I could not resist the price MT07S HI
When it happens, I will make measurements and add photos to the collection.
So in the near future the collection will be bigger by D4 (Black, XP-G2) and MT07S (Black, XHP35HI)
Emisar D4 from XP-G2 5000K joined my collection. Interesting flashlight, UI great, performance could be better (anodizing) but not bad. The peculiar fact that the same LEDs as in the Meteor M43 are slightly warmer. Accurate measurements indicated that the M43 has 4810K and the Emisar D4 4645K.
Meteor:
Emisar:
The flashlight has an error and with a standard temperature threshold setting, it flashes from time to time. I changed the threshold to over 60 degrees Celsius and now is the super. Nothing blinks and the turbo goes down after 110 seconds. The infrared temperature meter showed 61 degrees. I like the torch and stay with me.
In the meantime, I decided to replace the LED in TC20. I could not look at those yellows at 70.2 anymore. A massacre, I hate this LED. I decided to change to MT-G2. Of course, it was not without adventures. During tests, I accidentally made a short circuit and flew a resistor and a transistor with smoke. Of course, I did not give up, the transistor is not there so I do not have the moon mode but I’ve chosen the resistor accordingly and the new LED gives fire. I got on the tail 8.6A at 4.15V. In the evening, I will take measurements and add some photos.
There is no centering plate because there is no need.
… The most important color. Ah, there is nothing to compare, pure white without additional shades. I have the impression that the beam of light is more focused. Measurements will tell the truth, but later. I really like TC20 now.
Measurements done.
TC20 with MT-G2 reached 2602 lumens. Coverage fell from 273 meters to 243 meters. It does not matter to me because the quality of lighting is worth it. In high mode there are 1230 lumens. I’m very happy.
I forgot to add that the driver in TC20 is really strong. I released 18A at 4V and survived it and LED.
I have an ordinary 70.2 shaved and it is yellow for pain. I was looking for 5000K with a high CRI but no one is on sale. At the moment TC20 with MT-G2 satisfies me 100%.
But it will happen …
He is waiting for the arrival of three new flashlights and as I will compare and measure them. These will be MT07S HI, Catapult V6 and GT Mini. For comparison, I will add UT02 after modifications after which it reached over 1,700 lumens. Of course, all versions are NW.
Nice set up. At least you have high powered lights, None of the store bought stuff. I have stock UT02. What do I need to ramp it up to your lumen count because throw distance is pretty good.
Mind I ask what you used to pop the driver off the head? I tried using with a angled punch but can’t pop it off. Didn’t want to force coz I’m afraid to break something in there. Thanks
