Stick with the 30Qs for the Q8, as they work very well.
If the light itself has LVP, why not? Nb: some lights just warn of low-voltage, but don’t turn off, so make sure of that first.
Cheap chargers might at worst shorten the life of the cell if it overcharges, but don’t expect it to burst into flames or anything.
Not really. I’m not paranoid about Li-cell safety, just practical, but I still use laptop pulls that are half their rated cap, or less, and never had an issue.
2. Slicing the Xpl2 5000K with a razorblade gives the exact beam pattern of the XPL hi, but it reduces output dramatically (30% or so) the 5000 K shifted to approx 3700 K
Recent update from Windows 10 (Friday June 8th) bricked my laptop keyboard and touch pad drivers… now I’m stuck using the touch screen keyboard…
Here’s how it went:
10;30 pm while watching shows on Netflix with the kids, the windows update popped and ask for install and restart now or later… i chose restart later… finished Netflix, got too tired, went to sleep (closed the folded the screen down)… woke up to check email at 8am Saturday… no Windows log-in screen… no cursor on screen… keyboard keys and touchpad all unresponsive… had to log in with touchscreen keyboard (sucks crazy) and connect an external usb mouse… i checked the hardware drivers and it has issues… keyboard driver (ps/2 keyboard driver) has a code 10 issue and touch pad pointing device has a code 39 issue…
i have a Lenovo Flex 2-15…
tried uninstalling both drivers and rebooting several times to no avail… yes i tried rolling back the drivers, too… holding off on widows restore as a last resort…
Anybody have these issues, if so how did you fix?
Naw, the damned thing kept ruining a work laptop, killing wifi completely. Know what a laptop is without wifi? A brick.
Kept rolling back, uninstalling drivers, etc., and that eventually got wifi working again, but slooooooowly. To finally stop its insistent attempts, I found the dir where it starts dumping new files in preparation for mangling the OS beyond recognition, ‘windows10upgrade’ or some crap like that, created a file with that name, and turned off all attributes, especially admin, to make it untouchable.
For a while I’d get popup boxes citing an “error”, as in not being able to create or write-to the dir, and it made me feel good. It eventually stopped trying.
“LightUpTheDark” If you can get to the ” system Restore ” do that first. If that works, disconnect the internet immediately, find the Windows update and turn it off, reconnect the internet. You need to have a restore point saved when you are done and you need to be prepared in advance for those PITA updates.
I did the restore to a previous point via Lenovo’s (or maybe windows 10 safe mode via delete/F2 during startup) and restored to Thursday June 7 restore point and it fixed everything…
After windows reloaded with working hardware keyboard again, created a new restore point…
Or do, as I do, and only use Windows for gaming, and use Lubuntu for everything else, except for Excel too.
Lubuntu, compared to even Windows on an SSD, is crazy fast. It boots in like 2 seconds, and there isn’t any lag in the system, unlike Windows sometimes.
You could turn it off, disable it, delete the .exe, turn on “metered access”, all the usual tricks, and it’ll STILL come back to bite you when you least want it to.
