Copper S2+ limited edition
Might also point out that a full copper light heats up everywhere, get’s hotter in your hands AND heat’s up the cell inside a lot faster. Not necessarily a good thing, in some ways…
Edit: Not trying to be critical in any way, honestly, but I’ve built almost as many lights as led4power has posts in this forum! For the most part, extreme hot rods every one. Wow, how the time flies!
You’re right, I used the light’s volume instead of its surface area when estimating the radiated heat :person_facepalming:
I would’ve guessed for sure that convection and conduction do way more to transfer heat away. But of course it would be boring if I didn’t learn anything while being here :slight_smile:
Like I said, scour it under running water, before it gets the chance to oxidise (which happens almost instantly). It’ll be a salmon pink. Within seconds of exposure to air, it’ll have already turned that characteristic “copper color”.
It passivates almost instantly, so cutting it on a lathe, scouring it with steel wool, anything in air, and you’ll never see it in all its pink glory.
Take a slab of pc board, a Cu-bottom pan, etc., and try it.
So if something Cu is pickled and immediately coated, it can be a nice pink color.
“Within seconds…”
So when it’s spinning on the lathe and you’re cutting off the oxidized layer and watching the true nature of the metal spin around, you see it immediately, before air gets to it, under the oil, orange.
Reaction (and color-change) is almost immediate.
Maybe tinged by oil, maybe at higher heat, etc., sure, I’ll believe you when you say that’s what you see, but just try what I suggested. Take a rather large flat(ish) piece of Cu, and under running water give it a good scour. It’ll be a bright salmon-pink. I’ve seen this. As soon as you stop scouring, even under water, it’ll start turning orangey. That’s how fast the oxidation is.
Again, don’t take my word for it; try it.
Just for s&g…
“Copper just above its melting point keeps its pink color when enough light (the camera’s flash in this case) outshines the orange incandescence color.”
Hmm, and
“What you describe as pink is the actual colour of copper. The colour of a clean, solid surface of high-purity copper is typically salmon red. In your case, the appearance may be further affected by the particle size of the precipitate.”
Just sayin’…
Doesn’t convection have a bigger impact on cooling than radiation? Certainly with a slight breeze it would, but even with still air it must have a pretty big effect. Anyone know the actual number?
Convection is dominant part of cooling, otherwise flashlight would become hot much faster.
Well, as a rough guess, most small lights that are thermally regulated seem to stabilize their output at about 500 lumens, if you tail-stand them. That’s about 5 watts of power, with maybe 50% going OTF in light? If you’re saying 1 - 2 watts of that is radiative, then that leaves only 0.5 - 1.5 watts for convection.
Doesn’t sound like enough. I thought convective cooling would be 3 or 4 times what radiative cooling can do.
It is - at high power, ratio of convection/radiation dissipation depends a lot on input power/flashlight temperature. S2 head has very small surface area,1-2Watts is enough to increase temperature close to 60C over some time.
Specific thermal conductance/conductivity and specific volumetric capacitance/capacity are very different properties of material.
Copper has almost 2x times better spec. thermal conductivity (Sinkpad numbers you mentioned), but spec. volumetric capacitance is only 30% better.
Spec. volumetric capacitance determines how much temperature would rise when material receives thermal energy/heat.
Just noticed that these are all sold out now.
Mine shipped this morning, so the three week countdown to here has started. Thanks to Simon Mao and J-Dub74 for making it happen :+1:
I just ordered but wasn’t sure what options for driver or led was available, what are the available options.
You can basically ask for anything that’s available in another version of the S2. You can see the older S2 configurations here:
https://www.aliexpress.com/store/product/Free-Shipping-Convoy-S2-Gray-Cree-XML2-U2-1A-AMC7135-3-2-Group-3-5-Mode/330416_1614328969.html
and the newer configurations here:
https://www.aliexpress.com/item/desert-tan-S2-flashlight-with-XPL-HI-led-inside-and-ar-coated-glass-biscotti-firmware/32820745681.html
Other tweaks may also be negotiable, possibly at an extra charge.
I went with a 7135×8 Biscotti driver and an XPL HI U6-3A LED, along with AR glass and a smooth reflector. Basically copying one of the new Desert Tan S2+ configurations.
I’ve never turned a S2 into a triple… What’s the easiest way to do so?
If i could get a triple Nichia 90CRI drop in that works with the A6 driver that would be great.
You have to make or buy a spacer.
Copper is best, aluminum is good…
Kiriba-ru sells some, for a reasonable price IMHO
+1! Bought some from him and I’m happy with those!
I didn’t buy the S2+ copper but this surelly looks pretty!
Modders, show us what you’ll do to yours :smiling_imp:
Was one of the first to order it, but had to cancel because I had not specified led and driver, et cetera.
Apparently this caused the light to re-appear in stock only moments ago. And I (re)ordered the (truly) last one. Sigh…
EDIT: And 15 hours later it is already on it’s way to me :partying_face:
Great, doesn't it? :-)
Mine is going to be a custom build with H1-A 3A boost driver and an XHP50 90+CRI G4 35G. Gotta decide if I'm gonna put a 10º or a 5º TIR on it. Up to 1600+ lumens OTF if I'm not mistaken, I could increase driving current a bit but it's going to be gifted to a non-flashaholic lady (a very smart person).
Cheers ^:)
Mines on the way and I ordered it as a host. It’s being kept to build out as a future gift. But if I take a liking to it then I’ll keep it.
