I’d hardly call my Q8 scorching after a minute of turbo with spring bypasses and Luxeon Vs. Stock it never got hot at all even after several minutes just warm to the touch and I clocked mine in around 4500. All temp regulation off. After bypasses it gets warm a lot faster, but still nothin like the Emisar D4.
I wanted to get carryers for modding from the beginning, but the team has declined becaus it should be SRK-Style.
Now, that would be great.
And we will see, how the carryers could be modified. There seems to be only the center bar, which could be used to make Bat+ contact from the end to the top. The other bars are used for battery- or ground.
So with different carryer PCBs it should be possible to make a 2S2P or 4S1P variant.
Ok, now we have a MCPCB for XHP50, we’ll hopefully soon have the new battery tubes, now I need an affordable source for well binned XHP50 or XHP50.2 in neutral or maybe warm white. Are XHP50.2 suitable at all for a FET driver? I guess I have read somewhere they have a lower forward voltage than XHP50.
This is a good question but not because of the voltage. I have a XHP50.2 running fine without driver on 2 high drain 18650 batteries so at least some XHP50.2 leds can handle that. But I had one dying at much lower current in a light with 3A boost driver from KD. Something with a sensitivity for unseen voltage spikes?, I don’t know. At least the Q8 will not use a boost driver but a simple direct FET driver, could be advantageous for the XHP50.2
We (the Q8 team) had a flashlight made with one very well thought-over led choice for simplicity of the process. We never intended to proceed the Q8 project after that with extra versions, so just waiting for a cool white version to spontaneously happen was not a very favorable approach.
But now that Sofirn is involved that may be different, they tend to listen to what is popular on BLF. So ask them for a cool white version and convince them that it will sell.
I use an even worse setup and it works every time.
I have an induction cooktop and use a super old rusty one of these with knife marks on it. I dont recommend it because when it gets hot and cools off the center has a tendency to “pop” in and out with temp changes.
I spent so much time on this project that I feel like a Q8 Team Member.
Remember back when it was said that once the group buy was over Thorfire would take over and possible rename the light and do whatever they wanted? I was really hoping they would add a CW option. It seemed like a no brainer as the majority of flashlight buyers in the world (excluding BLF and CPF) prefer CW.
At this point in time I have no idea if a CW version would sell. I may be the only person in the world that wants this, but I’m not willing to pay double the price to modify it. I don’t need it that badly. I’ll just wait and see what Sofirn does.
Being a novice to all of this stuff I find soldering e-switch wires (or anything for that matter) 1000x harder to do than reflowing. If you practice once or twice with the right solder paste and an old MCPCB I have no doubt u can figure it out.
