G _ _ _ _ L _ _ _
Good_Luck?
:laughing: nope
Anyone are welcome to try the quiz EXCEPT Djozz and Zak
BTW, I already mentioned different soldering pad. I suppose there’s another difference? Or maybe this one, but you worded it differently?
No, the 119D and 119C have the same foot print. This is another obvious difference
G L A S S L E N S
I’m really hoping that this is not another typo. If this is the case then dedoming this LED would be the easiest and cleanest dedoming job with less lumen loss as usual. The idea of using multi refractive index material was introduced three years ago by a chinese scientist. He demonstrated more than 21% output using the same die. He used 5 layers silicone from the high to low to slowly reduce the RI transition to extract more photons off the die.
- Clemence
You mean the difference between 119C and 119D? I haven’t seen that comparison in the posts above (or 119C being mentioned at all).
I thought the question was what’s new in 119D/219D over 119C/219C. But yes, 119 package is better thermally compared to 219 package on two pads board like my VR16S1. Larger thermal pad area
And probably somewhat higher current handling too
- Clemence
We’ve had a bit of confusion.
But yes, your find is very interesting.
I could be wrong. If the configuration is like this: die - glass - phosphors embedded silicone, then its a total disaster. Dedoming would remove most all of the phosphor and leave us a big royal blue LED!
- Clemence
I’m surprised that 119 without dedicated thermal pad is better than 219…
You can use the webplotdigitizer to check the total surface area between 119 and 219 package. But high performance non DTP MCPCB or non isolated MCPCB must be used.
- Clemence
Another improvement in 119/219D is its thermally more stable. From –30C to 25C the output remains almost the same. Less output reduction in higher temperature too.
- Clemence
Happy surgery!
UPDATE 180702:
Full range CCT (2700K, 3000K, 3500K, 4000K, 5000K, 6500K) Optisolis added to the store. All 3 steps MacAdam.
The VR21P4 (Optisolis/757 series only) and VR21SP4 (E21A only) already shipped to Indonesia today.
- Clemence
New Products:
VR21P4 (parallel only, 757/Optisolis only)
- The closest performance to DTP copper MCPCB.
- 1 Oz copper
- Diameter = 21mm
- Thickness = 1,5mm
- Compatible with Carclo 106xx
- Almost invisible (from afar and when lit) yellow marking for enhanced aesthetic
- Special solder footprint dimensions for precise LED positioning. Very easy to solder with DIY techniques. No more overflow solder - bumps which can impede optic placement.
NOTE:
Ignore those erroneous guide boxes, they won’t affect the board/soldering performance. The LEDs self align perfectly.
This board is sure overkill for 757 LED family, the board thermal resistance is much lower than the LED thermal resistance itself. But with some scrapings here and there this board can be used for other high power (2 pads) LEDs as well.
NF2L757GT-F1 sm273 P9 Rfh00
VR21SP4 (larger version of VR16SP4)
!P7080621_DxO by Clemence Ronald, on Flickr!
New features:
- 1 Oz. copper
- Tighter LEDs spacings at 0,3mm
- Smooth backside
- 2,5mm holes can be tapped for M3x0,5 screws for alternate mounting options with thin heat sink plate.
- Diameter = 21mm
- Thickness = 2mm
- Clemence
