Here comes A1, an EDC thrower slightly larger than Emisar D1.
Reflector has exactly the same dimensions as Phoenix ElectroformsPA19.01, so for the big budget users there’s an easy upgrade path.
PA19.01 costs $45 when buying 1 piece or $35 when buying 100. So manufacturer could offer it together with UCL2-class window as a $50 option. Expensive…but I’m sure there would be buyers willing to pay so much for ~15% higher performance.
5 LED choices:
* Osram Q8WP driven to 7A
* 990 lm, 130 kcd with cheap optics
* 1100 lm, 150 kcd with upgraded optics
dedomed Samsung LH351D for those wanting higher output (or warm or neutral or high CRI…)
With Samsung INR21700-30T or Samsung INR21700-48G (LED driven to 6A):
1200 lm, 73 kcd with cheap optics
1400 lm, 82 kcd with upgraded optics
With Aspire 18350 (LED driven to 5.5A):
1200 lm, 75 kcd with cheap optics
1300 lm, 85 kcd with upgraded optics
stock Samsung LH351D for those wanting even higher output
1500 lm, 50 kcd with cheap optics
1600 lm, 57 kcd with upgraded optics
1400 lm, 48 kcd with cheap optics
1500 lm, 54 kcd with upgraded optics
Cree XP-L HI
With Samsung INR21700-30T (LED driven to 5.75A):
1200 lm, 91 kcd with cheap optics
1300 lm, 100 kcd with upgraded optics
With Samsung INR21700-48G (LED driven to 5A):
1100 lm, 85 kcd with cheap optics
1200 lm, 95 kcd with upgraded optics
With Aspire 18350 (LED driven to 4.75A):
1100 lm, 82 kcd with cheap optics
1200 lm, 92 kcd with upgraded optics
Dedomed Luminus SST-40 driven to 8A
1400 lm, 100 kcd with cheap optics
1500 lm, 110 kcd with upgraded optics
Note: there are no technical reasons not to include CRI80/90 LEDs, I just didn’t bother with performance analysis
A1S (A1 Supersized) is a compact thrower, a bit larger than C8, about the size of Emisar D1S.
Reflector has exactly the same dimensions as Phoenix Electroforms PA11, cut down to remove the rim from the front. Such compatibility enables upgrade.
Phoenix confirmed to me the possibility of cutting the reflector, but didn’t provide me with pricing information, so I have no idea if it’s feasible for the manufacturer to offer such options. I it’s not feasible, I think it would make sense to increase the reflector size to 50 mm outer diameter.
There are many lenses with 50 mm diameter and so other A*S lights would probably use them. Upsizing A1S like that would be better for family uniformity.
Not very hot, some variants should be able to sustain its output until battery runs out.
parts sharing: it can use exactly the same driver board as A1
offered with the following LEDs:
990 lm, 220 kcd with cheap optics
1100 lm, 250 kcd with upgraded optics
1200 lm, 120 kcd with cheap optics
1400 lm, 140 kcd with upgraded optics
1200 lm, 130 kcd with cheap optics
1300 lm, 140 kcd with upgraded optics
1500 lm, 84 kcd with cheap optics
1600 lm, 95 kcd with upgraded optics
1400 lm, 80 kcd with cheap optics
1600 lm, 90 kcd with upgraded optics
Cree XP-L HI
1200 lm, 150 kcd with cheap optics
1300 lm, 170 kcd with upgraded optics
1100 lm, 140 kcd with cheap optics
1200 lm, 160 kcd with upgraded optics
1200 lm, 150 kcd with upgraded optics
1400 lm, 170 kcd with cheap optics
1500 lm, 190 kcd with upgraded optics
Luminus CFT-90
just kidding
On the drawing you can see it together with Convoy C8 and Emisar D1S
A4S is a high-output light with 4 LEDs and a deep reflector. The reflector has the diameter of the A1S-one.
LEDs:
Osram Q8WP LED
4400 lm, 200 kcd with Samsung INR21700-30T with 28A drawn from the battery
hot-rod overheating in mere seconds
needs the 28A to be regulated because Samsung INR21700-30T will overdrive the LEDs, maybe even kill them
is it possible for this driver to regulate 28A for several seconds?
