PSA: I am not sorry if you are on a metered or slow connection.
The furthest tree in the center of the frame is approx 42m (138 freedom feet)
The fence line is ~28ft/8.7m
The peak on garage roof is ~63ft/19m
All 3 triples were using 10507 optics (clear narrow spot)
All lights were in their highest mode (mostly FET w/ fresh batteries)
Camera settings were full auto because i’m a potato photographer
PS: Since we have a bunch of armchair astronomers can anyone identify the star/satellite/planet/ufo in the pics? I am facing approx due East and i’m located in Texas.
I’m pretty sure if my stove was in any of these trees I could see it pretty clearly.
Personally, I think either would be good as an EDC light. I will say a $20 desert tan S2+ SMO XP-L single at less than 1/3 the lumens will also light up that tree. The bottom line is if you want something that throws “well” you need to step up to a D1 or better and stop trying to use a TIR triple as your single do everything light. In addition, I think they plan on putting a frosted TIR on the XP-L HI version which is going to diffuse the beam more than my pics, so expect even less throw.
-It’s not sunset it’s light pollution and a camera that takes excellent low light pictures.
-The 10507 clear spot should be used for all emitters we are considering. The XPL-HI crowd wants throw and lumens at the expense of CRI and beam quality. The Samsung doesnt need a frosted optic the beam is perfect with this clear one. If you voted for Nichia then you should probably tape 3x BLF 348’s together and call it a day.
The Isaac Newton telescope got moved to to La Palma. Which is an extraordinary place to see the sky, if your lungs can cope.
Herstmonceux Castle - Wikipedia is well worth a visit if you are in the area., though it is mostly a school now with the science centre being the interest.
I would prefer a clear optic also, but I understand we can’t pick and choose everything. I am going to wait and see what the final specs are, and make may purchase decision accordingly. I’m buying no matter what, but the number is to be determined. An optic is simple to swap though.
Well as I see it what the poll then shows is that the intended market doesn’t have a clear preference. That makes the poll moot and it is the designer/manufacturer decision again (or, more correctly - still) as to what is used. Fine by me, I’ll love it regardless unless it has serious faults. What the poll might achieve though, is make it more likely that two options be made available. Winner winner chicken dinner, as they say.
Assuming you’re taking these pictures in the evening, then that bright object is Jupiter. Right now, it’s in the eastern/southeastern sky after sunset. Venus is in the west after sunset, for the next couple of months.
