I would like to buy one of these flashlights please! LH351D preferred. I will look for how to send payment.
When they are ready for sale you will be sent a Personal Message through this forum. You should also recieve an email to let you know you have a new “PM”.
It should be at least a couple more months, but might be longer depending on how things go.
Texas Ace Lumen Tube calibrated with Maukka lights
A colour checker would at least free us from endless quoted mentos pictures
Huzzah!
joechina wrote:
Have the prototypes an AR coating? If the FW3A gets the 90CRI Samsung it would be better without, or?
The prototypes appear to have a mild AR coating. I haven’t seen one in neutral white yet, so I don’t know if it has any significant effect on tint, but it’s definitely not the painfully blue coating on some lights.
FWIW, the lens is 23.0 mm x 1.5 mm. Anyone got a link for lenses of this size?
The FW3A uses the Andúril firmware by ToyKeeper. It is similar to Tom E’s fantastic NarsilM, but with some extras.
Basic usage is very simple: Click for on/off, hold to change brightness. But there’s much more available for those who want it.
This is the UI diagram for it, showing most of the functions:
The interface uses mostly the same ramping as Narsil, and basic usage is identical. Click to turn the light on or off, hold the button to change brightness. However, this style applies to both the smooth ramp and the mode group, and the user can switch between them with three clicks while the light is on. No need to remember two interfaces or navigate a config mode.
Ramping also has some additional usability tweaks. If the user holds the button, ramping will always go up unless the button was released less than a second ago or it’s already at the top. To ramp down without ramping up first, do a “click, release, hold”. This eliminates the need to remember which way it was ramping in the past.
Both the smooth ramp and mode group are configurable. The user can set the lowest level, the highest level, and (mode group only) the number of steps. Full turbo is still available via double-click even if the ceiling is set somewhere more sensible.
While on, a double click toggles between turbo and the memorized level. So, if you hear a noise and want full power for a moment, double click. When you’re done, double click again to return to the original brightness.
Two groups worth of blinkies are included. To reach them, do “click click click” from off or a “click click hold”. These include:
Group 1: (always starts at battcheck)
BattCheck: Show remaining charge in volts and tenths.
Sunset: Start at “low”, then slowly ramp down to moon for an hour, then turn off.
Beacon: Blink once every N seconds at the last-ramped level. N is configurable.
TempCheck: Show current temperature and optionally configure settings for thermal regulation.
Group 2: (remembers the last-used mode)
Bike flasher: Steady output with a “stutter” once per second. Adjustable brightness.
Party strobe: Motion-freezing strobe. Adjustable speed.
Lightning storm: Exactly what it says on the tin. No adjustments available.
Candle: Simulates a flickering candle or fireplace. Adjustable brightness. Also works as a self-shutoff timer in 30-minute increments.
A few other modes are available by clicking even more times from off:
4 clicks: Soft lockout. Light won’t turn on until it’s unlocked. This mode doubles as a momentary moon mode, so when the button is held down it’ll light up at the current ramp floor. This is handy for checking something quickly without having to unlock the light.
5 clicks: Momentary / signalling mode. Using the last-ramped brightness, the light will be on when the button is held, or off otherwise. Good for Morse code and such. To exit this mode, physically disconnect power (unscrew the light).
6 clicks: Muggle mode. An extremely simple interface with a limited brightness range — ~10 lm to ~300 lm, with smooth ramping and no blinkies. Persists after a battery change. To exit this mode, quickly click exactly 6 times.
Some features which aren’t visible on the diagram:
Low voltage protection will reduce the brightness when the battery is low. If the brightness is already down all the way, it will shut the light off entirely.
Thermal regulation keeps the light from overheating. It’s not normally visible by eye though; it ramps smoothly across 512 internal steps to adjust output while it searches for the highest level it can maintain without overheating.
By default, the ceiling is set to the highest fully-regulated output level — 3 Amps. This is about 1000 lumens. Full turbo is about 3000 lumens, but cannot be sustained for long due to the heat it creates.
There are also some other interfaces available for this hardware, but it requires the user to flash different firmware. You can make it work like a BLF Q8, or like an Olight, or like a Zebralight, for example. However, these are not tested and not officially supported.
A lot has been said about the taper, finish (or lack of), optics, and emitters and everyone seems like they’ve said what they wanted to say. Haven’t seen a whole lot about the UI and wanted to add:
At this price point I’d buy the light if it was shaped like a turd, had a cool emitter, and had a lousy optic. The most exciting part of this light IMHO is this amazing interface.
Excited about Candle, Sunset, Beacon, LVP, User configurable ceiling (Yes!!), and pretty much everything about it. Toykeeper went all out for this to be special, thank you for your hard work!
This is the stuff or >$100 lights. What’s gonna happen at CPF when this thing pops up as THE light to buy? Should be interesting.
