Folomov EDC-C4
Introduction: Folomov reached out to me and offered the opportunity to review their recent light, the EDC-C4. While the flashlight was provided for free, I try to be unbiased.
Fit & Finish: The EDC-C4 arrived in nice retail packaging with an included protected 2600 mah 18650 battery. The overall construction is pretty good. Iām not a huge fan of square knurling, but itās clean and it works. The anodizing is decent, slightly on the shiny end of the spectrum. And the finish is slightly different between the head and the body.
LEDs & Tint: This Folomov uses a cool white XP-L LED. Itās not stated, but perhaps in the 6500K range with a hint of blue in the beam which is very clean overall. If youāre wall hunting, there is a single outer ring, but I donāt find it bothersome. Unlike many of Creeās newer chips, I havenāt noticed much tint shift with this XP-L. The reflector is very clean and shallow, resulting a floody beam.
Modes & UI: The EDC-C4 has four standard modes rated at 1200 - 200 - 75 - 10 lumens. My rough lumen estimates (DIY lumen tube) are relatively close to that: 1271 - 362 - 165 - 4 lumens using the included battery. Pretty good numbers, but Iād say the jump from low to medium is a bit too large. The mode order is L - M - H - T - H - M - L (ramp up and back down as opposed to wrapping) with mode memory. Strobe, SOS, and Beacon are present but (thankfully) hidden behind double clicks. Lockout can be enabled with a triple click.
USB Functionality: A micro-USB port is present and can be used to both charge the flashlight and to serve as a powerbank (say, to charge a phone). The cord to take care of these tasks was included. While I donāt typically rely on built-in USB charging, itās a nice feature to have in a pinch. The same goes for powerbank capabilities.
Conclusion: The Folomov EDC-C4 is pretty compact (short!) for a 18650 flashlight. Itās solid overall, and bright. I like the fact that it comes with a battery. To me, the one place where I struggle with this flashlight is pricing. At the time of this writing, the EDC-C4 is $43 on Amazon
Some size comparisonsā¦
