Massive fraud on 18650s in the Littokala Aliexpress stores!
There is the Panasonic NCR18650G though:
https://lygte-info.dk/review/batteries2012/Keeppower%2018650%203600mAh%20(Black)%202014%20UK.html
Down to 2.5V, it could do 3500-3600mAh without a protection circuit.
If I had one, I could test it myself, but it does cost a LOT of money for a single 18650 cell.
The problem with the NCR18650G and all others 3600mAh legit cells is that they tend to have more internal resistance than their 3500mAh counterparts.
Looks like I’m not the only one.
“Hello, because your package was returned as undeliverable, give you change the other logistics today sent to you, in the 17th website can query. This is the new tracking number:”
So I guess another 3 weeks minimum. :frowning:
Damn it. They changed lithium ion shippers.
This cell would hit 3.4+Ah minimum down to 2.5V at 0.5A - 1A, even without the protection circuit burden (≈40mV at 1A), maybe 3.5Ah at 0.5A, but 0.5A is below the 0.2C official discharge current rating. Totally l00ks like a rewrapped Sanyo NCR18650GA (go check it out with the battery comparator).
Cheers ^:)
Got the same returned and new tracking number message. The new one seems usps traceable
Finally! I had to look at a useless EKC (South Korea) website until now.
Try tracking here: https://track24.net
Hope it is of any help. In eBay fake tracking numbers are usual.
Cheers :-)
In Track24 it tells me the estimated delivery dates are between July 6 and July 26. Hopefully it won’t be that long.
I bought 26650 battery from aliexpress before, normally take 15 days…
I think mine from Ali took about 2.5 months. Very slow shipping, but at least it was free.
Just got my six 30Q delivery. Ordered through the link in the OP. The batteries have the 4 legs to the positive post, not 3 as my other 30Q cells.
Going to test voltage, then drain and then charge in a VC4 to see about capacity. Will report back with more info.
Update: All six were at 3.62V
I would no doubt open a dispute. I'd recommend choosing “product is not as described” or “counterfeit goods”. If you choose counterfeit goods and the seller doesn't cooperate you'll have to convince the AliExpress Case Management Team with proper evidence, at least like photo-comparing the cells with known good 30Q samples.
YMMV, though.
Cheers :-)
If only I coule order one without paying huge shipping costs.
Using my 20A constant current tester, it would have been easy to see if these were real Samsung 30Qs, by capacity and internal resistance.
It’s interesting that the original link now shows the 30Q cells with 3 legs, not 4 like they used to show and the version you received.
Anyway, it’s very likely you got fakes. Whether they’re still sending fakes remains to be seen.
What’s the first 3 characters of your postal code? (PM me, maybe) If shipping isn’t a lot of $, I’ll send you one of the ones I got.
The problem is that I live in Canada, so that was why the shipping costs were so abhorrent in the 1st place.
So, even if you were to ship me one, it would cost both you and me way too much.
I wouldn’t mind a reasonable shipping cost but I forgot about customs/tax on your end. Makes sense.
All I’m able to do with my equipment is discharge with a Lii-202 (using that to charge a large portable battery pack) and then charge the cells in a VC4.
Yeah, still better than nothing.
But it could be a 3000mAh cell with high internal resistance for all we know.
If someone in Canada actually took the plunge, I could check.
Do you have some power resistors?
If you can parallel some resistors to get a load of about 10A, then connect and record the voltage instantly, you could easily calculate internal resistance and compare it to HKJ’s measurement.
Send him at least a couple cells to take a peek at cell consistency.
Cheers :-)
