I think I should start manually breaking the contacts too on some of mine. I like the lighted switches on my shelf and the drain is so low that when I do check battery voltage, it doesn't move much, but there is that tiny risk factor that all of a sudden a fault shows up and they do drain fast.
Just received my Mateminco MT35 Plus in the mail 2 days ago, took 6 wks from order time. Have not had a chance to play with it yet, with working and helping Wife babysitting Grandchildren all week.
Not sure why Alibaba is making these, guess they will be in a contract with Astrolux to build the MF04. You guys are experienced with China and hoping you can shead some light on the process.
Here is a link for more info and pics by a “Mr. Mak” ( I’m guessing ). You will need to translate the language.
Note: You can run 2 flashlight heads together at the same time, see the pics in the link.
I believe Alibaba is just a storefront made up of many different suppliers. Something like that. They don’t actually make anything.
Mateminco is the company making the lights and they sell them in China as the Mateminco brand or sell them internationaly as Astrolux through Banggood. Astrolux is Banggoods house brand.
Nice. I am glad you like it. i think astrolux nailed it…
Pros…
Will shine 1.89 km or 1.17 mles. ( from steel beamshot )
Led is perfectly centered and sit correctly…
boost driver.
Very efficient…
4 modes… nice and simple!
New upgrade design battery carrier
Improved and solid indicator switch.
CW or NW option available.
This makes sense as the MF01 v2 driver is 21v out and can do 12000 lumen or so. So its more than powerful enough for a single xhp70.2. I’m sure this driver can do 12v at about 5A to 6A. So it’s maybe over 6,000 lumen? It gives steady output as well.
