If each of us with a PVC light tube measured a light then sent that light, and it’s power source, to Maukka for further testing, we’d then know exactly how our measurements compare to his. But at the end of the day, don’t Fenix and NiteCore and Thrunite ALSO use that massive green integrating sphere we’ve seen pictures of in their laboratories? Aren’t their ANSI ratings determined with expensive actual testing equipment?
And it hardly matters, for what it’s worth, as it’s all relevant to actual use… after depleting cells and recharging you can’t get the same numbers again in the testing equipment, so do the “facts and figures” actually mean anything to us in real world use?
What I said was insulting was meant on the terms that a great many of us have gone to great lengths to show results, while you simply sit and speculate, that’s the insulting part, throwing all the efforts of quite a few forum members in the trash with your 20-30% high comments while you yourself have no testing equipment to prove and verify what you speculate. Put a light on the testing box and watch the numbers change, constantly. Recharge it and test it again, and again, and again, for years, you’ll find that “facts and figures” are speculative as nothing is carved in stone. Variables are the only constants.
Remember too, that ANSI ratings from manufacturers are an average of lights tested, not a specific lights actual abilities. I don’t know if they test 10 out of 1000 or what, but they average out what they see and they use whatever cells they have on hand, usually their own brand and not what we use, so once again, the variables come into play.
Does 4.9A at the emmiter seem like enough amperage to support your lumen readings?
I was trying to find a 70.2 review from someone who has good measuring equipment. I could be wrong, but I think Köf3 from TLF has a good setup. At 4.9A the raw emitter (a P2 bin 4000K) was measured at 3800 lumen at room temp 25°C, before it got heated up. Once you subtract for the reflector and lens losses, DB knows more about this than me, it’s going to be well under 3800 lumen. So your 3790 cold lumen reading does seem high to me. I don’t know how much higher, though. Also, Cree emitter binning allows for plus or minus 7%. So that’s another wrench in the works.
I think TA’s idea of sending some stable output lights to get tested in Maukka’s sphere and then using those lights as a calibration tool is a smart move. It eliminates all the factory ANSI-FL1 rating variables and gives an exact output for that exact light.
The Convoy L6 makes similar output readings using a buck driver with 2 cells. Larger head, different reflector size and shape, different glass, so again the variables and probably emitter choices that add to it. And XHP-70 vs 70.2.
The K70 with 70.2 XHP-70 emitter and buck driver has been tested at over 10A tail current and 4600+ lumens out the front, so for the TC20 to get ~3800 at 4.9 emitter amps, yeah, probably about right. Emitter binning and size of the reflector, shape and finish of the reflector, glass lens used, all comes into play of course.
That’s what I’m trying to get at though, we use the numbers to show gains when we mod a light, so we know if we’re on the right track or if something else needs to be done, getting too caught up in the numbers is counterproductive.
I am not really “upset” I am just saying that with the factory numbers that are given for their parameters I am usually pretty close on the numbers with my readings on the lumens with my meter and tube setup.
I think Dale may have mentioned that you can test the same light with the same cell 20 times in a row , with that same cell fully topped off and each and every time you take a reading it will be a little different. Even if you make sure the light and cell are at the exact same charge and the exact same temperature each time. There is always a little bit of a variation in there. I am sure you know also as the cell and emitter get used more , then they will lose performance over time.
Even with the high dollar professional equipment the factories use , I don’t know for a fact , but I feel you will still get at least a slight variation using the same light and same cell through a series of 20 test.
The light tubes that DBC , TomE , Richard and myself use , were calibrated using I think it was 25 different type and sized lights , that were from reputable manufacturers such as Fenix , Nitecore , Thrunite , Surfire and such. I wasn’t there but the way I understand it , they took the averages from all those lights that they were using and the ANSI factory listed specs from each and then got an absolute average from all those numbers to get the calibration multiplier to the correct value on these meters / light tubes.
I just feel with my meter being so close to at least 85% or more of the lights I have tested , that are straight from the factory using their listed specs , that I am getting pretty accurate results , unless the factory integrating spheres are not giving correct numbers ?
Just a little update, Newlumen did his measurements on the TA tube using a 0.7 correction factor. Texas_Ace got his measured lights back from Maukka and determined his lumen tubes need to use a 0.68 correction factor. These tubes still are only plus or minus 5% between all 30 or so of them so his TC20 measurements are still pretty accurate. Maybe they can be rounded down just a tiny bit.
Robo tested his at 1792 lumens in high, 3806 in Turbo, he found it maintained output pretty well up into 80 or 90 seconds, if I recall correctly.
Robo has a review on it with run time charts, for what that’s worth. Tested various cells in it as well.
I was looking hard at this one earlier today, decided on spending the money for components and driver boards instead, reckon I’ll build my own as there’s more challenge there. lol
My TC20 (NW) gets 2960lm on Turbo @ 30 seconds on the TA tube, using the .7 correction factor
I’m using the included Thrunite cell (fully charged) and have meticulously cleaned all contacts.
Using the same correction factor, all of the other lights I’ve tested besides this one pretty much live up to their factory specs, including some ANSI rated lights.
TBH I’ve been wondering why I’m not getting anywhere close to the advertised spec of 3800lm.
My thought was the 3800lm rating is LED lumens, Thrunite’s website does not show anything about ANSI ratings that I could find.
Figures for some popular (non ANSI) lights on the same tube using the same correction factor:
BLF Q8 (stock)…………4865lm
Sofirn C8F (stock)……2338lm
(Both tested @ 30 seconds with fully charged 30Q cells) These readings appear to be pretty much in line with the factory ratings.
At first when testing the TC20 I wondered if the tube was reading low, however the 4 ANSI rated lights I tested (Eagletac, Jetbeam, Nitecore) were nearly spot on to the factory ANSI specs.(within 4lm to 50lm)
Accurate to what? To certain other forum members results, to ANSI-FL1 rated lights or to Maukka’s Lisun integrating sphere setup?
Pics of his setup.
I don’t mean to turn this thread into a discussion about integrating sphere calibration sources, but I’m trying to show why I think TA’s lumen tubes are going to be more accurate (not perfectly accurate) than certain other tubes or spheres. For many years people have been calibrating loosely to rated specs and each other instead of to proper certified sources - generally speaking. There are some guys on TLF that have some pretty impressive setups.
TA’s tubes are still not the definitive source since the production versions are all calibrated plus or minus 5% to his original tube, but we all can’t have $10k sphere setups in our house, either.
If I started an integrating sphere/lunen tube thread, would you guys be willing to show some pictures of your setup?
I’ve got a JoshK and Texas_Ace setup so I need pics of other devices.
BTW, the JoshK sphere tends to read roughly 3% to 4% lower than TA’s Tube.
Mine , Dales , TomE and Richards are all made from 4 inch schedule 80 PVC , painted black on the outside and painted with pure white on the inside. The opening where light sits has dark grey foam cutouts of different sizes to fit different light tubes.
My meter I use with mine (the meter it was calibrated with) is a Mastech LX1330B.
No diffuser in it. Dale would probably know more than me about how the calibration was all done though , because he is friends with the one who made the tubes.
Don’t know if you been here long enough to remember “manxbuggy1” or not but he made the tubes.
Edit: one thing I didn’t point out is that these tubes are made with a 1 piece P-trap and not made with several 90’s pieced together also. I don’t know if that plays a factor or not but thought I would mention it.
