Tom Tom, I did not think you were so bigoted, until recently. Please keep in mind this is an international forum. We are from all over the world. For many people here, English might be their 2nd or 3rd language. Please try to be more tolerant of others, okay?
Also, when you say stuff like this I can’t tell if your joking or serious. I’m starting to think serious.
You make it not so pleasant when you say stuff like this or rant about shipping rates. I’m sure you think your country is the greatest in the world, but you have to remember that everyone thinks their country is the greatest.
Can we please focus on the lights and all get along? Thank you.
/\ :+1:
LOL, just let them UK/Common Wealth folks call themselves names among each other, they will be juuuuust fine! :partying_face: :+1:
(lived in England for a while with two irishmen, one catholic from Dublin, one protestant from Belfast, have learned a few words that I was never taught in English class.)
I usually hang out on Reddit so I just now made an account here, but I’d like to get on the list please! Thanks everyone for your hard work on this!
Welcome to the forum. I’m sure Pepinfaxera will add you for one unit when he does his next update.
I’ve actually taken some video now with my d4 219c (approximating the cd of a lh351d fw3a) showing why I do not think any more throwiness than that is a useful thing even outdoors, and why floodiness might be. I have tested several scenarios; both distance shots and a variety of other ranges. I blindfolded one eye for 20-30 minutes before going outside, but as it turned out the camera wasn’t able to be made sensitive enough to match it. I got it as close as I could to the non-adapted eye’s sensitivity, but it didn’t quite reach that. I’m more of a stills photographer, so maybe there’s something I missed. All video clips were shot at the same exposures, the only auto setting was white balance.
Hells’ Bells. just get it made and delivered PDQ, however.
Done and dusted,
Then we can stop yacking about it.
It might be great, or not, but I’ll take that chance.
@spaceminions
What should I have done for my beamshots to be better? Do a full auto picture, note the ISO and Aperture, switch to “Program Auto” and fix those values and let it auto everything else?
I’m hoping to do an emitter-vs-color-temperature heat map of all votes with a matching name on both polls, to get more info about which specific emitter+color combinations are most popular. And since I can’t map anon votes between polls, they won’t be on the graph.
However, I have a tool to run the Condorcet algorithm locally, and here are the results so far with anon votes removed:
Color temperature:
      4500K 4750K 5000K 4250K 4000K 5500K 3500K 3000K 6000K 6500K
4500K     -   104   113   126   128   149   157   160   168   173
4750K    78     -   102   108   119   160   155   163   179   183
5000K    86    89     -   106   114   186   157   160   189   192
4250K    51    71    91     -    85   124   130   135   139   144
4000K    57    74    88    70     -   125   139   144   141   145
5500K    53    29    12    73    75     -   104   119   153   158
3500K    33    42    48    42    30    82     -   122   107   116
3000K    38    38    44    49    39    68    39     -   101   112
6000K    32    18     9    52    53     6    67    66     -   122
6500K    25    12     7    39    40     4    48    46     7     -
Emitter type:
               Samsung LH351D   Cree XP-L HI    Nichia 219c     Cree XP-G3     Cree XP-G2
Samsung LH351D              -            126            153            181            188
  Cree XP-L HI            120              -            152            233            236
   Nichia 219c             77             98              -            154            162
    Cree XP-G3             62             18             84              -            127
    Cree XP-G2             53             14             71             76              -
Removing anons doesn’t change the color temperature rankings. It does flip the top two for emitter type though. In either case, the margin isn’t big. In one result, XP-L HI wins by 5 votes. In the other result, LH351D wins by 6 votes.
The main trends I see in the votes are:
  • The top two emitter types are pretty evenly split, so we should probably try to get Lumintop to make both.
  • Tint for each emitter type should be 4000K to 5000K, but the details need a closer look.
BTW, it’s worth mentioning that the polling site does at least try to prevent ballot stuffing. It’s not very hard to get around that, with a bit of internet trickery, but it at least doesn’t let people do it easily. And at a glance, it doesn’t look like that has happened, even among anon votes. Like, for color temperature, there are currently 119 anon votes, of which there are 106 different unique ballots. And half of the non-unique ones just have “10” in every cell, no preference expressed, so they don’t even affect the result.
I actually started writing an implementation of the beatpath algorithm to satisfy my own curiosity about the impact of anonymous votes.
