Don’t you have an electric skillet?It work wonderfully with reflowing MCPCBs.
Buy yourself a 10$ one like I did, and you will be off to cool white land.
Along with some solder paste of course.
I use an even worse setup and it works every time.
I have an induction cooktop and use a super old rusty one of these with knife marks on it. I dont recommend it because when it gets hot and cools off the center has a tendency to “pop” in and out with temp changes.
I spent so much time on this project that I feel like a Q8 Team Member.
Remember back when it was said that once the group buy was over Thorfire would take over and possible rename the light and do whatever they wanted? I was really hoping they would add a CW option. It seemed like a no brainer as the majority of flashlight buyers in the world (excluding BLF and CPF) prefer CW.
At this point in time I have no idea if a CW version would sell. I may be the only person in the world that wants this, but I’m not willing to pay double the price to modify it. I don’t need it that badly. I’ll just wait and see what Sofirn does.
Being a novice to all of this stuff I find soldering e-switch wires (or anything for that matter) 1000x harder to do than reflowing. If you practice once or twice with the right solder paste and an old MCPCB I have no doubt u can figure it out.
Thorfire taking the design and doing whatever they wanted with, and they did not do anything
Looking at how Thorfire refuses to sell any replacement parts, it does not surprise me that they did not do this. I think it is because the BLF Q8 is a constant stream of revenue for them, and any departure from the original design would disrupt that revenue flow, so they are not willing to take any risk to change the design or do what they want with the Q8.
TLDR: The original BLF Q8 is good enough for Thorfire not to take any R&D risks.
This is a good question but not because of the voltage. I have a XHP50.2 running fine without driver on 2 high drain 18650 batteries so at least some XHP50.2 leds can handle that. But I had one dying at much lower current in a light with 3A boost driver from KD. Something with a sensitivity for unseen voltage spikes?, I don’t know. At least the Q8 will not use a boost driver but a simple direct FET driver, could be advantageous for the XHP50.2
Strange. Both LEDs from the same batch? Was the dead LED soldered properly or could it have been too much heat (don’t know in which light this LED has been used)?
At this point in time I have no idea if a CW version would sell. I may be the only person in the world that wants this.
I want one as well!!!
Hopefully they will offer the CW option!!!
There was brief talk of the haikelite mt07s tubes being made available which lego with the Q8. You just need to line up the tube once then the tailcap just works to support cells in series. That still may be easier than redesigning carriers.
Except for the fact that it’s Haikelite :confounded: and they already said they dont want to sell just tubes
I’d hardly call my Q8 scorching after a minute of turbo with spring bypasses and Luxeon Vs. Stock it never got hot at all even after several minutes just warm to the touch and I clocked mine in around 4500. All temp regulation off. After bypasses it gets warm a lot faster, but still nothin like the Emisar D4.
Have you removed the stock thermal regulation? If you remove it in the settings for q8 will get scorching hot on turbo. Not in 1 minute but it does.
This is really disappointing in my opinion from thorfire. The q8 was designed so people could easily MOD it. Spare parts should be readily available. Like I need an new battery tube. Mine is damaged. So thank you for the link.
And thank you Sofirn for people up the slack from thorfire. Really disappointed in thorfire
Why don’t I have a rope to hang on such a long thing, so heavy and heavy? I have to carry 8 18650 batteries with me. I think this design is a failure
I use lanyards on my lights whenever possible. This makes it possible with the Q8.
This light should be popular among those that want to carry a flashlight as a self defense weapon. Add a several battery tubes and you have yourself a nice bat.
Ummm, almost 200bux for a 4pak? Pass…
I got these for a buk each.
It was $7 for me. 2 day Prime delivery.
I’m going to get one, some people might not care for it. But I have use for the extended run time without having to change batteries. When your covered in paint overspray having to clean up some to change batteries gets aggravating. At the park it’s not as big of a deal. But I use my light for work. I would also like the q8 with a little more throw. Should be easy enough to MOD for those that want to do 6v emitters. But I feel it’s kinda over kill. All the monster can lights with 6v emitters all overheat in a minute or so. Ya we will get 12000 lumens for 1 minute with that set up. I’d rather 5000 lumens for a couple hours for my use.
I think that is a bit too ambitious. 5000 lumen is stock and it heats up quick to the thermal limit. 2500 to 3000 lumen might be sustainable.
Any news on this?
Not really.
Bump. Sofirn taking on too many projects
