Use coupon code 64M2NU to get $146.99 price (best to date).
This is a very popular budget model with well balanced hardware. Even has AMOLED Full HD display, global LTE bands(TDD-LTE B38/39/40/41, FDD-LTE B1/B3/B5/B7/B8/B20) and 14nm power efficient processor.
Use coupon code 1ce7e8 to get additional discount and final price of $35.99 ($69.90 - lowest to date)
Set includes rechargeable variant electric screwdriver made of aluminium alloy (with charging base), stylish white magnetic case, 56 pcs screwdriver bits, Wowpad magnetic screw pad, other accessories (sucker, USB cable, magnetizer, screw bottle, triangular plastic spudger/pry tool) - see detailed photos and description on product page.
Use coupon code c709fb for additional discount and final price of only $17.35
This is high quality precision screwdriver set with well designed(they even win reddot award) and compact case. See reviews @Banggood product page - there are also user provided real photos that better show the high end craftmanship.
Use coupon code 6897bf for massive additional 40% discount and get final price of $17.99 Lowest price ever !Limited offer so hurry up!
True power rating. This panel can easily charge any smartphone and will also charge in overcast conditions as well (with decreased rate of course).
Pair it with LiitoKala Lii-100 0.5A/1A Li-ion Ni-MH USB Battery Charger for example and you can have independent power source for your flashlight needs
I’d have to second that! It’s on a special deal if you can get it from the US warehouse right now (with shipping cost added, of course) - about C$85. But a big coupon that could bring the price to C$50 would really make it worthwhile.
I’ll do my best but I doubt BW-L3 deal would be as much cost effective (per Watt) as BW-L2. With above BW-L2 deal when you buy 2 pieces you get 30W of solar panels in total for only $36. That way you also get increased reliability. The most obvious downside is not combined output - no problem if you charge more devices but if you have single power hungry device (like a tablet) that’s a deal breaker…
Use coupon code be29af for additional discount and final price of only $15.99 Best price to date! Limited pieces !
Use coupon code BWL3X to get 30% discount (-$22.80 and final price $53.19 at the moment).
This is the most powerful solar charger in Blitzwolf range. It’s capable of delivering up to 3.8A of current (it full sun) which is enough to charge at full speed high power devices (high-end smartphones or tablets). Even smaller Blitzwolf panels can charge smartphones in cloudy day so this should easily power more demanding tablets. Solar cells from SunPower provide unsurpassed conversion efficiency over 23.5%
Blitzwolf chargers offer best value/cost ratio on the market and quality is very good.
At the moment the most cost effective version is 2A BW-L2 15W for $17.99 - see here: 15W version deal