I do hope Lumintop will make two emitter options. Obviously my preferred emitter is better than the other leading option, but I do see where proponents of the opposition are coming from (they’re still wrong).
I don’t know if it is possible, but I agree that the poll shows that having both XP-L and Samsung choices would make the most people the happiest. Although I prefer the XP-L, I would probably get both in that scenario. My wallet is hoping against this.
Thanks for checking! Yeah, pretty much seems like you said, the 2 emitters and the 2 temps.
LH351D 4000k/5000k
XP-L HI 5000k/4000k
And done! :slight_smile:
contactcr make sure that iso, aperture, and shutter speed do not change through your test regardless of their values or how you found them.
The point of my video was mostly that while beamshots can show the relative intensity of two or more beams, their shapes and qualities, etc, they don’t reflect how much intensity is actually required- if you ramp up from zero and stop when you’ve got enough light to see, you’ll usually find that you don’t go near the maximum brightness. However, you might find yourself wanting a wider beam - I know when I was in the woods in my test, the d4 219c beam was too narrow when it came time to get my bearings again.
Edit: You might try exposing for the least intense light in the comparison, rather than the most intense or a random middle pick.
To be clear, none of the options are bad. All five are great choices, even the old but venerable XP-G2. I’m pretty happy with my triples in XP-G2, XP-G3, 219b, and XP-L HI. I don’t have any triples with 219c or LH351D, but my 219c quad is nice, and everyone with a LH351D says it’s awesome.
If we can get more than one flavor made, I plan on getting every flavor.
In that case, it’s probably especially important to maintain a practice of humility and remembering what it’s like to be at the bottom. They say (and studies show) power corrupts… and, as Spiderman says, with great power comes great responsibility. Gotta be extra careful to avoid bad habits.
Any decent cell should work, though higher-amp cells like the 30Q and VTC6/VTC5 should make turbo a little brighter. On regulated modes, the highest output is only 3 amps, so most cells should be fine most of the time.
This light isn’t optimized for maximum turbo performance. The heat sink isn’t massive, the springs aren’t fancy low-resistance alloys, the wires aren’t extra-thick, etc… It’s not particularly hot-rodded.
The main thing is to make sure the cell is small enough, so probably an unprotected battery.
There isn’t a lot left to do, and progress has sped up again… so hopefully release will be soon.
The 10507 has the biggest numbers on paper, but…
  • It makes an ugly beam. I hear it looks okay with LH351D, but on every emitter I’ve tried in one, I end up hating the beam. It produces a rainbow effect and lots of artifacts.
  • The 10511 can be polished to increase throw, if desired, and from what I hear, it can throw better than the 10507 after being polished. Afterward it has more visible artifacts, but the beam still ends up looking nicer than a 10507.
  • Swapping the optic is easy and the parts are only about $1.50 each, for anyone who wants a different optic.
Yes, having data helps with convincing the manufacturer that a market exists for both. :slight_smile:
I kind of prefer the Ranked Pairs algorithm over Schulze/beatpath, but RP hasn’t been working lately on the CIVS site and the results are almost never any different, so I went with the more stable more popular option. I’m using RP locally though. It’s simpler, and it was easy to find existing code for so I wouldn’t have to reinvent another wheel. I just had to mod the input parser a little to accept the format I get when pasting data from the CIVS site.
For XP-L HI, more CCTs are available… so that would probably be 4A (4650K). But for LH351D I need to look at the data more closely to see whether people want 4000K or 5000K.
The LH351D in both 4000k and 5000k have been tested, both by Maukka and djozz. And from them, they said that the LH351D in both color temperatures was awesome, about as good as the Nichia 219C and Luxeon V.
I only have the 4000k R9070 version of the LED in my Thorfire TK15, and it is truly awesome, and makes for an awesome EDC.
Put me on the list please
This is why I’m on the list for four of them. I’ll do it myself.
I’m very much a CRI snob though, so probably no XP-L HI or XP-G2. I can’t not have a 219C version of course, and I’ll very likely try the LH351C, which Digikey has here in single quantities, 4000K, 90 CRI. (I know the page doesn’t list the CCT and CRI, but Octopart does.)
:person_facepalming: …. My, my, my…… :person_facepalming: … :frowning:
Forgive my ignorance, but who is Nellie the Elephant?
Beats me… I myself am also at a loss of any significance associated with that ’statement’ made by Tom Tom.
BUT…… fwiw……I did find a picture of “Nellie”. :person_facepalming:
