- There’s a problem with E21A R9080 production for these CCTs: 2000K, 2700L, 3000K, 3500K, 5000K, 5700K, and 6500K. So they’re not available until further notice. Only < R9050 available, and I’m not going to order anything less than R9080.
- Plenty of sm403 and (normally hard to get) sm453 both in R9080.
- I ordered small quantity of 144AR sm453 R9050 and the special 144AR sm563 R9080.
Full range Optisolis (2700K, 3000K, 3500K, 4000K, 5000K, 6500K) rfg00/rfh00, rfc00, all 3 steps)
Never thought into that yet, but absolutely would make sense, and I definitely would take a few, if someone could make a compatible board for 31mm length festoon lights.
(Another field of application, I am currently in the process looking up some (preferably the more efficient, the more good) driver for single 18650 cell lights, because I want to ride bike with customized lights - but for now I will pick 219B/C series LED for that purpose, paired with an XP footprint compatible stripe TIR optics, because I tried closely similar optics already, and seems to be very useful /and spectacular/ in practice).
Thank you :) I will try to reproduce that it would be the best for me to use during museum walks /there are many badly illuminated museum exhibitions here, I already took great use of the Astrolux A1/. And would make a great gift for my loved ones.
Resurrecting my Skilhunt optics swap subtopic (d=17mm), I tried those optics as well, and... yes, they did not make much difference in the practice. It seems, the Skilhunt H03 uses the 30 degree one. With the 60 degree one, I get a significantly more granular center spot, and just some more scattering into the spill. The 45 degree one is just a little different from the 30 degree one. The 20 degree one has a very slight ring in the pattern, but nothing disturbing - maybe the beam got a little bit more concentrated, but not near the experience with the LEDs with smaller emitting surface.
Has anyone modded a lantern with these 9080 emitters? Seems like a good use for high cri good tint. This one here can change from WW to CW. I’m imagining 2000k or 3000k WW with 5000k or 6500k CW 9080.
Not yet. Just got quad dtp stars that I was gonna use to refit an old-timey-looking lantern. Probably will stick in some 351Bs (3000K) for now, which should look nice.
