The Convoy L6 makes similar output readings using a buck driver with 2 cells. Larger head, different reflector size and shape, different glass, so again the variables and probably emitter choices that add to it. And XHP-70 vs 70.2.
The K70 with 70.2 XHP-70 emitter and buck driver has been tested at over 10A tail current and 4600+ lumens out the front, so for the TC20 to get ~3800 at 4.9 emitter amps, yeah, probably about right. Emitter binning and size of the reflector, shape and finish of the reflector, glass lens used, all comes into play of course.
That’s what I’m trying to get at though, we use the numbers to show gains when we mod a light, so we know if we’re on the right track or if something else needs to be done, getting too caught up in the numbers is counterproductive.
I am not really “upset” I am just saying that with the factory numbers that are given for their parameters I am usually pretty close on the numbers with my readings on the lumens with my meter and tube setup.
I think Dale may have mentioned that you can test the same light with the same cell 20 times in a row , with that same cell fully topped off and each and every time you take a reading it will be a little different. Even if you make sure the light and cell are at the exact same charge and the exact same temperature each time. There is always a little bit of a variation in there. I am sure you know also as the cell and emitter get used more , then they will lose performance over time.
Even with the high dollar professional equipment the factories use , I don’t know for a fact , but I feel you will still get at least a slight variation using the same light and same cell through a series of 20 test.
The light tubes that DBC , TomE , Richard and myself use , were calibrated using I think it was 25 different type and sized lights , that were from reputable manufacturers such as Fenix , Nitecore , Thrunite , Surfire and such. I wasn’t there but the way I understand it , they took the averages from all those lights that they were using and the ANSI factory listed specs from each and then got an absolute average from all those numbers to get the calibration multiplier to the correct value on these meters / light tubes.
I just feel with my meter being so close to at least 85% or more of the lights I have tested , that are straight from the factory using their listed specs , that I am getting pretty accurate results , unless the factory integrating spheres are not giving correct numbers ?
Just a little update, Newlumen did his measurements on the TA tube using a 0.7 correction factor. Texas_Ace got his measured lights back from Maukka and determined his lumen tubes need to use a 0.68 correction factor. These tubes still are only plus or minus 5% between all 30 or so of them so his TC20 measurements are still pretty accurate. Maybe they can be rounded down just a tiny bit.
Robo tested his at 1792 lumens in high, 3806 in Turbo, he found it maintained output pretty well up into 80 or 90 seconds, if I recall correctly.
Robo has a review on it with run time charts, for what that’s worth. Tested various cells in it as well.
I was looking hard at this one earlier today, decided on spending the money for components and driver boards instead, reckon I’ll build my own as there’s more challenge there. lol
My TC20 (NW) gets 2960lm on Turbo @ 30 seconds on the TA tube, using the .7 correction factor
I’m using the included Thrunite cell (fully charged) and have meticulously cleaned all contacts.
Using the same correction factor, all of the other lights I’ve tested besides this one pretty much live up to their factory specs, including some ANSI rated lights.
TBH I’ve been wondering why I’m not getting anywhere close to the advertised spec of 3800lm.
My thought was the 3800lm rating is LED lumens, Thrunite’s website does not show anything about ANSI ratings that I could find.
Figures for some popular (non ANSI) lights on the same tube using the same correction factor:
BLF Q8 (stock)…………4865lm
Sofirn C8F (stock)……2338lm
(Both tested @ 30 seconds with fully charged 30Q cells) These readings appear to be pretty much in line with the factory ratings.
At first when testing the TC20 I wondered if the tube was reading low, however the 4 ANSI rated lights I tested (Eagletac, Jetbeam, Nitecore) were nearly spot on to the factory ANSI specs.(within 4lm to 50lm)
Accurate to what? To certain other forum members results, to ANSI-FL1 rated lights or to Maukka’s Lisun integrating sphere setup?
Pics of his setup.
I don’t mean to turn this thread into a discussion about integrating sphere calibration sources, but I’m trying to show why I think TA’s lumen tubes are going to be more accurate (not perfectly accurate) than certain other tubes or spheres. For many years people have been calibrating loosely to rated specs and each other instead of to proper certified sources - generally speaking. There are some guys on TLF that have some pretty impressive setups.
TA’s tubes are still not the definitive source since the production versions are all calibrated plus or minus 5% to his original tube, but we all can’t have $10k sphere setups in our house, either.
If I started an integrating sphere/lunen tube thread, would you guys be willing to show some pictures of your setup?
I’ve got a JoshK and Texas_Ace setup so I need pics of other devices.
BTW, the JoshK sphere tends to read roughly 3% to 4% lower than TA’s Tube.
Mine , Dales , TomE and Richards are all made from 4 inch schedule 80 PVC , painted black on the outside and painted with pure white on the inside. The opening where light sits has dark grey foam cutouts of different sizes to fit different light tubes.
My meter I use with mine (the meter it was calibrated with) is a Mastech LX1330B.
No diffuser in it. Dale would probably know more than me about how the calibration was all done though , because he is friends with the one who made the tubes.
Don’t know if you been here long enough to remember “manxbuggy1” or not but he made the tubes.
Edit: one thing I didn’t point out is that these tubes are made with a 1 piece P-trap and not made with several 90’s pieced together also. I don’t know if that plays a factor or not but thought I would mention it.
I think i might have did something wrong in my previous test… i am not sure… i will make sure the light is align with the disc… i will report back this afternoon…
I welcome this discussion here as it pertains to the TC20.
I’m not doubting the validity/accuracy of DB, Tom E and Robo’s tubes or anyone else’s, I’d just like to know why my TC20 doesn’t appear to have near the rated output.
I remember reading years ago about manxbuggy1 making those tubes and I’ve always trusted the readings posted by DB, Tom E and Robo.
Since I’m getting what appears to be proper figures for all the other lights I’ve tested, I’m thinking my TC20 may have something wrong with it. As soon as I get some time I’m going to test it further with a Lii-50A and also test the lower modes.
I am curious if Dale or Robo got similar figures to mine for these two lights? (If they have them):
