I’ve heard doubts aplenty, but the fact is, it’s been nothing but vocal doubts that this amount of light could travel more than a few feet before becoming hopelessly useless. “maybe” under the stove? What, is your stove half a mile across? “Determining the exact color of the boxers(…)”? With that kind of attitude maybe I should determine the exact color of the boot targeted at Uranus.
You think, you doubt, you think. I have been in the dark, I know how much light it takes to see when there’s not streetlights and floodlights shining in your eyes. If it was truly dark outside, then the other sources of light can’t add up to much; let’s say a full moon even though I don’t consider moonlight dark (I can nearly read a book by it). It’s the wrong phase right now to compare versus that, but at the very least I might show what this rough amount of kcd at 300ft instead of 200 can do. Maybe I’ll try doing a video; of course I will have to turn it down if I go anywhere but an open field. My d4 219c turbo was enough for 200ft+ on a clear night; on a normal night the haze makes any light a bit less useful since more light just means more backscatter. If I get any haze, I might have to just do normal walking around rather than focusing on the infrequent longer ranges.
Generally I either need to be able to search for things at a very far distance with a d1s or equivalent; or maybe to get a very good look at something in specific that was still somewhat distant. Otherwise, my edc is for when you need something to see what’s in the near area (50-150 ft, sometimes more): where are you, where are the buildings / vehicles / other things you’re navigating between, what’s near enough to you to be worth noticing, and where should you put your feet.
A thought….there are quite a few flashlight users who disregard turbo and want thermally-stable output only. Now….FW3A won’t be the light with the highest output in the class, but the combination of ui, egronomics, price would still make it pretty unique. Would adding an option to stop the ramp at the highest sustainable level make FW3A more appealing to such users?
The ceiling is set by default at full 7135 which is actually not that far off from what it can maintain with some emitters IIRC. I think xp-g3 was 800lm anyway.
Being one of the few who actually has a Samsung 4000k triple, I would disagree. It makes an excellent EDC and can light up my entire yard and garage… Stating things like excellent looking under a washer, sink or stove is quite purposefully misleading especially if you personally don’t own something in this configuration. This is not to be confused with a mule configuration that has no optic. This light is using an optic.
As of that post I have indeed made 67 of them for 1.847%.
You have posted 59 times of the 3626 for a 1.627%.
So indeed I did outpost you by a whopping 0.220% in post count. :+1:
But in length of post & lines written…… you would be the sure winner.
So Tom Tom……
……your ’declaration’ is somewhat akin to ‘the pot calling the kettle black’.
At least try to be accurate in your future insult attempts Tom Tom……
As far as “interesting”…… that is subjective & depends on the individual listener. You certainly do not have a final say on that besides your own personal opinion.
sub·jec·tive / 1. based on or influenced by personal feelings, tastes, or opinions:
I was cycling last night at 2am in a pretty remote rural area about 25km from home. Clear, no moon, the milky way shining bright overhead, so I knew it was dark. I stopped my bike and turned off my light to see how dark.
Wow! I could not even see the road right underneath me, even after letting my eyes dark adapt for a few minutes. I could make out the tree line where it met the starry sky, but that was it. It was actually rather scary, when I thought, “What would happen if my light broke or I ran out of batteries?” I would have been completely unable to navigate anywhere, even by foot, at least until twilight started to give me some light. (But I carried 4 lights and spare batteries, so I wasn’t worried.)
Any light at 300 ft., even a crappy low-power one, would have easily out-shined any stray light (of which there was virtually none). Even 0.01 lux would have allowed me to see where the road was.
So your comments on the Samsung LED are what exactly? Pots? kettles? Who cares. Just add some actual value to the discussions to help people make better educated choices if you are going to comment on something specifically like the Samsung triple.
Strange. I can see to walk around by starlight after a short time; of course I might be lucky. I’m sure even those with poor ability to adapt could see better than that after long enough; full adaptation takes much longer than the initial bit- you’d be able to see well enough to walk around after half an hour at worst, because then your rods should be fully recovered. But yeah, even a little illumination would be plenty when it’s truly dark. Many times I’m disappointed with the lowest mode a light offers. And in places with significant stray light, as long as you don’t let yourself get blinded by something bright, you can rely on ambient light some. On a dark night in a rural area, you’ve got to supply all your own light, but it doesn’t have to overpower bright lights to be the dominant source, so best to cover a wider area to avoid tunnel visioning, and of course don’t desensitize yourself too much in case you end up needing that sensitivity. Either way for navigating around I want a nice wide beam, and the beam intensity of today’s triples and quads is still quite a lot, more than enough for that purpose.
My thoughts that the XPL HI will make a better all around EDC for this light are based on the comments of ToyKeeper & a few others concerning this light.
Also on the fact that I have many XPL HI lights & am pleased with them beyond measure.
Your right…… who cares. Who cares what I think. Who cares what you think. Who cares what Tom Tom thinks.
Like Tom Tom said in a previous post…. “it’s just a bunch of egos blowing hot air.” (quoted below)
Mostly hoping to ‘sell’ or further advance their/our own personal preference and/or opinion I might add.
And as far as the “stove & boxer” comments, they were simply in reply to the scenarios you brought up. (quoted below) So no “attitude” as you suggest.
And as far as the “boot” you mention above. That would be a real good idea before you send it in the direction you mention. That way you will have a fond memory of it & the leg attached to it when you awake from your proposed space flight.
The comments I made were simply in response to scenarios spaceminions suggested. (quoted below)
There was no intent to be “misleading” & certainly no intent to be “purposefully misleading” either.
Oh, took the time to post and blame the other guy for you drawing false conclusions on an LED not even specified by him or handled by you. Yeah, this is definitely a $20,000,000 response. LOL!
