FWIW, I have a triple 219b with 7+1 driver and a polished 10511 optic. It uses Crescendo so it does ramping on a clicky switch from 0.2 lm to 800 lm, and it’s one of my nicest lights. The host is a compact 18650 “brass beauty” modded by Dale to prove it could be done.
It may be only 800 lm, but I don’t often want more than that anyway… and it otherwise is tip-top.
Basically, I’m saying a 219b version would be pretty nice… even if you disabled the FET.
here btw is an example of the different strengths and weaknesses of a flood beam with no hotspot and a beam with a hotspot. watch from the 2 minute 9 second mark for the beam comparisons.
Not sure how to add photos, but I played with the manual settings on my camera and set it to 4500k and took a pick with both a Samsung 4000k and Samsung 5000k triple if someone wants them to post.
Yes, I did, but was doing it all in a browser on my phone so everything was so damn small it was difficult to tell what was what. Should already be corrected.
Maybe pull your link in your post so not to confuse people. I took mine out as well to make sure just one post of pictures with correct temp is posted.
Highly doubt they are the high CRI. And they are awesome even at that. I’ll have to trace the exact ones back to find out. But if these are not, then their high CRI versions will be hands down the best ever!
I have the 5K 80CRI in a Sofirn C8F and it’s fine. Even beam, super high output. It appears maybe a touch under 5K when I compare it to a 219C 5K. I see no reason the 90CRI would be any different.
D4 219C 5K 80CRI next to a C8F LH351D 5K 80CRI. White balance set at 5K
C8F XP-L2 5k 70CRI next to a C8F LH351D 5K 80CRI. White balance set at 5K
In addition the LH351D outperforms the XPL2 at turn on and at 30s, despite being 80CRI
