I just got 4 from LiIonWholesale. Same thing as yours. Nothing to worry about. Jon knows his stuff and would never sell anything fake. I’ve been a customer of his for 2 years now. Made over 20 orders. Never once had a problem.
The stickers are required by shipping standards, at least for air shipping. All cells must be clearly labelled. Not sure about surface shipping.
And yeah, 3.5v is about what they have to be shipped at now. 30% state of charge (or less). It used to be 40%.
Some shippers (especially from China) don’t do things by-the-book. I couldn’t care less about labeling, as long as they’re packed properly. I’ve had loose cells from China that could easily have been damaged.
If you’re getting the labels, chances are they’re doing the other more important things properly too.
The vapcell 18350s only had a pre printed vapcell sleeve on them, so that was different. and the vapcells came at 3.9V, so I wondered. But it looks like all is normal, I just did not have any experience purchasing 18650s, so I learned something, which is always good.
I'm always a little cautious with them, especially after I read on amazon I think or maybe it was youtube, but someone said his thrunite battery popped.
I just recently ordered 6 samsung 30Q’s from Liion Wholesale too (4 to feed the BLF Q8 and 2 to feed other single cell quad emitter light) and they came with 3.5-3.65 volts. My question is why it takes so long to get past 3.7 volts or doesn’t seem to charge at all on my Nitecore D4 charger. The 4 to feed the Q8 was in the charger for an hour and saw it barely cracking 3.7 volts and the charger was hot as well as the cells… took them out and re-inserted them and placed a small fan on medium speed. They finally reached full charge 6 hours later. I know the D4 charger’s max charging is 375 mA per channel when all 4 are being used but should it take that long… more like why did it barely charge the cell’s in the first hour (stayed on the first bar blinking on the indicator screen)?
What was also odd was that when I went to charge the remaining two samsung 30Qs, it did the same thing… I had to remove the batteries again (sat their just blinking away at 3.6 volts for an hour) and reinsert them to get them charging. Only this time, with 2 cells, the charging current was 750 mA. Took about 3-4 hours to charge just the 2 cells.
May have to buy a new charger with higher charging current (Folomov A4, I’m looking at you).
If the batteries were fully drained I can see 6 hours at 375mA (375 * 6 = 2,250mAh) and not all of that is going into the batteries. It sounds like a lot was going into heating the charger
Could be the voltage showing on the D4 is way off. Perhaps you can check it against a DMM when you next charge fully drained batteries.
The batteries are probably hot due to the charger being hot. Is that normal for D4’s?
My other 18650’s (AW 2200 mAh) don’t get as nearly as hot or cause the charger to get as hot. I usually run them past 3.5 before charging. My 3 Eagletac Red Tops 3400 mAh 18650s in the Thrunite TN41 don’t get hot either (but warm). It’s probably is time for a new charger for the samsung 30Qs… .
What enderman was getting at. Is the cells were fully charged. And sat for months or year or so it kills the capacity. I’ve seen this with cells I’ve misplaced for months. And when I’ve found them lost 400 or 500 mah. They should be lowered to the factory voltage. If your not going to use them in the next month. But having a couple hundred cells I don’t really worry about it. The recycle bin will give me plenty of new and slightly used cells to replace them
But yes in every battery spec sheet it has a table and they store it for 30 days. And the recovery rate is usually 85 to 90 percent or higher. leaving them at full 4.2 charge. Lithium cells don’t like to be fully charged for months on end. Some spec sheets go by the next charge and discharge cycle some do 3 charge and discharge cycles to see the recovery rate of the mah
If you go to 18650batterystore they pretty much have all the spec sheets on the cells you want. Imr batteries use to link them but they don’t anymore. You can learn alot by spec sheets on various cells.
Charging to 4.1 will get you some more cycles out of the battery and a little easier on the cell. That’s about 90 percent charged. Your not losing much mah
Because the charge rate is so slow around 3.8 is roughly half give or take on the cell. In that hour it only saw 375mah and not all of that made it into the cell. So nothing wrong with the cell it’s just a slow charger. I have the folomov chargers the a2,a4, opus 3100, xstar vc2 among others. Ditch the nitecore get something that can do at least 1 amp across 4 slots. Nitecore makes good lights, their chargers are hit and miss. Usually when hjk test them there are issues they have to fix. At least in the sc2 and another I forgot the name of. Imr batteries you can have the a2 for 15 dollars I think. And the a4 25. My a2 stays at work for if my vape dies I can blast the cells at 2 amps for half a hour and be fine the rest of the day
