In my case, the voltage readings of my ZY1276 didnāt seem to change (or if it did, it was too small that I hadnāt noticed it) before and after I upgraded its firmware.
Please read my PMs thanks
Guys I have great news. So my ZY1276 just came in the mail. After trying it. I was so confused of the firmware version. Its already on 3.36D . And it appears that I have the new ZY1276P version (I know cuz when it shows the model number when you holding button bfore going to configuration mode) okay. So basically. I should be able to check emarker without PD adapter. No documentation yet. So idk. Iām waiting for my type c cables. Also. Iāve found a closed beta firmware . 3.36E (newer than stable) it removed some Chinese text. And vooc check . For beta testing QC to PD 2!! (He said the memory isnāt enough for new features so he needs to remove some to get some) . Havenāt tried it yet tho. He said something too about not using it with emarked type c cable. Anyway hereās the fw if you wanna test it. ZY1276 only!! Iāve flashed it successfully.
Fw : https://mega.nz/#![](WFkRUSCA)RDdOOFOaqEt8DM_kchLiokDeEIp1mf2m3h95Pq5siLg
File doesnāt exist. Please upload it to mega.nz or similar.
Updated!!
please read my pm thank you
Any news about the ZY1280 ?
Anyone able to update the ZY1273?
I even canāt change the voltage from 4.0 to 1.8V.
What do you mean sir by changing voltage from 4.0 to 1.8v?
Do you mean calibrating the voltage of the ZY1273 from the Settings menu?
If the ZY1273 uses the same firmware flashing method as the ZY1276, then it needs the STM32 programmer device and proper cable/pogo pins to update.
Youāre right, i meant the voltage setting in the STM32 programmer software.
I do have the pogo pins, but canāt connect the ZY1273 to flash the firmware 3.1 on it.
Seems like a UM24 with smaller display.
Hereās a list with current RD USB meters:
https://rdtech.de.aliexpress.com/store/923042/search?SearchText=usb&origin=n&SortType=price_desc
If thatās the one itās quite cheap, probably much lower quality than YZXstudio?
AFAIK all RD products are good quality. Maybe not better than YZXStudio but probably with slightly better price/quality ratio.
Not lower quality, but just not as many functions.
The quick charge mode identifier is a little less 'smart', and some other functions just aren't there such as PD trigger etc...
Anyone know anything about these WEB- series of testers?
YZX usb meter is very good, but the price is too higher ā¦
but RD (ruideng meter ) is cheaper and have more function.
for āāUM24Cā:https://www.aliexpress.com/item/RD-UM24-UM24C-for-APP-USB-2-0-LCD-Display-Voltmeter-ammeter-battery-charge-voltage-current/32845522857.html?spm=2114.12010108.1000023.1.5aa25437tcldCcā and āāUM25Cā:https://www.aliexpress.com/item/RD-UM25-UM25C-for-APP-USB-2-0-Type-C-LCD-Voltmeter-ammeter-voltage-current-meter/32855845265.html?spm=2114.10010108.1000023.3.39efe6d4UQtfqhā: , it can support PC software and android APP, APP can support 21 kinds languages
and
APP and PC software can export data by excel. it is easy to research the dataā¦
but YZX meter did not have ,
For UM34C, it support USB 3.0 and Quick charge recognition mode:QC2.0ćQC3.0ćAPPLE 2.4A/2.1A/ 1A/0.5AćAndroid DCPćSAMSUNG, support support OPPO phone VOOC, OnePlus DASH
Though UM34C and UM25C have Type-c port , but there is not trigger, only support type-c charge, not recognition
although for data or some function, it is not better than YZX meter, but for the price , it is already best ā¦
for USB load, there are many choice , LD25/LD35
If someone need more cheaper meter, but colorful display, there is also choice
AT34
Waiting for everyone to discuss ā¦
Probably a very basic question, but it has me puzzled. Most of the USB power meters I have or have seen have Groups. What are their purpose.
You donāt have to reset the mAh/Wh measurements when doing several tests in a row. Just switch the group and retain the old data.