not brighter than Q8WP, but much more efficient. High sustained performance
4400 lm, 96 kcd with Samsung INR21700-30T with 19A drawn from the battery
3600 lm, 79 kcd with Samsung INR21700-48G with 13A drawn from the battery
3000 lm, 65 kcd with Aspire 18350 with 10A drawn from the battery
the most efficient variat, but sacrifices throw
5300 lm, 61 kcd with Samsung INR21700-30T with 19A drawn from the battery
4400 lm, 50 kcd with Samsung INR21700-48G with 13A drawn from the battery
3600 lm, 41 kcd with Aspire 18350 with 10A drawn from the battery
dedomed Luminus SST-40
5200 lm, 130 kcd with Samsung INR21700-30T with 25A drawn from the battery
4300 lm, 110 kcd with Samsung INR21700-48G with 19A drawn from the battery
stock Luminus SST-40
6300 lm, 68 kcd with Samsung INR21700-30T with 25A drawn from the battery
5200 lm, 56 kcd with Samsung INR21700-48G with 19A drawn from the battery
On the drawing you can see it together with Sofirn C8F
Note: there are no technical reasons not to include CRI80/90 LH351D, I just didn’t bother with performance analysis
Alternative:
There are many lenses with 50 mm diameter and so other A*S lights would probably use them. Upsizing A4S to get the same head diameter would be better for family uniformity.
I can see the A-architecture applied to several more lights.
1. Zoomie
I definitely think it makes sense to make an A-zoomie. Or several. In fact I have some drawings in the works.
2. A7S
Larger hot rod? Why not? I didn’t draw one, but if there’s interest - I may. Quick and dirty: 39A current draw with Q8WP for 6600 lm and 170 kcd. With SST-40 9000 lm at 34A.
3. Headlamp
does anyone need a hot-rod headlamp?
with different drivers (and 6V LEDs) efficiency can be better leading to longer runtime and higher sustained performance
though with higher price and lower peak performance
I’m not convinced 21700 is great choice for a headlamp - 18650 is already bulky enough. But I have a hunch that there are people who disagree…
the market for 18350 headlamps certainly looks underserved. A-family headlamp could go there.
headlamp-powerbank doesn’t seem like a bad idea
4. Lantern
does anyone need a hot-rod lantern?
21700 seems like a nice choice for a lantern. Not picked by anyone of the market yet, but that is likely to change soon.
a diffuser on top of A3 / A7 would give 70% quality for 5% price and 5% weight (for someone who has A3 or A7 already)
A3 and A7 have different head diameters, so diffusers would have to be different
5. Mule
Technically there are no problems. Regardless of how large it should be. Could even re-use all components except for the body.
But is there enough interest?
Personally not really a fan of all those designs.
I only like tube lights.
If I can fit a flashlight with a bigger diameter head in my pocket, then it would make no difference if the whole light was that diameter.
Even a 26650 light can easily be gripped in one hand so the only reason to have a non-tube light is if you need a head bigger than like 40mm.
Stuff like USB C charging, long throw / high cri / high efficiency LED options, LED and driver on same board for compactness, are all great ideas.
Also, even though getting high numbers is cool for marketing, it’s pretty much useless for a regularly used or EDC flashlight.
Having long battery life, stable output, no drop down or FET or direct drive, is what really matters.
The longest runtime would be using a shockli 26650 5500mAh cell.
The longest runtime while minimizing mass and size is a samsung 18650 35E.
Maybe in the future 21700 cells will get better but currently the highest capacity one is the samsung 48G which is slightly worse in wh/kg and wh/L than the 18650, but it is still very close (a lot closer than the best 26650) so if you need more capacity it’s definitely the best option.
I don’t think anything below 18650 is worthwhile even considering, having looked at the wh/kg and wh/L of the best 16340, 18650, and 14500s.
What do you consider a regulated output level in a 18650 tube light that is sustainable to be? I know it is variable to the need but just wondering what a moderate level is approximately. 5-600 lumens?
Well it really depends on LED efficiency, if you have multiple LEDs running at a low current each (getting high lm/W) then you should be able to get both high output and long regulated runtime out of an 18650.
I’m not sure if it would be 500, 1000, or more lumens, that would require some calculations to be done.
If BLFers in general would like A-lights with 26650, that could be changed easily.
Personally I EDC lights in a backpack, so for me weight and overall volume are more important than any individual dimension. Larger head doesn’t add much to volume, but can nicely improve performance.
BTW I may draw a near-tube A-light later, still with 21700. I’m not sure, that may be applicable to more lights, but not having actual driver design I was pretty conservative with sizing. But aspheric zoomie should be doable.
Removing powerbank would help as well. That may be a good light, but not an A-light.
It may be useless for you, but is not in general.
I love my D4 and use its Turbo a lot.
On low currents, LG H30 or Acebeam “5100 mAh” (which uses a cell I failed to identify) are the highest capacity 21700. For moderate currents that may be either 48G or Acebeam.
There are uses where Wh/l and Wh/g are meaningless. That is - when you have enough energy. Beyond that every size increase is a waste, regardless of how it improves power density. Personally I love 18350 - runtime is good enough for my EDC, the best cell has good IR and it’s significantly smaller and lighter than 18650. Even DQG Tiny 18650.
Powerbank function may be an excuse for some to go up with the cell size from what they use now.
