The blue display LEDs are so bright i can barely read the number. 99 looks like 88
Mine hasnt arrived yet… they shipped out on may 19th… i didnt buy an insurance so no tracking number… i am little bit concerned…
I wouldnt worry mine just came yesterday
Cool… i have a plan for this power bank… i will hook it up to my nitecore tini and light it up…
@Newlumen, don’t worry. It will come soon enough.
BTW, nice idea for using it to run a Nitecore Tini. It will run forever on a 6000mAh power bank.
@contactr, what do you mean too bright? The contrast is not lacking, unless you are viewing it on the side.
The parts of the number that are lit up are bleeding into the unlit parts so it looks like all parts of it are lit
99 (i think):
This should be emphasized. It’s not even easy to get flat tops out.
They probably did this to keep it from moving around but when you have two cells in there I basically have to bang the other end and let them come lose. A better solution would have been a bit more flex in the terminal and then maybe some foam on the battery cover side to keep them in place from that angle too.
I got my pb2 today from banggood… took 24 days… not bad…
Lcd is not bad… you need to angle little bit to read out the numbers… i have good eyes… not a problem… numbers are clear if i read it from 3 feets…
It feel good… remind me of motorola pebble cellphone texture…
Simple design… 2 usb ports…
I am using lg mj1 flat top for the extra mah…
Mine arrived in the U.S. from Banggood’s China warehouse in only 7 days. Fastest BG order I’ve ever received!
I should mention I did pay for tracking and insurance. It seems this speeds the order along.
My display is much easier to read than yours. If it’s 99, 88, or any other reading, I can make it out clearly.
Mine pb2 came from thailand. According from the package label… your?
The package label says mine came from China.
Can I use different batteries at the same time without any risks, e.g. one Sony VTC6 and one Samsung 35E or would this have a negative effect on one or both cells.
My package says shipped from China too
@FlashTom, no problem whether the cells are discharged, or charged.
For charging the cells, the PB2 has separate charging channels, meaning it is safe to charge different cells.
For discharging, the cells are in parallel, so it does not matter.
Mine hasn't come yet, but I should have read the specs before ordering it as none of my batteries will fit. I hope it makes a decent paperweight.
Wait, why none?
Unprotected flat tops work fine.
I mean none of the batteries I have personally will fit. The only unprotected batteries I own are 30Q's but they are button tops. Most of my batteries are protected.
Oh ok… flat top are cheaper!!
