LED test / review - Cree XLamp XHP35 High Intensity C4 + E2 (5000 K) - Really high performance in XP footprint?
25 posts / 0 new
koef3
koef3's picture
LED test / review
EN
XHP35A-H1-0000-0D0BC40E3
XHP35 HI flux E2, ‚tint 3C‘
UPDATE --- 06/23/18 --- raw data added (link)
Since the XHP35 is available on the market, it is often used in high power flashlights. With this LED many flashlight manufacturers got more output at same size and battery configuration. In all the time, I didn’t test this LED though.
In this review I test one of the highest bin availabe XHP35 High Intensity (HI) to date, and – as comparison – a slight less efficient XHP35 HI in C4 bin. I got the XHP35 HI with stated E2 binning a few months ago from a TLF member, the C4 one from mouser.
Technical data
Tsp 85°C / If 350 mA
Order code: XHP35A-H1-0000-0D0BC40E3, of E2 variant not available
Type: quad die (Flip Chip / Lateral)
Binning: E2 min. 590 lm (C4: 475 lm)
Rated voltage: typ. 11.3 V (max. 11.9 V)
Max. forward current: 1,050 mA
Viewing angle: typ. 115°
Thermal resistance: typ. 1.8 °C/W
Junction temp.: 150 °C
Official datasheet is available here (Cree website, pdf)
Appearance and LED die
The XHP35 is the smallest LED of the XHP (eXtreme High Power)series. With 3.45 x 3.45 mm the XHP35 HI has the same size like other XP LEDs and also uses the well known standard XP footprint.
Two bonding wires are visible, and four single dies can be discerned even without power the emitter up. Two of them are not connected via bonding wires, so the electrical connection lays underneath them (Flip Chip technology).
Because of this design the LED runs only on 12 Volts - the dies are connected in 4S (4 in serial).
Because the silicon dome is missing, the emitter is very flat. All Cree LEDs without a dome except the new XD16 are labeled as ‚High Intensity‘ (HI). There is also a High Density (HD) version available, which is fitted with a dome.
The footprint reveals no surprises, here shown in used condition.
Like in unpowered state the four single dies are visible. Unless the other XHP 1st gen LEDs, there is no gap between them. This should improve the beam pattern even in SMO reflectors.
The Light emitting surface (LES) of the XHP35 High Intensity is 5.32 mm² (0.00825 sq in) in size.
Power and overcurrent capabilities
25 °C Tsp, unless noted otherwise.
raw data here
Within official parameters
  • At 1,050 mA (max  rated current): 1,537.2  lm @ 13.06 V (C4 bin: 1,355.6 lm @ 13.20 V)
  • Power at rated maximum: 13.71 W (C4 bin: 13.86 W)
  • Efficiency at 1,050 mA: 112.1 lm/W (C4 bin: 97.8 W)
  • At 350 mA (binning current, but 25 °C Tsp): 633.1  lm @ 11.96 V (C4 bin: 558.0 lm @ 12.13 V)
  • At 350 mA (binning current, corrected to 85 °C Tsp acc. To Cree datasheet & PCT): 562.2 lm (C4 bin: 495.6 lm)
Overcurrent:
  • Maximum at 3,200 mA, 2,851.2 lm @ 15.29 V (C4 bin: 2,495.9 lm @ 15.37 V)
  • Power at maximum 48.9 W (C4 bin: 49.2 W)
  • Sweet spot at 2,200 mA (2,545.5 lm @ 14.29 V, C4: 2,239.7 lm @ 14.38 V)
  • Power at sweet spot 31.4 W
  • Bin E2: Efficiency at max 60.2 lm/W, in sweet spot 81.1 lm/W
Interesting facts
  • The XHP35 HI stated as E2 is more efficient than the E2 one, at avg. 12 %.
  • The E2 LED apparently has a slightly better heat dissipation, the max. current is 200 mA higher
  • At 85 °C the light flux of E2 matches pretty much exactly that of the XHP35 HI C4 at 25 °C
  • The E2 bin for XHP35 HI is not listed at the Cree PCT. If you would compare the HI E2 with other LED you had to choose the XHP35 HD variant from their list.
  • In overcurrent condition the Vf is very high, about 15 V.
Now a few words to the stated flux bin of this LEDs.
The min. light flux for E2 bin is 590 lm @ 350 mA 85 °C Tj. See also Cree PCT for this.
The XHP35 HI E2 tested here delivers 562.2 lm where the C4 delivers 495.6 lm.
Conclusion: the first LED does not reach it’s minimum light flux for bin E2, the C4 binned LED on the other hand is slightly better than stated in datasheet (min. 475 lm @ 350 mA 85°C Tj). So the alleged E2 flux bin is in fact equivalent to D4 bin (min. 550 lm) – the highest XHP35 HI bin which Cree list in his official documents.
