This gets back to that Sofirn/Thorfire confusion, (Sofirn has taken over the project now?) but aside from that I look forward to the next gen Q8. Though I’m a bit confused with the configuration. XPL-HI is 3v right? How does 2s work? I’m super newb.
Also I gotta say maybe I’d mount the above pictured “Uber Q16” to my truck for a light cannon but I don’t know how to otherwise use it. I certainly couldn’t carry it on my nightly walk…
(Edit: it suddenly occurs to me I’d better check the Q8 mod thread which I’ve never done. There may be info there I’m unaware of)
Djozz below. That’s nuts! I guess it would be a (bad) way to carry a bunch of cells. Wait, I know! New Olympic sport. Night time pole vault!
I agree that this extension with added parallel batteries is not the most innovative add-on for the Q8 (and it was not an initiative of the Q8 team), but from their perspective this upgrade makes sense as it is easy and not expensive to make and sell, it does add runtime which will appeal to quite some people (the Q8 has a sustainable output of about 2000 lumen, at which output it currently has ~2 hours of runtime, to light your basketball court wanting 4 hours is not exorbitant), and best it fits all the thousands of existing Q8’s.
This long body tube is quite unexpected… It sorts of voids the whole compact soda can concept.
I would suggest a screw in USB charging extension between the head and tube… That would only add about 10-15mm to the length and would make the Q8 easier to gift to non flashaolics.
I don’t see much meaning in a 8P setup for this light. For more runtime it’s easier to carry 4 additional cells separately than their weight and the tubes weight all the time in your hand.
But if the cell configuration can be changed to 2S4P without too much work, I would rather buy this light as a modding host for 6V LEDs for a proper price.
Anyway, for the 4 cell version it’s usually not more than 12000 mAh capacity, and that’s not too much for USB-charging over night, and the cells won’t be completely empty everytime.
What I have seen how the battery carriers are constructed, with some cutting traces and adding wires you should be able to make them 2S4P. Then a 2S driver can be used that has the same battery connection side as the stock Q8. A more neat solution is designing new contact boards for the battery carriers (and upload on Oshpark for everyone to use ) to get this done.
Sounds good, I wouldn’t mind to design the new carrier boards.
I haven’t followed the modding discussions for a while, is a MCPCB for XHP 50/70 available meanwhile?
One concern here, if all 8 cells are run down to minimum voltage, then some bright spark decides instead of swapping them all out (since he only has a 4 bay charger), he will charge one carrier load and insert it, wouldn’t the resulting current from 4x30Q fully charged to 4x30Q fully discharged be rather like welding? There must be some sort of protection against that built in right?
With the proliferation of 4 bay chargers I suspect that charge imbalance would be quite a common problem. One easy way to encounter this would be to run a “normal” test on your cells in a Lii500, and forget that when END is flashing it doesn’t mean the cells are fully charged. Do that once on an 8 cell recharge with this setup and you now have one fully charged set and one set at a random voltage, without being aware. Happens easily.