I use beacons at work to remind me that there is another process going on that I need to check occasionally.
Sunset and Candle will be for for bedtime. Not good to sleep with illumination on, this will be nice for winding down.
I’ll even have fun with Lightning storm and Party Flasher when the grandkids come over.
I am more impressed by longer runtimes than max output so I’ll happily set the Ceiling to ~300 lumens.
Anyone else have any use scenarios or plans for the new UI?
Amen to those two statements my friend!!! . You nailed it.
The first one is ‘famous BLF quote material’ in my book too…. .
.................................. "Slow is Smooth, Smooth is Fast" ...................................
You’re right, Andúril is awesome. It has totally spoiled me.
I’ve been using Andúril since last September when ToyKeeper first released it. I now have it running on the Emisar D4, D1, and D1S, three Q8s, a GT, a swapped X6R, and a swapped Meteor.
Muggle mode is one of my favorite features because I love sharing my lights. It’s great to lend someone a high-powered light without worrying they will burn/blind themselves, enter setup or strobe, or otherwise get confused or frustrated. I click six times to enter muggle mode, hand them the light and say, “Click to turn it on and off. Hold to change the brightness.”
Momentary mode is great for hiking. I wear a headlamp on a low or medium mode and keep a D4 on a high-ish momentary mode. Perfect for a quick look around when reaching a clearing or looking for a landmark. Momentary is cancelled only by disconnecting power, which means no sequence of clicks will accidentally exit it.
Beacon mode has adjustable brightness AND adjustable interval.
I set the ramp ceiling at turbo-50 on my Nichia D4. This is plenty bright for most of my needs, and won’t heat up in just seconds. Turbo is still only a double click away.
Adjustable frequency party strobe mode is fun. I froze a fan’s motion the other day. Tactical strobe is adjustable too, in case you want to try to make yourself sick.
Lockout also acts as a momentary mode set at a low level. Very handy.
I’m excited for Andúril to be installed on a factory built light so that lots more people can enjoy it.
Teacher, it’s true! Who among us hasn’t bought a light that looked great, had our favorite emitter, but the UI was lame? I’ve always thought “I’ll adapt” but wind up giving them away.
I’ve adapted to the Skilhunt H03 UI because I use headlamps differently than pocket lights.
Wouldn’t want it on an EDC.
I’m so stoked about this UI I’m slowly trying to figure out flashing attiny chips so I can put it on some other lights.
The bonus with this light is that it most certainly does NOT look like a turd and won’t have lousy emitter/optic combo.
When I got a ZL SC62d it almost killed the hobby for me because it is such a great light.
I predict this light may slow down my purchases but the UI and the prospect of putting it on other lights and lanterns opens up a whole new branch of the hobby. I used to have a blast doing emitter swaps but that has died down since it’s become pretty simple to buy a light with a decent emitter.
Thanks again to all involved!
Edit: thanks for those details goshdogit! Those little things appeal to me. I hear from non-enthusiast “it’s just a flashlight” but these “little” things turn it into a Versatile Lighting Tool which really does let you do so much more than a flashlight and do it with a sophistication and accuracy that cannot be replicated by a light you’d get off a pegboard display at a hardware store.
Click this to go to signature links.
I’m in for 2 please!
1 please. UK here
Huzzah!
I would like 1 please!
I could have sworn that I signed up earlier but don’t see my name. I want one too. Thank you.
I’ll take 2 please
You did and your name is on #1217. Please see the post #4
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
Im interested….. add me to the list……. thx!
Im not a Pessimist …. just an Optimist with a lot of experience
I’m in for 2 please.
In for 1
I would really appreciate to be added to the list for one.
Excellent, thank you!
Updated list : … . . . . . . . . . . C L O S E D
Primary Interest List, (main): See Post # 4, Page 1 .
pepinfaxera: Interest List: See #Post , Page 111
pepinfaxera: Interest List, duplicate: See # Post , Page 71 ,
Apologies, I’m sorry..
1233 – # Post . bansuri
New requests:
Correcting: …
1125 – # Post . Bob_McBob
I need to edit list.
Greetings.
