but for now I will pick 219B/C series LED for that purpose, paired with an XP footprint compatible stripe TIR optics, because I tried closely similar optics already, and seems to be very useful /and spectacular/ in practice).
Thank you :) I will try to reproduce that it would be the best for me to use during museum walks /there are many badly illuminated museum exhibitions here, I already took great use of the Astrolux A1/. And would make a great gift for my loved ones.