For others - recharging that comes with it may be a good reason to go down.
I’m a huge efficiency geek. But sometimes less efficient solutions are simply better.
I’m sure if they removed turbo mode and made ‘high’ the new turbo you wouldn’t notice a difference.
The difference between high and turbo is not very noticeable after the first few seconds.
Do you have any reliable tests for those cells? Hopefully you’re not going off of the numbers that the manufacturer claims.
[quote=Agro]
That’s true, but for most people you don’t choose a runtime and then pick a light which is the smallest size.
You do the opposite, pick a size limit that you are willing to EDC, and then find the best battery for that size light.
As far as I can tell, 18650 is a pretty popular EDC size.
Also, it doesn’t make a lot of sense to go with just “enough” runtime when you could increase the size of the light by like 30% more and get 400% more runtime.
AAA is also a pretty popular EDC size. Different people-different needs.
I disagree. By “enough” I mean “it never runs out before I can recharge”. 400% of “never ends” is still “never ends”. 130% of something is 130% of something.
I could spend that 1-2% to insure for the case that never happened, but may in the future. But not more than that.
I think multi-LED is the future of flashlights, BUT along with a powerful boost driver. The era of DIY FET driven lights being more powerful than productions lights with boost driver is coming to an end. One of my favorite lights is the Sofirn C8F, and the only way to improve it is with a boost driver so it gets flat regulation.
Linear drivers are appealing for some people but for me it is dumb to burn excess power, might as well just drive the LED harder.
Hell you shoulda heard the gruff I got for pushing the need for better boost drivers in this NiMH thread. Inefficient this inefficient that. But whaddya expect when maximizing output from a stinky little AA Eneloop? A perpetual motion machine? :laughing:
I mean they’re inefficient in distinct ways yes but they’re not THAT inefficient considering linear driver excess power waste thru heat.
Anyway, I believe there’s serious progress yet to go on them too.
I’m a huge efficiency geek. Especially in powerful lights - because then efficiency improves not just runtime but also sustained performance.
I’ve been a big fan of buck, boost, buck-boost drivers.
I’ve been a huge fan of XHP35 HI.
It was hard for me to pick a lower efficiency option….but I believe that for A-lights it just just better.
Why?
Linear drivers use fewer components…and smaller ones
Driving even a single XHP35 to the max requires a large inductor, interfering with optics
the sheer amount of board space required is large…A1S should be possible, A4S - maybe, but the smaller variant surely not
Cost
Buck, boost drivers are costly, especially the high powered ones
Quad LED MCPCBs are perfect for compact lights, and running an LED at low currents get extremely high efficiency, so a quad light could get like 200lm/W and still put out hundreds of usable lumens.
I wonder what the most efficient driver for running 3v leds is, either linear or some sort of 1S buck driver that takes 4.2V down to ~3v?
Nichia 219Cs aren’t the most efficient LEDs but you can get over 200lm/W at like 2.8v so that the flashlight could have 500lm regulated output literally until the battery runs out.
Boost drivers are just bad if you care about efficiency, especially if it’s a 12V LED.
For a 6V led it wouldn’t be so bad, as long as you don’t draw much current.
We’re a bit off the topic, but…
I’ve seen one claim of a light making 200 lm/W. This was from Lux-RC.
Say that one wants to repeat this feat with a quad…
What are the losses? With a shallow MgF2 coated aluminum reflector and UCL2 lens you get 95% efficiency. Not including losses on bezel, washer, centring ring. So maybe real 93% is achievable. With cheap reflector that’s more like 88, with a clear TIR (and no protective lens) I would expect up to 90.
What kind of efficiency can you get with a buck driver? Let’s be optimistic and say 99. So to get 200 lm/W OTF you need 220-230 lm/W at the LED. Samsung LH351D can does 150 lm with 220 lm/W and 100 lm with 240 lm/W. So a quad TIR with 99 efficient buck driver could do about 500 lm with 200 lm/W.
If we drop driver efficiency to 95% which I think is realistic, that’s more like 430 lm.
With linear driver, efficiency wouldn’t be good, in the same setup it would be about 78% efficient because at such low currents Vf gets very low.
BTW 12V boost drivers can’t be so bad. It must be possible to make an efficient one. I say so because I observe that nothing gets close to Zebras for sustained output in their size class. Even multi-emitter lights.
And AFAIK Lux-RC does boost too. To 9V.
Running the LEDs at low currents for high lm/W and using high quality optics isn’t a problem, that’s easy to test and sort out.
We just need to figure out which drivers we can use to get high efficiency while the battery voltage is far above the LED voltage, such that it can stay in regulation.
If the battery is fully charged at 4.2, and an LED is running at ~200lm/W at 2.7V, that’s a 1.5v delta.
Maybe we need more people to do driver tests :question:
