Wow! A really useful & detailed review with lots of useful information & visuals. Hope you get the opportunity to review other upcoming flashlights too.
I have the Rofis MR70 since a month. Very happy with it. I use it while biking at night. The UI is great. I use the triple-click strobe occasionally for a couple of seconds too. So much brighter than a car headlight even!
The Lumintop ODF30 is similar. The cheaper cousin. It is priced well if compared to its more premium & feature rich cousin.
I note that the thermal/timed output runtimes of both are quite similar at Turbo & High.
I love this picture heavy review. Actually, flashlight review should be picture base. The picture with test images gives the clear idea about that flashlight. Lumintop has produced some quality tactical flashlights http://totalguide.org/best-tactical-flashlight. The 3500 lumens means higher brightness. I am thinking to get this one.
I recently got hold of the Rofis MR70 and the brightness factor doesn’t seem to be much different considering the near total flood the beam throws out.
The Lumintop ODF30 seems to be more brighter in the centre due to formation of a hot spot making the beam a bit throwier but sacrificing some useful floodiness… most perceptible at its high & mod nodes, rather than turbo.
Since my last post I recieved my TA Lumen tube and TA recieved some measured lights from Maukka (he has a professional integrating sphere with calibrated reference lights). So we should use a 0.68 correction factor on these tubes.
I measured my ODF30 a bit earlier using a 0.7 correction factor, but that’s still very close.
Brightness levels are roughly:
Turbo 3150
High 1500
Med 500
Low 140
Eco 5
What I’m most interested in is the turbo run time before it starts to ramp down. I got about a 1m 37s before it starts to ramp down. It’s pretty hot to hold at this point. So I’m not really sure how lock is getting two and a half minutes. Maybe yours just getting a lot hotter than mine before stepping down?
Maybe it’s battery related? I see that the black KeepPower 5200mah has quite a bit more voltage sag than the Liitokala 5000mah cyan that I’m measuring with. Maybe this increased voltage sag means it’s delivering less amperage to the emitter so it heats up a little slower?
I just received an ODF30. Really compact light! It’s somehow like a mini Convoy L6.
I still have to take it out for a night walk… but with summer solstice approaching night is coming quite late these days.
I wish it would be a more neutral white though.
anybody else problems with mode switching?
Mine sometimes hangs.. so it doesn't change modes.. I push the button and nothing happens, and after 2 or more clicks it changes modes.
I just checked my faulty one and it clicked but did not turn on. Is there a better switch that you know of? Is does other weird things such as going on turbo when turning on and then not switching out of modes etc. Seems like its a combination of things, maybe switch and driver? I want to put a NW 70.2 in there so maybe I could swap the driver if I can figure it all out.
Oh boy... That is really annoying... good to know that I'm not alone. They asked me to send it back, but that would cost me $30 for registered post... not going to do that. Also, the parts are glued, so I can't even reach the driver (plus switch)
It 'clicks' every time, it just doesn't change modes.
I took off the rubber switch button and used a piece of plastic to change modes, and after about 20 clicks it hasn't skipped a mode... so hmmm maybe something going on with the rubber boot
I have the ODF30C and still the same problems. I not sure if taking off the rubber button is going to work long term as mine still clicks when it is stubborn but still won't turn on or off or switch modes when it is playing up.
Thought everything was glued as I can't even separate the tube from the head, let alone the bezel.
You need a vice with padding to hold the battery tube. A heat gun to warm up the glue and a rubber strap wrench to get some good leverage on the head to twist it loose.
Sorry about the auto-corrected response earlier. I fixed it.
They should pay for return shipping or else just send a replacement light.
They shoot themselves in the foot by gluing it shut. Instead of sending a replacement driver (which most folks here are capable of swapping), they have to send a whole light.
I just got this light and the ODL20C. Both of the manuals say the charging LED goes from Red to Blue at completion of charging. Both of my lights slow blink Red when charging and then go solid Red when charging complete. I verified this by measuring cell voltage out of the light with my Fluke 115. Both are at about 4.18x. I even put the cells on my icharger 4010 and ensured they terminated at a 4.20 V charge at 10% termination current. Put the cells back in the lights and plugged them in and same result. Both are solid red. I left them both plugged in for an hour after turning solid red hoping for blue but no dice. I’ve never seen the Blue?
