Ok sorry, misltranlation on my part. I have asked him again, and he said that while 45% IACS beryllium copper is stiffer than copper after being worked on, it is actually slightly softer than copper before being worked on.
From what I can translate from French, he said that when forming 45% IACS beryllium copper into a spring, it has a slightly higher chance of breaking than copper, and much higher chance than 38% IACS beryllium copper. That is because 38% IACS beryllium copper contains more impurities added when making it, such as nickel and cobalt, giving it higher mechanical strength.
Finally, containing a higher percentage of copper and beryllium just makes it more expensive to produce.
TLDR: 38% IACS beryllium copper, while a bit weaker electrically, is stiffer than 45% IACS, before and after being formed, and is much less expensive to manufacture into a spring.
Sorry for the mistranslation, but I don’t speak or write much about these kind of topics much, like science, so I don’t always know the appropriate terms.
You don’t machine springs, they are bent into shape.
And also you DO want compressibility, if it’s too stiff it will plastically deform when compressed which is not what you want for a spring, it should remain in elastic deformation.
@Enderman, yes, you want compressible enough springs, not too stiff. Beryllium copper 38% IACS is good in that regard. In fact, phosphor bronze and beryllium copper 38% IACS are quite good in this regard.
However, as seen by djozz in his test, springs that collapse are a problem when looking for higher conductivity, as they collapse quite easily. This is not in relation to stiffness, but elastic memory when being compressed.
We want spring with good elastic memory.
Stiffness Elastic memory goes in an increasing manner:
Edit: Haha I absolutely love Beavis and Butthead. Such a great show :+1:
Edit 2: IMPORTANT
I made a mistranslation again. By stiff
Beryllium copper IACS 38% is a good material for a spring in terms of stiffness, and is the best balance between electrical conductivity, cost, and elastic memory. Phosphor bronze is a bit cheaper, but we already these in most sizes. A tall, not short high current spring is what’s lacking.
Well, besides a nice laugh I've had after discovering the title of hIKARInoob's linked video (to my Spanish native speaking mind that sounds :-D “moñoñoñoñoñoño”), I have an interesting question in this regards fellows: What is the relative hardness of these spring alloys versus the hardness of the usual standard carbon steel cutting pliers are usually made of? You know, if the allow is slightly softer it can be of cutting edge :-D help.
It would be interesting to make it narrow for reverse mounts. By reverse I mean that the thick end touches battery. Lone Oceans does so to gain more space on his drivers.
Most of the Chinese companies got back to me, and they said that while they said Beryllium Copper 38% IACS is not much more expensive than phosphor bronze, they would have to order separetely the material, and for 200 pcs, it would probably exceed my original price point.
The only way I could get them at a reasonable price would be at onne of thr companies which sells 1000 pcs of them for 350$ everything included, since it is a custom order
Now, that would be a bit overkill. Even a group buy would be hard pressed to sell all of these units, and I do not have enough hobby money to afford all of that, and space.
So, unless someone, or many people, are willing to split the difference, I don’t think the group buy is going to be successful.
Just as well. Beryllium is a nasty metal, I’ve had to use it in aerospace applications (mostly the oxide beryllia BeO for it’s thermal properties, with tight control throughout the lifecycle), but it is not something to be used ubiquitously.
It used to be used in solid rocket motors, but that was insane.
“Formation of BeO from beryllium and oxygen releases the highest energy per mass of reactants for any chemical reaction, close to 24 MJ/kg”
I doubt there is any danger in spring wire, but other alternatives are available with decent design.
Do you think I should make an group buy interest page for the Beryllium Copper Springs in the same size as the Djozz springs? They can handle twice the current, so they could be a replacement for spring bypasses.
If I can have enough interest in enough springs(at least 500 springs to be sold) then I will consider making the order.
Ahh that would be perfect. I did not think about Richard. He would perhaps like it. Especially now since he could sell many more springs since while the short springs are excellent, the problem is they are short.
I think 9mm base diameter is still too wide to fit onto a small board with 7135’s loaded on the same side as spring. If you could make a skinny one and one as you describe to meet the minimum that might be better
