Higher CRI LEDs usually have lower forward voltages.
In the case of the 351D 80 and 90CRI, at 3A, the forward voltage of the 351D is actually lower than the XPL2.
It is actually lower!
3,28V at 3A vs 3,31V at 3A of the XPL2! The forward voltage of the 80 and 90CRI version is the same, and since the LH351D is more efficient than the XPL2.
That means the LH351D 80CRI actually has a lower forward voltage and higher efficiency than the XPL2, at 80CRI!
Note: ToyKeeper had shown a comparison once between lights of all sorts of CCT and CRI; the camera > jpeg > screen can definitely limit your ability to tell the difference in quality - for instance, the well-known 219b sw45k wasn’t that much different in the picture from the other lights. I expect if it was needed, the 80cri version of the samsung would be okay; but there’s 90cri so no need.
I would be interested in a 219c version and a xpl-hi version. What is the expected completion date? I’m kinda late to this party and this is a huge thread. Awesome configuration.
Hondarider: We hope it could be sometime soon, but nothing solid. As for your emitter interests, you will want to skim the last ~10-15 pages for some of the good info on the subject, then look at something like 10-11 pages ago for the poll link.
Hi HONDARIDER .
The emitter is not decided.
And, according to the survey, See Emitter type , Nicha 29C has little chance
Just say how many flashlights you want, or you prefer to wait and see what the emitter will be.
How many flashlights do you want in total? … x … units? .
I’m waiting for your answer,
Please: answer in thread
I don’t know what happened, but average poll results have been changing over time. I did a quick dirty heat map graph of the results at three different times… 06-10, 06-13, and 06-15. And I noticed some patterns:
People who voted early were more likely to prefer warmer temperatures, LH351D, and 219c.
People who voted later were wore likely to prefer cooler temperatures and XP-L HI.
People who voted in both polls, and used the same name on both, ranked Cree emitters higher, and ranked 4500K to 5000K tints higher, than those who voted in only one poll or didn’t use the same name on both.
I’m not sure if this is interesting to anyone except me, but below are the result snapshots plotted as heat maps.
Correlated votes (people who voted on both polls and used a consistent name) (excludes anons):
2018-06-10:
2018-06-13:
2018-06-15:
All votes (no correlation data included):
2018-06-10:
2018-06-13:
2018-06-15:
Based on what I see in the correlated vote maps, it looks like, if there can be two flavors, the flavors should probably be:
XP-L HI 3D
LH351D 4000K
Those are the two emitter bins which are closest to the hotspots in the data. And after those, the next most-popular spot appears to be 219c 5000K.
2018-06-10:
2018-06-13:
2018-06-15:
2018-06-10:
2018-06-13:
2018-06-15:
XP-L HI 3D
LH351D 4000K
Wow… I find it very interesting. Pretty amazing really. :+1:
It took me a minute to figure out what the “hotspots” were … but after that it all started making sense.
One question… what are the numbers at the bottom of each square??
It looks to me like 5000K for the LH351D is a bit hotter on the heatmap than 4000K. I slightly prefer 5000K, but would be happy with either as long as a Samsung option gets produced.
The LH351D is not available in 4500K. It is offered in 4000K and 5000K.
Since the 219c 5000K is available as a D4, one each of the other two as an FW3A pretty much covers the market. I know there were a few of us waiting for the FW3A and putting off a D4 purchase.Maybe D4 availability was a factor in the 219c receiving fewer votes.
