In for 2.
Digikey sells them in quantities as small as 1.
Deleted.
@Toykeeper, you were right.
We can order 5000k 90CRI emitters.
You know what is funny though?
I just contradicted myself from a few weeks earlier from the BLF lantern thread where I linked all of the LEDs.
Here:
Here is 5000k 90+CRI:
Here is 4000k 90+CRI:
Here is 3500k 90+CRI:
2700k 90+CRI:
Highly doubt they are the high CRI. And they are awesome even at that. I’ll have to trace the exact ones back to find out. But if these are not, then their high CRI versions will be hands down the best ever!
Thanks TK and thanks BlueSword for the links, is there anyone yet who has tested a 5000k 90+CRI?
I am down for one already (#219), please add me for another, total (2)
Side question, is anyone else not able to get to the tint/emitter polls, the pages will not load for me
I have the 5K 80CRI in a Sofirn C8F and it’s fine. Even beam, super high output. It appears maybe a touch under 5K when I compare it to a 219C 5K. I see no reason the 90CRI would be any different.
D4 219C 5K 80CRI next to a C8F LH351D 5K 80CRI. White balance set at 5K
C8F XP-L2 5k 70CRI next to a C8F LH351D 5K 80CRI. White balance set at 5K
In addition the LH351D outperforms the XPL2 at turn on and at 30s, despite being 80CRI
How is the LH351D outperforming the XP L2? I do know the LH351D is the most efficient singular 3V LED on the market, but it does have a higher forward voltage than the XPL2.
Does that means that the higher CRI variants of the LH351D have much lower forward voltage?
We need to send one 80CRI and one 90CRI LED to Texas Ace to see if my suspicion is true, or to Maukka.
Maukka has already tested both @ 2A. I think the vf is similar enough that at 30s the extra output of the LH351D still wins out.
No actually, that is only for the LH351D 70CRI.
Higher CRI LEDs usually have lower forward voltages.
In the case of the 351D 80 and 90CRI, at 3A, the forward voltage of the 351D is actually lower than the XPL2.
It is actually lower!
3,28V at 3A vs 3,31V at 3A of the XPL2! The forward voltage of the 80 and 90CRI version is the same, and since the LH351D is more efficient than the XPL2.
That means the LH351D 80CRI actually has a lower forward voltage and higher efficiency than the XPL2, at 80CRI!
Cree needs to make a XM-L3/XP-L3 soon or they will lose market share.
Isn’t this what I said at first in so many words?
Both 80 CRI
Set to 4500k on the camera
5000k Samsung
4000k Samsung
Note: ToyKeeper had shown a comparison once between lights of all sorts of CCT and CRI; the camera > jpeg > screen can definitely limit your ability to tell the difference in quality - for instance, the well-known 219b sw45k wasn’t that much different in the picture from the other lights. I expect if it was needed, the 80cri version of the samsung would be okay; but there’s 90cri so no need.
I would be interested in a 219c version and a xpl-hi version. What is the expected completion date? I’m kinda late to this party and this is a huge thread. Awesome configuration.
Hondarider: We hope it could be sometime soon, but nothing solid. As for your emitter interests, you will want to skim the last ~10-15 pages for some of the good info on the subject, then look at something like 10-11 pages ago for the poll link.
Yes, the polling site seems to have gone down yesterday, but it came back today. Not sure what the issue was.
The links are at the top of the first post.
Ah, right. I knew that existed for a reason.
Hi HONDARIDER .
The emitter is not decided.
And, according to the survey, See Emitter type , Nicha 29C has little chance
Just say how many flashlights you want, or you prefer to wait and see what the emitter will be.
How many flashlights do you want in total? … x … units? .
I’m waiting for your answer,
Please: answer in thread