Against my experiences, the spread in efficiency is obviously very big. A XHP35 HI E2 I tested much earlier but with the same test setup reaches almost 3,000 Lumens and therefore complies with the stated bin.
The apparently existing of such high bins of Cree emitters makes me suspicious (pictures of Cree reels with XHP35 HI E2 printed circulates even in the BLF). Not only in case of this LEDs such high light flux bins are not listed in official datasheets and the Cree PCT. But why Cree makes such a secret out of LED binnings, and why Cree doesn’t sell this LEDs officially (like at Mouser or something)?
I have a possible theory about this. Maybe the stated highest flux bins are not really binnings, but ‚golden samples‘ which are detected and sorted out at production while sorting each emitter in bin and color kit. Unfortunately the amount of these super-efficient emitters could be much too low – and if such LEDs are offered at the market officially the availability simply could not be guaranteed. This could maybe explain why some of the tested XHP35 HI E2 have a unusually large spread in efficiency.
Maybe some of you members have a better theory about this? The maybe existing spread in the bins and max. light flux could be very interesting for our thrower and ‚maximum possible performance‘ fans.
Luminance
I established a new method for determining luminance, especially to ensure more realistic values for 'real-life' conditions (flashlight use). The measurements are taken with a new original Convoy C8 reflector, but with same heatsink / setup as previously used in flux measurement.
Reflectivity for reflector 85 %
Transmission UCL glass 97,8 %
Values at 25 °C Tsp, for 85 °C Tsp values are 6 to 14 percent lower, depending on LED
LEDs marked with Warning sign uses old values are still taken with previous method (determining die size) due to problematic light distribution (donut holes etc).
Important: due to destroying of the emitter used in the light flux I had to use another XHP35 HI E2, which might be more efficient than other samples (see also 'interesting facts' section above). Selecting of very good samples might be necessary for highest-performance mod projects.
With 171 cd/mm² the luminance of the XHP35 HI in E2 binning is very high. It is as high as of the XP-L HI V3 and comes close to the dedomed SST-40-W!
At approx 35 percent bigger LES as of XP-L HI V3 the light flux of the XHP35 HI E2 used for luminance test is also approx 35 percent higher, so the values are plausible. The C4 one performs much lower, but comes still close the dedomed XP-G3 in highest bin.
Light quality and use in optics
At this point I don’t need to explain further. The XHP35 HI is often used in modern flashlights and their beamshots are published everywhere on the net.
Because of the missing gaps between the single dies there is no big ‚black hole‘ in the center of the spot. At some flashlights there might be some yellow or red areas in the spot (see beamshot) or little dark points, but much better than the weird beam patterns of the bigger XHP50 and 70.
In the luminance test with a Convoy C8 SMO reflector there were no darker spots or miscolored areas in the beam.
To mix the light and get a really nice and uniform color distribution I recommend the use of an OP reflector and/or diffuser film.
Conclusion
A good LED, like everyone know. Smile Relatively nice beam pattern, also a acceptable performance and good handling makes it to a good choice for modding lights. But – there is one big con: the XHP35 HI needs 12 V and also special electronics. Because of this the XHP35 is not suitable for all flashlights despite the same XP footprint.
The flux bin E2 is not reached in this test, it rather corresponds to D4.
Pro
  • very high performance for it’s size
  • very high luminance, even higher as XP-L HI V3 (E2 binning only)
  • industry-standard XP footprint
  • Good light quality and beam pattern if used in flashlight optics
Con
  • 12 V variant only, special electronics needed
  • very huge performance / efficiency spread in E2 labeled samples
  • E2 flux bin not reached at sample used in light flux test (D4)
I hope you enjoyed this test - and thanks for reading! Smile
Greetings, koef3
My LED tests: Cree SC5 based LEDs (WIP!)  ---  Nichia 319AT 83 CRI - Optisolis (3000/5000 K) - Lumileds Luxeon LXML-PWD9 - Luxeon MZ 5700 K (90 CRI, 3 V) - Luxeon V (CSP) 4000 K 70CRI - Luminus SST-40-W (+ dedomed) - Cree XP-L2 (+ High CRI variant) - XHP35 HI - XHP70.2 - CXA1304 COB - OSRAM OSLON Black Flat HWQP - SYNIOS DMLQ31.SGLE UW Q8WP - unknown 5050 LED ---- finished: JAXMAN M8 (Mini C8) HighCRI Triple
Edited by: koef3 on 06/23/2018 - 13:30
Lexel
Lexel's picture
Last seen: 29 min 13 sec ago
I can confirm this suspicious binning
I tested one of the E2-3C and one E4-3C I bought from MTN last week
Stock D4-1A Emitter 464kcd
E4-3C 489kcd +5%
E2-3C 538kcd +16%
The last one might be a lucky one that is well within E2 binning
djozz
djozz's picture
Last seen: 2 hours 49 min ago
Thanks for all the work again, this will be a good reference for building lights with the XHP35!
koef3
koef3's picture
E4-3C 489kcd +5%
E2-3C 538kcd +16%
The question is why is Cree hiding the highest bins in their documentation? And another question: why is Cree not selling them to authorized Cree resellers, like Mouser?
