Aah I had not thought about it that way.
Thank you for correcting me.
Maybe I was thinking that way too much for reducing costs.
Iām sorry for repeating that too.
Thank you Djozz for the better perspective.
Interested in two. Depending on price of course.
you are numbers 846 and 847 on the interest list
Interested in Group Buy.
UPDATES Cross section of the BLF V2 lantern added. Further field testing going great! photos coming soon. also will have more detailed specifications for the lantern to provide to Barry & Thorfire soon. All we may need is to find someone to draft up a CAD of the lantern in the cross-section drawing below if Barry needs a more detailed version for Thorfire to work on.
Sbslider can you PM or email me a text-file of the list so i can update the OP? Thanks
SilentObserver is 848 on the interest list
email sent
Looks like progress! Thanks for the update. :+1:
What if the āshadeā was a cylinder rather than a cup?
The top surface of the āaluminum threaded shelf/baseā could be left un-anodized to help reflect light.
This would save a bit of polycarbonate and eliminate the paint, but Iām not sure how it would affect the lanternās strength or otherwise change its construction. Just a thought.
I like the idea of amber switch LEDs rather than green ones like the Q8.
Looking forward to the new photos. Hope you had a great trip!
Nice cross section DBSAR, is there also a notch and pin on the lens and base so they canāt twist and damage the wires?
Interested in two please.
Put me on the list for one please.
Nice to see some progress! But what happend with the tint ramping option we discussed earlier? As far as I understood it, we would need at least 6 LEDs (and a new LED board) to make that work.
Also I thought that our priority is to create the āultimate Laternā, not the cheapest.
And please add me for a second one.
I would be interested in this, please add me to the list.
Definitely interested. Those Samsung LEDs look really nice.
Is it intended that the lantern is water resistant? The schematic shows an o-ring at the base of the diffuser, but nothing at the top or around the center screw
The cup shape makes it much stronger than just a cylinder type shade. i did test that shint base reflector idea originally, and the flat-white surface increases light reflection and reduces the hard-light glare and bad light distribution flaws of most factory lanterns i tested & used. (shiny or chromed reflectors cause to much glare & artifacts.
The cross section can;t really show it, but the shade would definitely need either one or two index locking notches at the head area to lock it from turning. (Same goes for the base)
added! number 849 on the list.
That tint ramping is definitely in line to be added, as this cross section is just the design of this prototype being tested. All it would need is the change to six emitters, ( three 3000K & three 4000K LEDs) and the addition of a third wire lead from the driver.
Thanks for mentioning that to remind me i missed adding that to the drawing. i did forget to add the upper rubber gasket/o-ring to the head & the small o-ring to the center bolt. (next updated drawing will have those)
