WAVIEN collars are BACK! Are you interested? [group buy over]
How about having half-sphere pieces of glass properly crafted and sliced, then outside spray painted with mirror effect spray LoL?
Cheers ^:)
That is a special arrangement you made! :+1:
I would buy one, and probably also a quality 50mm lens, but I would have to know the focal length and if the lens has a small rim to clamp it behind a bezel (and if the 50mm is measured with or without the rim). And the price must be reasonable of course.
Blf GT with A037 lens and this wavien collar is a good combo ?
Stock led & driver will give >2mcd ?
Αmen George,amen. :slight_smile:
XHP35 Hi with its shiny surface may not be optimal, an oldschool dedomed XM-L2 or XP-G2 may show a better ‘wavien’ effect (and throw further anyway).
Dedomed sst-40 could be a nice option then…
Possibly. I have not followed it well but has anyone measured the increase of throw of a dedomed SST-40 as opposed to one with dome on, and compared that to the throw increase of a XM-L2 ? Is it just as good? In other words: how good is the photon recycling effect in the SST-40? (the wavien collar uses the same effect).
I would buy two and - same conditions as Djozz - a quality 50mm lens as well.
Would be excellent if thi came through!
Cheers,
Nico
Great Enderman, thanks for doing this! I want one, maybe two if the price goes down.
I have a few questions regarding lenses and the collar:
What f-number should a Lens have for optimal performance (meaning it collects all of the light and there is no wasted lens diameter)?
I want to put the smallest possible lens on top of a small sized collar. It should be possible to glue it directly on top if the diameter is just slightly larger or if the lens has a rim?
Thanks for arranging this! I would take one.
Some interesting reading there. Thank you :+1:
I should have known someone on here would have thought of it before me :slight_smile:
Very true!
The mirror needs to be first surface, aka on the inside of the sphere, otherwise the glass will refract light and not just reflect.
I assume it’s about F1, they said it’s high precision quality and won’t be that cheap either, but no idea about the price.
I can ask about the dimensions and if it has a rim and all that stuff.
Yeah for sure!
Marinebeam said that the 60 degree output is perfectly suited for F1 lenses, numerical aperture = 0.5 Numerical aperture - Wikipedia
I prefer to think of it this way:
“the ratio of the (back) focal length f to the diameter of the entrance pupil D:
N=f/D”
I actually also really want a compact EDC flashlight with a wavien collar :stuck_out_tongue:
Since the collar is 32mm OD the smallest lens I would go with is also 32mm, since going smaller wouldn’t reduce the size of the light any more.
That are good news! 2 pcs for me!
Any estimates on how this Ahorton lems would perform?
https://www.illumn.com/ahorton-27-2mm-aspheric-glass-lens.html
I’m in for one. When I bought my last one from Wavien, it was closer to $90 for the sample. $50 is a steal. Thanks for setting this up!
:slight_smile: :+1:
I’ll email them on monday with how many people are interested and then hopefully get us a link to buy.
I voted earlier for one or two collars and eventually lens - depending on the price.
I’m in for maybe 2
I’m in for three, just brought a marine torch for $150 to get Waivien so yeah…
