That’s what I meant. It’d be two caps with contact boards and a cable to connect them. If it was used with the upcoming extendable battery tube, battery life could be made virtually limitless. I’ve seen pictures of a solution like this, but no details. It could work with 3d printed parts too, which would keep weight down further.
I used a ‘50mm quick-release truss clamp’ to make a tripod mount for my Noctigon Meteor M43, which lacks a threaded hole. The Meteor and Q8 both fit nicely in the 50mm truss clamp. I stretched some old tubes onto my clamps to increase friction and prevent scratches.
For mounting to a bike or ATV, connect another smaller clamp to grip the handlebars. This makes the light’s angle easily adjustable.
Be sure to use a quick-release truss for the light’s end, so you can easily detach the Q8 when you’re not riding. It seems the smaller diameter clamps aren’t widely available with quick-releases.
uhm… I was in the first batch list for the Q8, but then I gave my reservation up to someone else because I was in tight circumstances… but now of course I regret :s I payed 40 USD for the D4, which is worth it, but this massive light for the same price was just a gift… wondering what is the lowest price it has been sold after that. I remember deals around 50-55 usd… has it ever dropped to 40 again?
Have been playing with my new toy - BLF Q8 and still loving it.
While playing with the Q8 last night I noticed something that is not on the owner’s manual or the cheat sheet so I thought I would post my observation here to see if I can get more information on this unlisted “feature”.
Ok so this is what I did:
1) From off, hold and ramp up the brightness till it started to ramp up and let go of the switch.
2) Hold and ramp down the brightness and HOLD the switch down until the light is at the lowest brightness (indicated by one quick blink of the switch).
3) Let go of the switch, within 1/2 second push and release the switch one time.
Doing the above, the switch will blink once and will no longer glow green until you turn on and off the Q8 again.
Now I’m not sure if this is only happening on this version of the firmware (if there has been different versions for the Q8) or I just have a special Q8.
Thought I would post it on here and see what you guys think.
I ordered 3 Q8’s from the first batch for friends and me. However one of three got the button light broken. I remember this was an issue on the first batch. I contacted the miller some time ago, but i heard he was very busy with personal stuff. Can someone here tell me i this is a problem i can fix myself. Or can i order some kit with parts to replace something?
What do yo want to mount where?
The Q8 ON TOP of the Panasonic?
Or the Q8 and Panasonic with a double sided screw on the two threads?
Or the Q8 on a tripod?