-18 Off : # Post . DB Custom , See # Post . … “Delete, Remove”
-1174 Off : # Post . CM2010 , See #Post . … “Delete, Remove”
-931 Off : # Post . darrylo 3nd … “Delete, Remove”
-932 Off: # Post . darrylo 4nd … “Delete, Remove”
-1344 Off : See # Post Coscar, delete , “Remove”
1234 – # Post . mniezen
1235 – # Post . mniezen
1236 – # Post . FBsLights
1237 – # Post . preface
1238 – # Post . whopist
1239 – # Post . jaynick
1240 – # Post . jaynick
1241 – # Post . jaynick
1242 – # Post . tjl014
1243 – # Post . tjl014
1244 – # Post . Cutchya
1245 – # Post . I LIKE FLASHLIGHTS
1246 – # Post . DoubleU
1247 – # Post . ActiveAl
1248 – # Post . severide
1249 – # Post . Tarvos
1250 – # Post . Tarvos
1251 – # Post . kmwc72 CN
1252 – # Post . kmwc72 CN
1253 – # Post . ActiveAl
1254 – # Post . Lion42
1255 – # Post . Lion42
1256 – # Post . andyxxx
1257 – # Post . andyxxx
1258 – # Post . flashycali
1259 – # Post . Aussie78
1260 – # Post . dmsoule
1261 – # Post . dmsoule
1262 – # Post . manithree
1263 – # Post . tvizk
1264 – # Post . raqin
1265 – # Post . retsyx
1266 – # Post . Bervilat
1267 – # Post . kubed_zero
1268 – # Post . kubed_zero
1269 – # Post . korylprince
1270 – # Post . Ratus
1271 – # Post . Edindevon
1272 – # Post . GalaxyWide
1273 – # Post . Medicijnman
1274 – # Post . Nash_Vegas
1275 – # Post . Moomoomao
1276 – # Post . Moomoomao
1277 – # Post . Brinkmann
1278 – # Post . Brinkmann
1279 – # Post . bonfire
1280 – # Post . Moparguy
1281 – # Post . Moparguy
1282 – # Post . .-’_
………….. – 1282 See: .-’_
1283 – # Post . Nooner
1284 – # Post . Atom00
1285 – # Post . javipiloto
1286 – # Post . Lfatman
1287 – # Post . DarkParagon
1288 – # Post . Crazy999
1289 – # Post . LanternGuy
1290 – # Post . samnavy
1291 – # Post . Random Dan
1292 – # Post . finnegans
1293 – # Post . TheSoulless78
1294 – # Post . wiley07
1295 – # Post . jinjin19
1296 – # Post . QwertzHz
1297 – # Post . Cyzan
1298 – # Post . Cyzan
1299 – # Post . cujo255
1300 – # Post . geetee03
1301 – # Post . apurva
1302 – # Post . apurva
1303 – # Post . Marubae
1304 – # Post . HONDARIDER
1305 – # Post . HONDARIDER
1306 – # Post . yokomus
1307 – # Post . Chatika vas Paus
1308 – # Post . Chatika vas Paus
1309 – # Post . Snoballz
1310 – # Post . spaceminions
1311 – # Post . Mr.Scott
1312 – # Post . lohtse
1313 – # Post . lohtse
1314 – # Post . brettr1
1315 – # Post . gkushev
1316 – # Post . gkushev
1317 – # Post . wiley07
1318 – # Post . wiley07
1319 – # Post . Yoav.Klein
1320 – # Post . Bd7
1321 – # Post . alejo
1322 – # Post . hiker89
1323 – # Post . hiker89
1324 – # Post . hiker89
1325 – # Post . NordicMist
1326 – # Post . wheelgunwordslinger
1327 – # Post . Dsvist12
1328 – # Post . Dsvist12
1329 – # Post . Doobyscoo
1330 – # Post . mrgreengenes42
1331 – # Post . misterpearguy
1332 – # Post . MobileEMP
1333 – # Post . MobileEMP
1334 – # Post . MobileEMP
1335 – # Post . rennet
1336 – # Post . lew123
1337 – # Post . zeroflow
1338 – # Post . duhduhduhdiabeetus
1339 – # Post . Nortson
1340 – # Post . Hallamski
1341 – # Post . michaeltmohr
1342 – # Post . Glas4d
1343 – # Post . Glas4d
1344 – # Post . Coscar
-1344 – See # Post Coscar, delete
1344 – # Post . gemmell
1345 – # Post . gemmell
1346 – # Post . a_idiot
1347 – # Post . jaharkes
1348 – # Post . madness
1349 – # Post . arisdes
1350 – # Post . Zeratull
1351 – # Post . severide
1352 – # Post . TheShadowGuy
1353 – # Post . Cursecut3r
1354 – # Post . Hesh24
1355 – # Post . Tony Cape
1356 – # Post . sbslider
1357 – # Post . LightUpTheDark
1358 – # Post . Jagger
1359 – # Post . soldsoulrockroll
1360 – # Post . ReallyInToCheese
1361 – # Post . noobsanpu
1362 – # Post . BurningPlayd0h
1363 – # Post . headburger
1364 – # Post . Phaze13
1365 – # Post . Iselldrugsforgolf
1366 – # Post . Typevii
1367 – # Post . tkd15
