Yes, as long as you have a 2S a sufficiently high input voltage to maintain regulated output.
http://www.kaidomain.com/p/S027639.Triple-SST-20-White-6500K-LED-Emitter-with-20mm-x-1mm-Copper-PCB-Parallel-w-optics
triple SST 20 on the KD MCPCB board /w optics, for 6.99 $US.
- Code BLF works as well *
And I ordered 3 independent emitters for 3,19$ each few days ago…
Oh well :person_facepalming:
EDIT : Please KD, could you stock the High CRI version of the SST-20 ?
It’s called SST-20 WxH, here is the datasheet
I second this. Pretty cool. Tightly binned 2700/3000/3500/4000Ks too (if available).
Cheers ^:)
Someone should send one or two to koef3 for testing.
@ KD, please get the A120 footprint version which is XP-compatible. Like SST-20-W35H-A120-J4352
I have 10 coming in (from AE). If he’s up for testing them, I’ll likely send a couple to Texas_Ace since he’s here in the states. It’d probably be a bit more costly for me to send them internationally.
… It’d probably be a bit more costly for me to send them internationally.
Mmm, a few hours ago I had to handle the FedEx shipping guy €29.23 in custom duties for a €33.24 order from the :facepalm: states. Grrr $uck$…
Cheers :-)
Original post date Tue, 06/12/2018 - 00:03; space removed LoL.
The_Driver:Someone should send one or two to koef3 for testing.
I specifically mentioned koef3 because he actually tests the luminance.
I can send him some when i get mine
I did send him a PM and offered to send him a couple, but I’m guessing it would be more cost effective for you, George, right? (Since you’re in Europe) And they’d likely get there faster. Either way, we’ll make sure these get tested.
Of course , once i get them i can send some his way
Is it possible to buy this without led and driver? I only need de drop in as a host, for a custom build
Hi Ban,
I see on your website that the payment system is worked on (so I sent an email for an order). Do you have any idea when the website is restored?
gchart:… It’d probably be a bit more costly for me to send them internationally.
Mmm, a few hours ago I had to handle the FedEx shipping guy €29.23 in custom duties for a €33.24 order from the :person_facepalming: states. Grrr $uck$…
Cheers
Are these fees tariffs?
Hi Ban,
From the other thread:
Hi BLF friends
Thank you for supporting Kaidomain.com KD for a period of time. We are happy to launch a new shopping platform of KD. New KD will let you have a better shopping experience in KD.
The new system is under testing and will be ready within 1 to 2 days.Thank you
Ban
Barkuti:…
Cheers :-)
Yes. I believe that is due to 12% import duty + 21% IVA (VAT) + whatever FedEx charges you for the paperwork.
In the meantime I've got informed and now I know I can avoid that by staying below €22 per order shipping excluded.
That sure puts a crimp in your choices keeping it under 22 euros. Maybe that is a good thing? :money_mouth_face:
+1 to this.
pennzy: Barkuti:…
Cheers
In the meantime I’ve got informed and now I know I can avoid that by staying below €22 per order shipping excluded.
You can usually get most seller to write a dodgy amount on the box. I have items worth like 20-30 AUD and the seller will quote like 5AUD.