I don’t think that this is made out of no reason.
Earlier the same things happened with other LEDs, like XP-L or XP-G2 (in the meanwhile the bin S4 / S5 are officially documented).
TBone
Last seen: 1 hour 51 min ago
Possibly because Cree was not expecting to produce their highest quality in big enough amounts. Mouser is buying thousands of LEDs in one order and usually they do not stock all tints (or even different bins). If Cree can only deliver a few hundred of one bin Mouser may not be interested to list such a ‘special’ item.
If the yield is constant the new bin will show up in the next revision of the datasheet.
Schoki
Schoki's picture
Last seen: 54 min 5 sec ago
One question: how do you calculate your sweet spot?
koef3
koef3's picture
Hey, thanks for the question – because the values are completely wrong, and I didn’t even noticed that after six times complete reading…
It’s fixed now. Smile
Currently I does not calculate anything for the sweet spot, in general I call the point ‘sweet spot’ which is roughly 15 – 35 percent under the possible maximum light flux because such a difference is not really visible with the eyes.
Could be a thing for my upcoming tests to always get the same calculation.
koef3
koef3's picture
Luminance of XHP35 HI E2 added in OP.
luminarium iaculator
luminarium iaculator's picture
Last seen: 1 day 4 hours ago
Cheers Beer
Modding is making something how you want it to be, not how it comes stock...
Old-Lumens
koef3
koef3's picture
Important notice:
I updated the luminance values for all LEDs shown in test chart including XHP35 HI C4 / E2. I used another E2 sample for luminance testing due to destroying the sample used for first light flux / luminance test.
To ensure more realistic values for 'real-life' conditions (flashlight use / secondary optics) I established a new testing method to determine the luminance with a SMO reflector. All upcoming and already existing tests will use this method!
Updating of my other tests will be done in the next hours / days.
JasonWW
JasonWW's picture
Last seen: 1 hour 28 min ago
Koef3, so you were getting 2850 lumen at 25°C temps? Did you do short pulses to measure this?
If you were to measure the temps after 30 seconds, where do think it would drop to? Would it hit 85°C temps in 30 seconds?
koef3
koef3's picture
My cooling rig is very big and the thermal resistance of it is very, very low especially since I optimized the whole cooling for lowest thermal resistance. So I got almost no drop in light flux due to higher Tj / Tsp.
After 30 seconds the light flux at highest current possible hasn't changed in a significant way (+- 0.5 percent maybe). This means also I have not to measure the light flux in short 'pulses'. However, in flashlights (especially these with less massive material in the head) it is almost impossible to get these really good values from my lab testing conditions. But this depends really on flashlight type and board used.
JasonWW
JasonWW's picture
Are we at the point where we can have 2700 Lumen out the front flashlights from the factory?
koef3
koef3's picture
No, not really. From my experience flashlights have never the same low thermal resistance from LED to case so the highest current possible is lower than in my tests.
I think real 2200 to 2400 (OTF) lumens out of XHP35 HI are the maximum in a mass-production standard factory flashlight. All above may shorten the lifespan of LED and/or electronics significantly...
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 hour 44 min ago
I have just recognized that my Nitecore MH23 with an XHP35 HD shows a little less brighter spot or dark area right in the center of the big white spot. It can only be seen when doing a whitewall shot but it’s definitely visible. I checked the flashlight’s LED but all four die areas seem to work fine. The dark area only disappears when being closer than 1,5m to the wall. Any distance beyond 1,5m will reveal that there is a minor dark spot within the spot.
According to the first post of koef3 I assume this is absolutely normal, isn’t it? Unfortunately I cannot post any pictures of the whitewall shot as the camera sensor will immediately equalize the light intensity to the aperture.
Enderman
Enderman's picture
Last seen: 6 hours 13 min ago
That can also be from the reflector not being at the perfect distance from the die.
Lexel
Lexel's picture
Found same issue with Nitecore light, seems the focus of the reflector is not optimal
Lux-Perpetua
Thank you Enderman & Lexel! Is there anything I can do about it or would you recommend to accept this “as is”? I must admit I have not recognized it when using the MH23 outside.
