It has to do with translations from different languages to English.
pepinfaxera is from Spain, where flashlight is said “linterna” (in portuguese it is “lanterna”).
Most common translation from our languages is “flashlight” despite “lantern” is also used.
In this case I just tried to help to clarify that there is no difference from both terms. So there is only the FW3A flashlight/lantern, not 2 different products to subscribe for!
However, lantern is a term associated to other type of lights. Please search for “Zanflare T1 lantern” - a recent thread - to see what the term may refer to
PSA: I am not sorry if you are on a metered or slow connection.
The furthest tree in the center of the frame is approx 42m (138 freedom feet)
The fence line is ~28ft/8.7m
The peak on garage roof is ~63ft/19m
All 3 triples were using 10507 optics (clear narrow spot)
All lights were in their highest mode (mostly FET w/ fresh batteries)
Camera settings were full auto because i’m a potato photographer
PS: Since we have a bunch of armchair astronomers can anyone identify the star/satellite/planet/ufo in the pics? I am facing approx due East and i’m located in Texas.
I’m pretty sure if my stove was in any of these trees I could see it pretty clearly.
Personally, I think either would be good as an EDC light. I will say a $20 desert tan S2+ SMO XP-L single at less than 1/3 the lumens will also light up that tree. The bottom line is if you want something that throws “well” you need to step up to a D1 or better and stop trying to use a TIR triple as your single do everything light. In addition, I think they plan on putting a frosted TIR on the XP-L HI version which is going to diffuse the beam more than my pics, so expect even less throw.
-It’s not sunset it’s light pollution and a camera that takes excellent low light pictures.
-The 10507 clear spot should be used for all emitters we are considering. The XPL-HI crowd wants throw and lumens at the expense of CRI and beam quality. The Samsung doesnt need a frosted optic the beam is perfect with this clear one. If you voted for Nichia then you should probably tape 3x BLF 348’s together and call it a day.
The Isaac Newton telescope got moved to to La Palma. Which is an extraordinary place to see the sky, if your lungs can cope.
Herstmonceux Castle - Wikipedia is well worth a visit if you are in the area., though it is mostly a school now with the science centre being the interest.
I would prefer a clear optic also, but I understand we can’t pick and choose everything. I am going to wait and see what the final specs are, and make may purchase decision accordingly. I’m buying no matter what, but the number is to be determined. An optic is simple to swap though.
