I really like xp-l HI also. They have great performance and efficiency. They have a nice clean beam when behind a carclo optic unlike the non HI variety. I expecially like something on or below the black body line like a 5A1 tint.
I think you might be right
I should have been less presumptuous
here is what I had in mind
I was responding to comments about the size of the FW3A being similar to the HDS. I think that is a very valid comparison not only in terms of dimensions, and also in terms of some of the head and tail proportions, knurling, and use of tapers to create the waistline.
I think a Titanium FW3T would be immensely popular. It prompted my search for the Titanium HDS image. The Ti Ra is an HDS Legacy Model… hence I was punning that it would add a “Legendary” feel to use a knurled waistline, that nobody wants…
(The Legend of HDS, The Light That Gets You Home)
speaking of knurling on the FW3A, I think the tail should be knurled more fully, not leave the smooth part before the switch so wide. I want to feel knurling near the edge, so I can tell the difference between the smooth head and a coarse tail, by feel, in the dark, upside down, or standing on my head…
The Ti Ra that went for $650 2 years ago, was one of 75 made in 2009, I dont know the original cost. I believe the max lumens was 170, not sure if they were High CRI
How awesome would it be to get a Ti FW3 in 2019, at budgetforum prices, And in High CRI?
Which brings me to, the XP-G3 and other LED options being considered for the FW3A
Im a maukka groupie, whatever he says is good, I generally follow
even though he does not approve of the XP-G3, I bought a light with that LED, twice. Both times I hate the Green Rainbow Tint. I really do not recommend that LED. I buy the lights for other reasons, despite the LED. It would be one of the Last LEDs I would consider, as a High CRI snob.
We just witnessed Clemence pull a bunch of sw45 9080 out of Nichias final stock… I wonder if someone could piggyback an order for the FW3T run?
I mean really, a Titanium FW3T with an sw45 9080, how bad could that be? Its no Legacy HDS but, better than a poke with a sharp stick, no?
My vote is for XPL HI for the FW3A. Preferably in a nice neutral tint like 5D.
I wouldn’t be against Lumintop making different versions for people with other tastes though. Perhaps an XPG2 version for those who want the cheapest possible light. And maybe a 219C version for high-CRI fans.
I’m not impressed with the LH351D. Way too floody.
I’m a big fan of LH351D.
I think it would be a superb choice for those of us who want pure flooders.
For more general-purpose uses - it just doesn’t look like a good option in optic this small.
If this light is to be produced with one LED option - I recommend against LH351D.
Shaving the LED would largely fix that, at the cost of reduced efficiency (but still quite good). The light would definitely still be a flooder, but useful to more people.
And mass-shaving LEDs doesn’t seem to be a costly operation. Shaved LH351D should cost less than stock XP-L HI.
Please put your forum username in the “email” box. If there is a tie, it may be broken by removing anonymous votes.
……………………………Price Lumens Throwiness CRI Beam Heat
For price and heat, lower values are better. For everything else, higher values are better.
Throwiness is a rough measure of candelas per lumen. It’s the overall beam shape. Even the throwiest option is not a thrower, because compact triples are floody by nature.
“Beam” is the overall beam quality, like smoothness and color consistency.
More peppers makes thermal management harder, reduces the sustainable brightness after step-down, and increases risk of damaging the emitters on turbo.
Worst part about each:
XP-L HI: Costs more.
XP-G3: Strongest “Cree Rainbow” effect: angle-based tint shift, green around hotspot.
XP-G2: Lowest output. Old.
219c: Most heat, lowest sustainable output, highest chance of damaging itself on turbo.
LH351D: Super floody. May be a bit green at low levels.
Values only indicate approximate performance in a Carclo 10511 optic using a FET for direct drive on 1x18650. These have not been directly tested in the FW3A host, so this data is more of an educated guess than a measurement.
Votes will be counting with the Schulze Condorcet method.
@TK……
Is this something we are supposed to be voting on or has that already taken place??
I just looked that up, 5D is just below 4000K?
I suspect most people would consider that quite warm, to me it would look muddy orange, 4C is too warm for me, 3D just about perfect.
Mood lighting has its place, but this is an EDC light, built for practical function.
I know there will be differing opinions and perceptions, but if I am not mistaken several polls and discussions have shown 5000 is around the middle of what the BLF majority want in an EDC. A6 neutral and Q8 are both around that mark I believe, and look great.
The poll is not active yet. I’m waiting until TLF is back online so everyone can participate. It’ll be run on the same site I used for the muggle mode poll, where people rank their preferences in order.
Until then, I’ve been trying to make sure the comparison table is accurate, so I put a preview online to get feedback.
I believe LH351D 70+ deserves to be listed just like CRI 90+. Frankly, I have no idea why with this particular emitter so few people are interested in lower CRIs…
I totally agree & IIRC your statements are correct also about pteferences. I am hoping for at least 5000K Zulumoose. A bit more is fine too…. but at least 5000K. Hopefully below the BBL too.
I am good with 2D or 3D. 3A is perfect.
. EDIT:@Zulumoose…. Here is one of the Polls you mentioned.
Considering the intention is to have TIR optics, how much difference will the “throwiness” of the LED actually make?
Won’t the lens produce a similar result regardless?
Are there different triple TIR optics out there that would allow for different beam patterns, like with a single emitter TIR?
I would like to see xpl-hi’s in the 4000k range. But in any case whatever in ends up with,if its not too late, please put me down for 2. Thank you for everyone working on this!
Steve
Yes, with Carclo you can choose smooth or frosted finish. And cups that shape the beam to different beams.
Though really the only options that make sense is the narrowest cups with clear or frosted.
I’m aware of 1 other 3-up 20 mm lens, it’s from Kaidomain. I think it’s clear only and has slightly different hole spacing.
If the throw of the Samsung LEDs were an issue could we not just as for the narrow clear optic instead of the narrow frosted? I’m putting the floodiest optic I can find it it regardless.