Just to rule out any own faults:
Can this dislocation between emitter and reflector happen when the flashlight suffers small shocks from falling (during transportation) or is that very unlike to happen? I’m talking about veeeery small shocks, so 4-6cm of drop height. Wink
Enderman
Enderman's picture
The only way to fix it would be to open the head, which I’ve heard is pretty hard on most flashlights from nitecore.
If you don’t notice it much during use, don’t bother.
The reflectors are very solid inside the light, and the thing that would cause a donut hole is a Z axis translation, so no it almost certainly isn’t from any drops.
Lux-Perpetua
Alright, thanks a lot! So, I don’t need to be worried about it. The dark spot can only be seen if you really look for it on the ceiling or wall. My MH23 only “dropped” 4-5cm from a bag into a plastic box while inside its holster. So, I guess this does not even count as a real drop. Big Smile
koef3
koef3's picture
Raw data
Cree XHP35 HI C4
Amps    lm    Vf
0,20    354    11,72
0,40    623    12,22
0,60    890    12,62
0,80    1113    12,92
1,00    1311    13,17
1,20    1493    13,39
1,40    1686    13,61
1,60    1851    13,83
1,80    2000    14,02
2,00    2124    14,20
2,20    2240    14,38
2,40    2339    14,56
2,60    2413    14,75
2,80    2463    14,94
3,00    2496    15,14
3,20    2496    15,37
3,40    2463    15,51
Cree XHP35 HI E2
Amps    lm    Vf
0,20    360    11,47
0,40    707    12,03
0,60    976    12,42
0,80    1246    12,74
1,00    1487    13,03
1,20    1702    13,27
1,40    1909    13,49
1,60    2091    13,70
1,80    2273    13,91
2,00    2421    14,11
2,20    2545    14,29
2,40    2645    14,48
2,60    2727    14,67
2,80    2785    14,86
3,00    2826    15,08
3,20    2851    15,29
3,40    2843    15,52
If you create diagrams / comparisons with this data, I would ask you to publish these charts in this topic and also to specify the source of the data used. Smile
Agro
Last seen: 15 hours 30 min ago
I’ve been asking myself a question: what makes efficient thrower LED?
High cd/mm² together with high cd/mm²W?
In a way that’s a good metric. If you want a lot of throw in a thermally limited host, that’s what you need. But a smaller emitter always wins. When your thermal limits are more relaxed that may not be so good….
I wanted to abstract away LED size.
What is “efficient LED”? Here I say it’s one with high efficacy.
What is a “thrower LED”? One with high surface luminosity.
What I call efficient thrower LED? One that can achieve high surface luminosity without becoming inefficient.
So I charted lm/W against cd/mm² using koef3 data. That’s what I got:
Conclusions?
  • It seems size abstraction works like expected – compare Blackie HWQP with Ostar Q8WP – their behaviour at high intensity is about the same.
  • XHP35 HI really looks very nice here as well….until it reaches (probably thermal) limits.
  • Looks like if someone reinforced SST-40 bond wires it could go for longer.
Note that alone this chart says nothing about “what LED should I use in host X”. Size is a critical factor here and I explicitly ignore it. But I think it’s an interesting secondary metric.
ADDED:
Domed emitters are more efficient than flat ones?
It’s not strictly false, but from now on I will call it a misconception – because that’s not so simple and often straight incorrect.
If you take a LED in domed and dedomed variant, the former is more efficient, regardless if it was domeless from factory or dedomed later.
But unless you want to have your LEDs severely underdriven, a flat LED with larger die will offer same throwiness (i.e. cd/lm) with better efficacy. Obviously there are often market related reasons why a domed emitter might be preferred. F.e. there is no larger one in the footprint and price point that you’re targetting. But in general I think that (outside of lanterns and other lights targetting extreme efficiency) flat LEDs are just better.
And thank you koef3 for enabling me to draw these charts as well as these conclusion.
Your intensity measurements are what makes your tests special.
koef3
koef3's picture
Nice chart, thanks. Smile
Very interesting. The XHP35 HI reaches thermal limit, indeed. Tj is reached very quickly, because the Vf is very very high (3,400 mA with 2,843 lm at 15,52 V!) which lowers the efficiency significantly. The small thermal pad of the XP footprint is likely to negatively impact heat dissipation.
Agro
I added more LEDs to the chart above as well as a few more words.
LouieAtienza
Last seen: 40 min 13 sec ago
The binning is not surprising. Intel used to do this all the time with tbeir processors. This is because they have to sell different speeds at different price points. So they would rate one processor slower than another even though they were the exact same chip. Of course once overclickers figured this out Intel started to lock speeds on-chip…
