Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
This might be helpful
I see, Thanks I’ll give it a try and report back…
It worked! Thank you so much! :slight_smile: :beer:
This is the correct wiring for the replacement BLF Q8 Switch…
I put a small dot of crazy glue to prevent the switch from rotating when I screw back the silicone boot
Bought one too. Maybe I’ll come back and ask how to dismantle the lamp’s head if I have some issues.
It’s easy. You just need to have some good strength.
If not, just use some carpet to help you open it.
original Q8 MCPCB is available on Aliexpres :smiley: :smiley: :person_facepalming: :person_facepalming:
https://www.aliexpress.com/item/BLF-Q8-Driver-Chip-Q8-Circuit-Board/32867355375.html?spm=2114.12010108.1000013.1.2538726bX9vIYM&scm=1007.13339.90158.0&scm_id=1007.13339.90158.0&scm-url=1007.13339.90158.0&pvid=2a05d018-a404-4259-b6eb-28f999de2e49&\_t=pvid:2a05d018-a404-4259-b6eb-28f999de2e49,scm-url:1007.13339.90158.0
Actually, I have seen that BLF Q8 MCPCB in the Sofirn AliExpress Store from several weeks ago (I often browse the Sofirn AliExpress store…), just didn’t know if it’s the original one or not. Since Tracy from Sofirn assures us that it is the original one, this would be good for those who need BLF Q8 replacement parts.
There are also a few other BLF Q8 replacement parts (BLF Q8 reflector, and switch assembly) from the Sofirn AliExpress store, in case anyone needs them:
https://www.aliexpress.com/store/product/BLF-Q8-Accessories-lighted-switch-assembly-Copper-DTP-MCPCB-Reflector-for-Q8/2933049_32879434650.html
@Tracy, I was the one who ordered 2xMCPCBs a while ago a few days ago.
And yes, it is the original one. And having messaged Sofirn, they are going to offer some other things soon, including the battery tube, and the tailcap. And a special surprise I will not tell yet.
I just got the Q8 and loving it so far :slight_smile:
Thanks to everyone that worked on this project!!!
Question: I am trying to find out if it’s worth the hassle to get a handlebar tripod mount to use the Q8 as a bike light. What do you guys think?
My concern is the weight of the Q8, although very compact for how bright it is, it does weight a bit when loaded up with all four 18650 batteries.
Just want to get some feedback on this especially from anyone who has looked into doing the same, thanks!
I wouldn’t want to trust only a tripod mount on a bouncy, pot holed bike ride with such a heavy light. I would feel more confident with some kind of large strap(s) or circular clamp holding the body.
heres a vid of a bike mount and a thread with some pics…scroll down…
I wouldn’t do it. Maybe we can talk Sofirn into making a remote battery tube adapter.
From the mtbr thread: BLF Q8 on the Bars? 5,000 Lumen Monster bar light! | Mountain Bike Reviews Forum That a nice looking plate/adaptor/mount thingy :slight_smile:
That’s a good idea, a remote battery pack and while we’re at it, how about a short replacement for the battery tube with connectors for the cable going to the remote battery case. One can dream :slight_smile:
That’s what I meant. It’d be two caps with contact boards and a cable to connect them. If it was used with the upcoming extendable battery tube, battery life could be made virtually limitless. I’ve seen pictures of a solution like this, but no details. It could work with 3d printed parts too, which would keep weight down further.
I used a ‘50mm quick-release truss clamp’ to make a tripod mount for my Noctigon Meteor M43, which lacks a threaded hole. The Meteor and Q8 both fit nicely in the 50mm truss clamp. I stretched some old tubes onto my clamps to increase friction and prevent scratches.
For mounting to a bike or ATV, connect another smaller clamp to grip the handlebars. This makes the light’s angle easily adjustable.
My 35mm truss clamp above closes down to almost an inch. There are also 20mm or 3/4 inch clamps on eBay.
Be sure to use a quick-release truss for the light’s end, so you can easily detach the Q8 when you’re not riding. It seems the smaller diameter clamps aren’t widely available with quick-releases.
Sounds like a good child project to the Q8. Wish I had a workshop that I can take on these project.
That looks really nice. Especially how the inner tube fits on the clamp, totally look factory.
Question, do you have any issues with stability, shaking or flexing?
Thanks for your help. :+1:
uhm… I was in the first batch list for the Q8, but then I gave my reservation up to someone else because I was in tight circumstances… but now of course I regret :s I payed 40 USD for the D4, which is worth it, but this massive light for the same price was just a gift… wondering what is the lowest price it has been sold after that. I remember deals around 50-55 usd… has it ever dropped to 40 again?
Not at 40$, but 46,50$:
https://m4dm4x.com/blf-q8-arrived/
Enjoy.
Have been playing with my new toy - BLF Q8 and still loving it.
While playing with the Q8 last night I noticed something that is not on the owner’s manual or the cheat sheet so I thought I would post my observation here to see if I can get more information on this unlisted “feature”.
Ok so this is what I did:
1) From off, hold and ramp up the brightness till it started to ramp up and let go of the switch.
2) Hold and ramp down the brightness and HOLD the switch down until the light is at the lowest brightness (indicated by one quick blink of the switch).
3) Let go of the switch, within 1/2 second push and release the switch one time.
Doing the above, the switch will blink once and will no longer glow green until you turn on and off the Q8 again.
Now I’m not sure if this is only happening on this version of the firmware (if there has been different versions for the Q8) or I just have a special Q8.
Thought I would post it on here and see what you guys think.
This is actually a bug which turned into a feature.
If you click on then off fast enough, that will shut off the button.
Thought that might be the case, thanks for confirming.
