ALIVE: Haikelite MT07S only US$46.72
I guess I would still need a D shackle to fix the thick green end to the screwed mounting.
I wouldn’t hang this flashlight on my belt because my trousers would fall down!!
The other thin black string end of lanyard probably wouldn’t last too long on the back end of flashlight before snapping.
This lanyard looks more like the type used on a lightweight compact camera.
At the end of the day, we all got a great flashlight for a bloody good price.
To keep their costs down they obviously throw in a cheap lanyard.
I’m not too worried about this and might look for a more robust strap (flat nylon similar to a dog leash).
I’m sure I will find something for a few bucks.
I had to replace flimsy straps on a back pack once and used heavy duty dog leash from eBay.
Works better than the original.
Umcookies,
Yes, you are correct, the thick double Paracord braided handle is prefitted to a beefy threaded D-ring that fits the well machined tripod mount hole on the body. It's pretty flipping fantastic IMHO.
** LANYARDGATE UPDATE
My MT07S XHP35 NW White arrived today... quite impressed with the light!
Exactly as advertised, the super-deluxe braided Paracord handle that also came with my MT09R accompanied this light, but amazingly at the SAME time the closure bolt for the D-ring assembly on the MT09R loosened itself and disappeared while changing batteries. So between the 2, one handle is useable....
i am more than suitably impressed with the lights performance, especially battery runtime. Throw is excellent, with a fairly even, though moderate corona surrounding a very intense small center spot. One thing gnaws at me, the reflector has what looks like a hazey residue on it, a QC fault in manufacturing. Its impact on actual performance is negligible, however, aesthetically it does detract significantly from the rest of the light which reflects top flight machining and finishing. I’d rather have a perfectly clear smooth reflector and a throwaway lanyard, however.
Id like to see if Haikelite will address the reflector issue. I’d prefer they just send a new part, since shipping the thing is just crazy.
For the discounted price, this light is a stellar bargain, and I highly recommend it.
final notes: I like the straightforward UI, but HL could really stand to upgrade the power “button”, it seems flimsy compared to the robustness of the rest of the light.
Good Lux!
PS MANY THANKS M4D M4X for your work and making this possible
I wonder if it’s possible that only the 35 version is supplied with the braided paracord handle. Only the 35 version is pictured with this on Banggood’s site, and perhaps to compensate for the fact that the 35 is a cheaper emitter than the 70, although both versions have the same price.
Any idea how many Lux this 35 ?
But mine is the XHP35 HI version, and it didn’t come with it.
BG is asking me to wait, and it has been days and they still haven’t came back to me.
I will email them again today.
:+1: Then it appears random.
HAIKElight spec for XHP35 = 360KCD Lux
RANGE 1200 Meters
Any other XHP35 owners have the reflector haze issue ?
HiKARInoob,
The braided Paracord handle is the nicest type I've seen and really works/fits well with the bulk of the light. BTW What is the condition of your reflector? Who did you email about the lanyard? I would like a new reflector....
Most likely not going to happen. Although I’ve only read one measurement I think it’s more realistic to think of throw of ~200 kcd.
I just briefly checked the condition of my reflectors of my MT07S lights and they looked fine. However, I’ve never really looked closely as I’m easily satisfied I think when it comes to reflector quality.
I didn’t email anyone regarding the lanyard as I’m not going to use it.
I have a NW and a CW XHP35 now and both have no reflector haze
Both came with the green paracord lanyard and only 1 of them had the metal tripod mount claw screw thing
Performance of both is very good
Thanks, Itsme !
i won the lanyard lottery and bought the farm on the reflector. It’s very minor, I’m nit picking but side by side with my 70.2 MT09R comparison (which has strikingly good reflectors) I expected better...
...then again at one third the price I’m not going to complain and it doesn’t negatively affect anything except light instruments, like 3% or so....
i still can safely recommend HK products overall
Just came in the mail today and I Love it :beer:
Thank You so much M4D M4X you are the Man :beer:
I ordered the black XHP35 HI Upgrade version and it was a steal. I will surely use this light the most. Fits in your hand perfectly, has a great UI, Beefy Lanyard and mount. Great on the road light, I drive 2hrs to work every day, just need to find a zip case to keep it in my lunch tote. You guys are going to like this one. :beer:
good to read such happy comments
:beer:
Can u check if the driver is regulated?
I know 70.2 version have full regulation
Yes, the driver has full digital regulation and can manually override the high temp stepdown
Not really necessary bc the heatsinking is so well on done I have run mine on turbo nearly continuously, the XHP35 HI version. Righteously overbuilt.
I have the NW XHP35 Version and also have to mention the neutral white is fantastic; I LOVE it !
Anyone know the exact spec (cct) of this LED ??
My guess is 4500-5000K, but I'd like to know exactly.
4800k 80CRI.
For some reason, every NW white versions of their lights, even for the MT09R, use 80CRI LEDs.
The MT01 uses a great 4800k 80CRI XHP50.2, the MT07S uses a 4800k 80CRI XHP 70.2 and XHP35HI 4800k 80CRI, and even the MT09R uses 5500k XHP70.2 80CRI.
Even the SC01 uses an XHP35HI 80CRI.
Thanks millions, BlueSwordM !!
I have a CW 70.2 MT09R and am having TA work his magic with. The Cool White is waaay too blue for me, and now I know the right spec for it's replacements.
The 80CRI is key. I'm a high CRI kinda cat after all. Higher than 70s, anyhow. I really notice the color rendering subtleties.
Cheers !!
