Thanks let me know. I’ll also going to test mine tonight.
Quite fast for S.A Regarding my ODL20C sample, it is on a much slower boat.
Hardusvd70:Just received mine right NOW!!! Thank you freeme.
Yes indeed it was relative fast to SA. Please let me know regarding the ODLC20C when you receive it.
JasonWW: freeme:Quite fast for S.A Regarding my ODL20C sample, it is on a much slower boat.
You know they don’t use boats.
I can’t tell if your serious or making a joke. Just to clarify, I meant use boats for international shipping, not for local deliveries.
Lux reading at 15 meter distance between Astrolux MF04, BLF GT and Thrunite TN42
Astrolux MF04 CW
BLF GT NW
Thrunite TN42 CW
Lux reading at 10 meter distance between Astrolux MF04, BLF GT and Thrunite TN42:
Astrolux MF04 CW
BLF GT NW
BLF GT CW
Thrunite TN42 CW
Lux reading at 10 meter distance for the following flashlights.
Nitecore TM38
Acebeam X65
Amutorch JM70
Haikelite MT07 II with XHP70.2 and SMO reflector CW
Haikelite MT07 with XHP70 and OP reflector CW
Utorch UT02
Acebeam EC60
All CW except BLF GT.
Astrolux MF04 cw - Album on Imgur
Measured my Astrolux MF04 with 2 different lux meters and I got as follows:
13210 lux and 12130 lux at 10 meter distance.
So about the same as the GT then.
Your not using the peak hold setting are you? I move the sensor around by hand trying to find that brightest area, but I ignore any sudden peak readings.
Hardusvd70:Astrolux MF04 cw - Album on Imgur
13210 lux and 12130 lux at 10 meter distance.So about the same as the GT then.
Select max on lux meters then moving the sensor around to get max reading.
JasonWW: Hardusvd70:Astrolux MF04 cw - Album on Imgur
Maybe that explains the 2 different readings you got?
Haha, I noticed my readings are forever on the lower side. You guys can trust me for not publishing exaggerate figures just for the sake of sale.
I got higher value for 15m. Maybe you want to give it a try?
JasonWW: Hardusvd70:Astrolux MF04 cw - Album on Imgur Measured my Astrolux MF04 with 2 different lux meters and I got as follows: 13210 lux and 12130 lux at 10 meter distance.
So about the same as the GT then. Your not using the peak hold setting are you? I move the sensor around by hand trying to find that brightest area, but I ignore any sudden peak readings.
From two different model meters.
Hardusvd70: JasonWW: Hardusvd70:Astrolux MF04 cw - Album on Imgur Measured my Astrolux MF04 with 2 different lux meters and I got as follows: 13210 lux and 12130 lux at 10 meter distance.
I will test it at 15 meters and then 20 meters to see what the lux reading will be.
I expressed interest but never received a PM with the code. Can I still get a discount code?
Hi.
Mine arrived today, CW. Works all fine.
Thanks freeme and BG.
@Hardusvd70
You use 3 different luxmeters for your readings comparing different flashlights, could you please reduce that to just one to get a fair comparison? (not saying your readings are wrong, just less accurate like this)
@Hardusvd70
Will do that, busy with that now. I will use the red lux meter for all lights and update.
I got my astrolux mf04 CW today… I shine at the white wall and the beam look great… thank you GB and banggood.
Has anyone had a notification that their NW version has shipped yet?
I’m dead to Banggood. No reply or reaction to anything. :person_facepalming:
I ordered my NW the first of this month. Not shipped yet, but after all I ordered later than most people.
I tested my mf04 CW and got 1930 lumen… I am happy with this light.