1368 – # Post . xikteny
1369 – # Post . bushmaster
1370 – # Post . kevinw0lf
1371 – # Post . scottie888
1372 – # Post . Gondwanaland
1373 – # Post . cannesahs
1374 – # Post . Polyesterboy
1375 – # Post . the0dore3524
1376 – # Post . Stereodude
1377 – # Post . CitizenK
1378 – # Post . bento_blf
1379 – # Post . klrman
1380 – # Post . yokomus
1381 – # Post . KJ4BXT
1382 – # Post . KJ4BXT
1383 – # Post . ale9g
1384 – # Post . Penguin
1385 – # Post . Penguin
1386 – # Post . waxing twilight
1387 – # Post . Roc32
1388 – # Post . Roc32
1389 – # Post . iamlucky13
1390 – # Post . Mops1
1391 – # Post . Mops1
1392 – # Post . wheremydonky
1393 – # Post . wheremydonky
1394 – # Post . wheremydonky
1395 – # Post . psumo
1396 – # Post . adirus
1397 – # Post . geetee03
1398 – # Post . zotee123
1399 – # Post . anycolourfloyd
1400 – # Post . CabalGrim
1401 – # Post . Lick
1402 – # Post . ttylamg
1403 – # Post . Cereal_killer
1404 – # Post . Jay
1405 – # Post . mb200k
1406 – # Post . stolikat
1407 – # Post . TonyG
1408 – # Post . asciiphil
1409 – # Post . Fady
1410 – # Post . Fady
1411 – # Post . Fady
1412 – # Post . lucydog
1413 – # Post . lightknot
1414 – # Post . lightknot
1415 – # Post . xertian
1416 – # Post . xertian
1417 – # Post . Enlightened1
1418 – # Post . Enlightened1
1419 – # Post . elnino
1420 – # Post . gottawearshades
1421 – # Post . 3061fps
1422 – # Post . andrewmac
1423 – # Post . andrewmac
1424 – # Post . firstcipher
1425 – # Post . skinny_tie
1426 – # Post . Nooner
1427 – # Post . Cereal_killer
1428 – # Post . Cereal_killer
1429 – # Post . bushmaster
1430 – # Post . kollers
1431 – # Post . Geese
1432 – # Post . caplang
1433 – # Post . vadimax
1434 – # Post . MonkeyLight
1435 – # Post . MonkeyLight
1436 – # Post . MonkeyLight
1437 – # Post . MonkeyLight
1438 – # Post . justaguy
1439 – # Post . justaguy
1440 – # Post . HeavyD3
1441 – # Post . HeavyD3
1442 – # Post . knuckles
1443 – # Post . Mops1
1444 – # Post . thejinn
1445 – # Post . fusion_m8
1446 – # Post . justanotherguy
1447 – # Post . Geese
1448 – # Post . JohnnyUtah
1449 – # Post . loki993
1450 – # Post . e1000
1451 – # Post . jamio
1452 – # Post . hodor
1453 – # Post . Ilmatic
1454 – # Post . Ilmatic
1455 – # Post . atasuke_
1456 – # Post . AcIDsNaZz
1457 – # Post . Desert Lumens
1458 – # Post . bulbeee
1459 – # Post . Melven
1460 – # Post . neBstress
1461 – # Post . autoxer
1462 – # Post . RichardBrown
1463 – # Post . Valerianis
1464 – # Post . takumi86
1465 – # Post . Gravedigger1
1466 – # Post . MascaratumB
1467 – # Post . RandyC
1468 – # Post . RandyC
1469 – # Post . coban
1470 – # Post . coban
1471 – # Post . eas
1472 – # Post . Delta_V
1473 –
1474 –
1475 –
1476 –
1477 –
1478 –
1479 –
1480 –
NOTE: If I overlooked a post, PLEASE IM me and i’ll edit for correction.
. -. . . . . . . . . . C L O S E D
Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
Can you put me down for one please?
You can never have too many torches........just not enough darkness
I’m interested in one, thanks.
In for 1!
@pepinfaxera Can you add me in for one more please. For a total of 2. Thanks!
I’m in for one. Two if it is available in a warm high CRI option.
Sign me up for 1 please.
Hello,
The emitter is not decided.
Greetings.
How many flashlights do you want in total? … x … units? .
Okay, sorry about that!
I would like 1 possibly 2 depending on final price. Thanks
bansuri wrote:
. You nailed it.
Texas Lumens Flashlights / M4D M4X Deals : sign up - save $$$$
Rudeness Level _ mΩ _ {width:70%} _ LightWiki _ LED Tint Chart
Xlamp size chart _ BatteryU _ Flashaholic? Need Professional Help??? TheOriginal _ TAB _ LightSearch _ BatterySearch _ 14500's _ DiCal
TL;DR: Andúril = amazing. ToyKeeper = genius.
/\ …. Exactly bansuri… well said again!! .
I agree with you both.
